My very own Beocord 2400
This post has 217 Replies | 2 Followers
chartz
Burgundy, France
Posts 4,171
chartz Posted: Thu, Oct 23 2014 11:32 AM
There!
Eddie (Valve1) and his lovely wife were here this morning with a beautiful gift (not really Stick out tongue) from Denmark, an unrestored Beocord 2400. Something to keep me (and Søren I guess, do you mind?) busy for the next few weeks.
Thanks again Eddie for your service, that was really nice! It was really nice talking to you too, although you did most of the talking!
Stay tuned...
Jacques
Christian Christensen
Stockholm
Posts 512
Really nice.
I am getting to my BC2400 within a week or maximum two.
My re-capped M75 are my precious diamonds.
Søren Mexico
Mexico City
Posts 6,411
Thats good news Jacques, congrats, cant wait for the first report and pics
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 23 2014 3:59 PM
No matter how hard I searched, I couldn't fiand any pictures of the BC2400 mechanics.
I did find something though!
First picture. A bit (2 hours) of cleaning. The capstan wheel is completely shot, it is hard and dented. To the bin.
The right brake lever has lost its cork. This will be an easy fix, I've got cork sheets somewhere in the dungeons (this is a martinism Stick out tongue).
That rubber debris are horrible: no problem on alu, but on steel it is bad news, oxydizing it badly.
Not powered yet, but Frede did it and it went well, so no worries here I guess.
The counter belt seems fine.
Jacques
Søren Mexico
Mexico City
Posts 6,411
I am a little busy today, will open up mine again tomorrow, and go along with you.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 23 2014 4:22 PM
Good! Looking forward to that Søren!
Jacques
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Thu, Oct 23 2014 6:07 PM
Good luck to you both.  My BC2400 is out in the garage and gets used at least weekly.  It's a solid piece of equipment.  Hard to believe, but it retailed for $500 US in the 70's.  Not so hard to believe is that it was fairly well regarded by some magazines I've seen on Tapeheads.net.
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Thu, Oct 23 2014 6:10 PM
Delighted to be to be able to Beoassist and meet you both.
You have a stunning collection of restored classics.
We traveled through some great looking villages in your area after. Have it chalked in for some cycling in the future.
Got to our place and was lucky enough to get the only parking spot in the village. Total distance was 4050k.... beer time now Beer
Looking forward to your restoration !
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 23 2014 11:30 PM
I found a broken spring and one at the bottom of the deck. I will have to figure out what these are for. More dismantling tomorrow!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 24 2014 11:03 AM
Here's the back of the Beocord. I had to buy this special screwdriver (nutdriver?) to access the four nuts.
JUST BEAUTIFUL
Here you see one of the two connectors that allow the command panel and the electronics to be removed.
You do have to lift the amplifier pcbs to have access to two of the three screws (shown in the service manual, screws n° 54 p 79).
The broken-and-found-wandering-inside-the-box springs...
The home-made replacement.You can see the heads, well-worn. This recorder was actually used and maintained, I certainly wasn't the first to get inside (fingerprints at several places, screwheads).
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 24 2014 12:31 PM
The new brake pad. I cut it from a sheet of cork and superglued it to the lever.  How did you remove the left drive wheel Søren?
The new capstan wheel. Really easy to remove, you just pull the shaft once the little cover is removed. Much simpler than Revox...
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 24 2014 12:48 PM
One more question, how do you grind a rubber wheel that has irregularities on its edge to be perfectly rounded? The rubber is good and grippy, so I suppose I can save it (the FFW wheel above).
Of course, I don't have a lathe!
Thanks for any tips on that matter.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 24 2014 1:16 PM
The electronics, with the two connectors (photo 2).
Jacques
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Oct 24 2014 2:44 PM
chartz:
I do.  Bring it with you next week and we'll see what we can do with it.
Dave.
Søren Mexico
Mexico City
Posts 6,411
chartz:
At the end of the shaft there is a pressure retainer ring, remove that and it comes out, if I remember right. When out it comes apart as shown, and it all will have to be adjusted and greased before assembly.
On the right drive, you will have to remove the pulley for the counter drive, which also has a function for the brake/clutch function, and has to be adjusted, when assembling
There you will have to check the lift arm with felt, on mine the felt was loose, so I cleaned it and glued it back
Søren Mexico
Mexico City
Posts 6,411
To remove the retainer rings you will need one of these
Søren Mexico
Mexico City
Posts 6,411
Damn they found me, only one star I will have to renew my membership
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 24 2014 4:04 PM
Thanks Søren.
It seems that the 2400 is a bit different, look:
No circlip, and the brake is over the second step!
Is the shaft just stuck? I can't take it out. Sad I'll see whether ther's a side allen screw.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 24 2014 4:10 PM
Edit: yes there IS a screw! Smile
Jacques
Søren Mexico
Mexico City
Posts 6,411
chartz:
You can even see it in my pic
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 24 2014 5:20 PM
Søren Mexico:
chartz:
Oh yes, I see it now!
Damn!
By the way... Can't do without when fixing Beocords and Beograms!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 25 2014 12:04 PM
A bit of cabinet making today!
First, sanding (240 grit to erase surface defects) and then finishing off with iron wool. I insist on doing this operation by hand, I almost never use a block because it will take off too much veneer. The edges are particularly vulnerable to sanding.
After iron wool sanding, before oiling with teck oil. There were tiny bits of missing veneer, which after repair and sanding I can't spot! I used a bit of veneer that I got from another member, thanks to him Smile Sorry, I forgot to take pictures Sad
The bottom of the deck, with the usual 'surprise'. Relatively clean. The diagrams will remain in the envelope.
The power lead is captive, and you can see its storage box here (top left).
Jacques
valve1
Posts 1,502
valve1 replied on Sat, Oct 25 2014 12:42 PM
Jacques, I am impressed by your enthusiasm Yes - thumbs up
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 25 2014 1:17 PM
Thanks Eddie, but don't be, every piece of B&O you saw at home had the same treatment... I buy cheap!
Oiling... Many applications will be necessary to soak the wood completely.
These won't do. I'll have to cut new pieces of black cardboard. They protect the wood at the left and right edges.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 25 2014 3:40 PM
After the removal of this PSU, access to the pulley - and to the belt - is easy. A new belt was fitted.
Has someone been here before? What's a little acetone anyway?
Yuck!
EDIT - Jan. 4 2015 : I realised the diodes were in fact a wrong replacement for a 3-amp bridge (because the PSU has to power the amps). I therefore fitted a correct B80C3700-2200 bridge.
After some cleaning...
This is the end of tape automatism disengagement switch, it turns the detection bulb off. The solder tag solder joint was dry, leaving the wire lose between the play and pause levers, thus disturbing their actions!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Oct 26 2014 3:23 PM
Another problem today. The rewind function did not hold, I had to push the lever hard to do it, and it still didn't hold, and after letting the lever go, the deck spilled tape, with the slack absorbers going wild.
I was tempted to look at the lever adjustments, but no, there was nothing to be done there. After some head-scratching, I finally decided that it was the rewind idler wheel which wasn't pressing enough on the flywheel and I was right!
All I had to do was unscrew the two screws below and re-adjust pressure.
Jacques
Stockholm
Posts 512
I jump in here, as I have just started some work on my BC2400
the connectors on the board I cleaned with silver polish, and then after that some alcohol to get ride of left overs.
Stockholm
Posts 512
Stockholm
Posts 512
Question.
My back plate , bottom plate under the wooden chassi..was nailed...is this correct ?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Oct 26 2014 7:48 PM
Christian Christensen:
Question.
Yes, this is correct. I had to mask it to do the paint job of the black bottom part. Sad
Welcome aboard!
Jacques
Søren Hammer
Denmark
Posts 953
What a nice thread! This is what I have missed Embarrassed
Might give my own Beocord 1800 the same treatment and install her in my current system. Even two open-reel decks in one system isn't enough though...
Do you want to recap and rebias them, too?
@Søren: Do I spot the B&O reel that I gave you when you visited me? Whistle
@Eddy: Did you get the whole 5000 system back home safely? What did SWMBO say to the Beovox'es? Laughing
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Stockholm
Posts 512
Mine BC2400 i in excellent shape, so I have chosen reburb to :
Recap record and playback card.
recap power supply
recap line input card
recap speaker output caps
HAvent found motor- caps yet, if I find them I will replace
replace pinch roller with new.
polishing contacts on the cards.
oil to motor.
cleaning some mechanics
demagnitising heads
replacing lamps
Azimuth adjustment ( one problem azimuth screw is half broken..dont know how to solve that  )
checking in and outputs levels
adjusting record Bias.
Something like that. :)
Feel free to ask question or tip me on good things to think about regarding this particular machine.
Christian
Stockholm
Posts 512
Ahh motorcaps was on the other side...will go and pickup new ones tomorrow
Søren Mexico
Mexico City
Posts 6,411
Chris why change all the caps, I checked mine and only 2-3 was out of specs
Stockholm
Posts 512
I have an ,a clear prupose with the refurb.
I want to maximaze the audio quality of the recordings.
Adjust the BC2400 to its maximum., with brand new Emtec tapes.
I have an experiemnet.
I have heard rumours from  serveral directions that a BC2400 performes just as good as a Revox.
So...I bought myself a Pr99, only for this for this experiment.
I want to compare.
There for I want all the caps in the line from line input to tape and from tape to be fresh. before I start tuning all levels.
I think like this, if I bought myself a Pr99 I can just aswell take 3 hours to replace this audio line of caps in the BC2400
The BC2400 is up for a recording competition against a Pr99
Stockholm
Posts 512
...crazy...aint I ? ;)
valve1
Posts 1,502
valve1 replied on Mon, Oct 27 2014 6:35 AM
Søren Hammer:
Not to hijack the thread,  I got it out of the van and upstairs and no more. SWAMBO is ok with the BVs Big Smile
I will do a write up.... if I ever find the time that being retired is supposed to have lots off.  Confused
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 27 2014 8:23 AM
Søren Hammer:
Hi Søren H! Have you seen this?
valve1:
That's what my mum and my step parents have kept telling me Big Smile
We are looking forward to the pictures!
The electronics: I will inspect every single card, check voltages and quiescent currents when I have finished the transport. Not quite there yet.
Christian, if the Papst motor starts fine, why replace the capacitor?
Could you show me the path of that bulb switch wire in your Beocord 2400? It seems to always be in the way of something! Angry
And yes, buying a PR99 to compare the Beocord with is crazy. Erm..
Jacques
Stockholm
Posts 512
Jacques,  so no risk for the motor if the caps would open ?
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 27 2014 9:17 AM
No, it simply won't start unless helped by hand. Of course you don't want to let it like that!
The only time I've ever changed a start cap was on my ReVox G36 because the take-up reel was desperately slow when the spool was full.
Jacques
Page 1 of 6 (218 items) 1 2 3 4 5 Next > ... Last » | RSS
