Remove the speakers from the cabinet, maybe it's a resonance problem causing a feedback loop?
Or put the Phono on a very heavy stone platter...
But more probably: the motor of the phono is going defect, running not smooth any more... touch the platter/case or directly the motor itself. Maybe the humming comes from the motor ... mechanical problem with the motor or the power supply of the motor. 50Hz power supply humming? Try a new cap parallel to the motor.
Transport screws losened ?
Late reply.... Which ones are the transport screws and how tight are they supposed to be? Cheers Phil
