My very own Beocord 2400
This post has 217 Replies | 2 Followers
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Jan 5 2015 12:04 PM
Yes, that's the one. Since you are in Sweden, you could give Josef Svalander a ring.
Jacques
Christian Christensen
Stockholm
Posts 512
of course I could Smile but I am anyway very curious how the result was of your wheels.
I dont think anyone here have tried his service yet....
My re-capped M75 are my precious diamonds.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Jan 5 2015 12:56 PM
I'll tell you when I get the wheel! It is a bit longish (4-5 weeks).
Sad
Jacques
Peter Christy
Paignton, United Kingdom
Posts 17
Jacques,
My bridge rectifier turned up this morning, but there is a problem:
Bridge by pchristy65, on Flickr
The one on the right is the original, the one on the left the replacement. The pin connections are different, even though the physical spacing is the same!
A warning to others who may be looking for this part: CHECK THE PINOUTS before fitting a replacement!
Luckily my high current discrete diodes have turned up today as well, along with some electrolytic capacitors. However it may be a few days before I can fit them, as my attention is currently on my other piece of Scandinavian hardware that I am restoring.....
100_2329 by pchristy65, on Flickr
Smile
Pete
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Jan 7 2015 2:06 PM
Oh! It must be the first time I see a rectifier bridge with this pinout! It is most definitely wrong. A counterfeit? I would not use it and bin it immediately.
Should be like this:
Nice car! Yes - thumbs up
Jacques
Peter Christy
Posts 17
Hi Jacques,
Yes, the rectifier is obviously no use to me - I was expecting it to be like yours! Luckily I have received a packet of 1N5404 diodes, which should be more than adequate.
The new electrolytics are physically much smaller than the originals, even though they are the same rating. I will check out the originals more carefully before replacing them, I think! If there is no significant ripple on the output, I may leave well alone.
Cheers,
Pete
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Jan 7 2015 2:26 PM
Exactly what I did. I kept them.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Jan 26 2015 9:56 AM
Hi!
I have received the "new" rubber wheel!
It's going back.
Jacques
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Jan 26 2015 11:45 AM
chartz:
Hi!
It's going back.
Do you mean 'back' to the manufacturer?  What was wrong with it after such a long wait?
Dave.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Jan 26 2015 11:46 AM
PM Dave!
Jacques
Stockholm
Posts 512
I have asked Svalander some general question about that service.
And he said that they gather enough wheels under a month  to send a big package away for this work
So ..that is the answer for the long wait.
Stockholm
Posts 512
any noticable deifferens of lower belling ? :)
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Jan 26 2015 2:21 PM
Christian Christensen:
Sorry?
Jacques
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Jan 26 2015 3:15 PM
chartz:
Sorry?
'Lower Belling' sounds like a quaint old English village!  Not sure what you mean there Christian.
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jan 27 2015 7:04 AM
That rectifier... Laughing
I've seen many counterfeit parts but I think this one beats the lot.
They didn't even manage to get the pinout right - or maybe the pinout is right and the lettering is wrong.
Not that it matters much, it's probably just an empty shell with nothing inside, not unlike some prescaler ICs I bought
a couple of months ago. Have you checked?
Stockholm
Posts 512
Dave.
You described that the lower flywheel that is connected to the motor, is causeing the hum level.
And that if rubber on the flywheel is not soft enought, the flyweel "bells".
So Sorry that I did my own construction of the english language.
I was wondering if the new flywhell has decreised the motorhum that spdread in the chassi
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Jan 27 2015 3:05 PM
OK, it's Jacque's machine but I understand now I think.  If the rubber is too hard, I suppose it can resonate and produce a 'hum' or slight 'ringing' sound.
Dave.
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Jan 27 2015 4:39 PM
I was wondering if the new flywheel has decreased the motor hum that spread in the chassis.
No, that's one of the problems. It actually made it worse. And the motor itself is completely silent. The old wheel was much, much better... and it still was bad!
But the job will be done again free of charge of course. Another five weeks' wait then I suppose.
Jacques
Stockholm
Posts 512
please keep us update on that wheel. Wink
Christian
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Feb 10 2015 6:07 AM
Of course.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Feb 24 2015 11:56 AM
Still waiting. I hope the result is worth the wait...
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Mar 12 2015 8:09 PM
Good evening!
The new idler wheel has finally made it home. It looks exactly like the original one, in shape and dimensions. It looks like a new old stock one, so the job was nicely done this time (unless Josef sent me a NOS one Confused ). It is not silent, but the noise level is now acceptable and there is no more wow.
I am expecting a genuine B&O stamped NOS one for the rewind function, we'll see.
Cheers!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Mar 13 2015 9:52 AM
And today I got the NOS idler wheel, perfect! I will now tackle the electronic restoration (new caps mainly).
To be continued...
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, May 27 2015 3:38 PM
Perhaps this is the final piece of the puzzle... Frede found it for me, as promised Smile Thank you!
Some polishing will be required as usual. Good thing the front logo is intact!
Don't you just love to behold it?
Jacques
sonavor
Texas, United States
Posts 3,732
sonavor replied on Wed, May 27 2015 5:08 PM
That is really nice. It looks brand new.
John
Søren Mexico
Mexico City
Posts 6,411
A beauty Jacques, I have just ordered spare caps for my BC 2000, transistors for my BM 1900 and 2400, the BC 2000 is sitting on my dining table apart in the main pieces, Monday the parts will arrive, in the weekend I will take a shot on one slide potentiometer, I saw something like a lock piece at the end of the poti. it may be possible to take them apart without much work. Will be back with more next week. I am a little nervous about the germanium TRs there are a lot of them in there. But it worked nearly very good when I tested. I have new tapes (RMG SM 911) waiting. My compliments to your good work.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 28 2015 7:02 AM
Hi Søren,
I am confident that you will succeed!
The hard work, apart from the sliders, will be head adjustment. You need a good tape recorded on a well-aligned machine to do that should you decide on replacing those cushions underneath the heads and the guides.
The Beocord 2400 has springs, but both heads were shot!
Let's hope the germanium transistors will be fine. Do keep in mind I had a bad recifier on my Beocord 1500 though.
Jacques
Ben_S
UK
Posts 631
Ben_S replied on Fri, May 29 2015 10:22 AM
Looks fantastic Jacques, I really need a better lid for my BC1800.
I'm not sure mine has the logo on the top either actually. Did they all have that do you know?
Ben
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, May 29 2015 1:04 PM
No they didn't all have a logo. But I have seen that many have the recess. What was there in the first place?  Confused
It does look better on the picture than it really is, but I haven't finished the polishing process yet. It requires a lot of work, and I absolutely refuse to use abrasive paper, or micro-mesh for that matter. You can never quite get full transparency with this method. Those who have seen my restored dust-covers have been impressed Embarrassed
So I start polishing, then forget about it for a few weeks, and get back to it until the result is satisfactory. I couldn't run a business that way, but that's the beauty of DIY.
Jacques
Ben_S
UK
Posts 631
Ben_S replied on Fri, May 29 2015 9:58 PM
chartz:
I think mine has the recess too.
My lid is an absolutely terrible state though. I think it is beyond satisfactory repair really as there are two scratches which are both very deep. Goodness knows how that happened but there we are. Weirdly, the other item I have which is similar is my other reel player (Beocord 1100).
I think you are right with the abrasive paper, I have tried it before on another lid and despite spending hours on it I couldn't get it to look as good as I wanted to. It seems you have managed to find a way to do them properly though!
Ben
Stockholm
Posts 512
A nosy question, who is Joseph that sells NOS idler wheels, I am VERY interested
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Jun 17 2015 2:08 PM
Joseph Svalander, in your very own country I believe!
But he doesn't sell NOS wheels, you misread me Wink
Jacques
Stockholm
Posts 512
"And today I got the NOS idler wheel, perfect"
Where did you get hold of a new old stock idler wheel ?
So after you had Joseph redo the job, you still got hold of a NOS. ?
Who has these spareparts  ?  I would dearly dearly buy a couple myself if I knew who to turn to... :)
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Aug 12 2015 8:34 AM
I'm afraid that new old stock wheel was a one-off find. Sad
Jacques
Stockholm
Posts 512
anyone that knows how to accsess and from what angle the screw that holds the bronze wheel to the motor ?
Søren Mexico
Mexico City
Posts 6,411
If I remember right its a M4x6 Allen grub screw, Allen key 2 mm, what I dont remember is how to get at it, but maybe you may have to take the motor out
Stockholm
Posts 512
Thats the problem, Søren , cant get the motor out without getting to that screw
Stockholm
Posts 512
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 31 2015 5:57 PM
That hex key needs to be a bit longer than the usual ones, but I managed to take the stepped pulley out from the top of the machine. Not difficult at all.
Jacques
Stockholm
Posts 512
I didnt, had to take out motor from backside of the chassi
Page 5 of 6 (218 items) « First ... < Previous 2 3 4 5 6 Next > | RSS
