Aussie Michael:Thanks MM I will try that setting. And yes thank you for the link with the video, i did see that :-) I saw you suggested the S8 but i got confused as you said BS8 and i thought... i just sold my BS8, and how would that work. But yes the S8 is a good idea and being that it's black it could fit ok - but then there's more wires. I can't afford a BL19, so i was even thinking a BL11. I'm not sure how much the S8 even costs, but I read here previously that it's a great value sub. I know what you mean about the swapping of the speaker groups, and I was thinking i wonder if I can make one of the colour buttons on my remote be a "shortcut" to speaker groups :-)
Thanks Mjmedlo lol
With the S8, and connecting to the TV to use as 2.1 the setup guide shows that you have to buy the RJ45 PL cables to use with the system separately. Is that correct? Did you have to do that?
Hi Michael,
there is no 'red button trick' for a particular speakers group.
But you can use the MyButtons for that.
Make a setup watching tv - with all preferred settings (including the 'mono/center speakers group'.
Pick one of the MyButtons to save that!
Make another setup - with the 'front/left-center-front/right' group, and save that to another MyButton.
Now you have two shortcuts for what you intended.
Certainly I meant the S8 (BeoPlay S8).
Sure you will have to deal with cables for the satelites. But, even if you would go for a WiSA solution for the fronts, you would have to deal with cables = power cables!
The sub must - in your case - be connected via two RJ45-PL cables. No big deal - those are the standart PL cables nowadays. And (of course) a power cord. Yes, you would have to buy these PL cables seperately
You connect and configure these three speakers as 'sub', 'front/left' and 'front/right' - your existing rears/surrounds stays as they are now.
Adding a BL11 would be another great solution, if you want to keep it simple and without external fronts.. But you'd probably pay more for a second hand BL11, than you would have to for the S8.
And you would have to run cables too!
Thanks again MM greatly appreciate your help
Aussie Michael:Thanks Mjmedlo lol With the S8, and connecting to the TV to use as 2.1 the setup guide shows that you have to buy the RJ45 PL cables to use with the system separately. Is that correct? Did you have to do that?
and to answer your question. . yes, you must buy the PL cables separately
Aussie Michael:Upon unpacking the screen and installing it on the stand the guys call me over to have a look and there is a little piece of something under the glass in the top left hand corner. This looks like packing material. They asked me what I would like to do and of course I don't really know, so I said continue and i'll work it out with the dealer when they call in the afternoon. How it got there who knows and to be honest I don't really know what it is. Sort of looks like a fibre of some sort. I spoke with the dealer and they will arrange service to come take a look at it for me. They will likely remove the glass and blow out what's there.
Ok Service came today - all blown out, even though it was minor. No issue now :-)
Aussie Michael: Ok Service came today - all blown out, even though it was minor. No issue now :-)
I know the Beovision 11 frame and glass are one piece and is held in place by a few screws.
Is the Avant glass held in place by screws, glue, sealant... especially curious because there's no apparent frame.
Aussie Michael:Okey dokey....UpdateMy BL19 should arrive this week.I called the dealer to find out what's going on as I hadn't heard. It seems I have to keep ringing. Anyway.... 2 months later lolYay.
BeoNut since '75
Aussie Michael:My BL19 should arrive this week. I called the dealer to find out what's going on as I hadn't heard. It seems I have to keep ringing. Anyway.... 2 months later lol
Michael, it almost sounds as a joke...
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Silver
Silver will give you the most decor flexibility - it goes with everything and blends in
I also got silver for those reasons and the base of the Avant is Silver.
BeoGreg:You got bitten by the australian B&O bug, it's ferocious. Nice setup indeed. You'll have to tell us what's the difference on/off both for movie and audio.
Nice setup indeed.
Michael, pretty nice furniture you have there in the corner. Congrats
Give us a full review how you experience this combo. Never heard the BL19 in conjunction with the Avant only.
Michael,
I'm intrigued that you have a motorised stand yet you appear to have the TV parked across the corner of your room when switched off.
With all my previous and current TV's with stands I've always set the TV to turn parallel to the wall when not being viewed. Doesn't the new Avant give you an even better option for being parallel to the wall (and against it) when off, but swinging and coming more forward at its viewing angle?
Graham
EDIT
But just noticed that your speakers are down in the last pic, so maybe it's on audio?
Still interested to know whether you have tried different positions for the TV when off.
EDIT 2
Looking at previous pics you've got a lot of boxes hanging on the back of the TV? Does that rule out parallel parking???
Chris:Michael, pretty nice furniture you have there in the corner. Congrats Give us a full review how you experience this combo. Never heard the BL19 in conjunction with the Avant only. " Believe nothing you read and only half of what you see, let your ears tell you the truth. "
vikinger:Still interested to know whether you have tried different positions for the TV when off. EDIT 2 Looking at previous pics you've got a lot of boxes hanging on the back of the TV? Does that rule out parallel parking???
Chris:Give us a full review how you experience this combo. Never heard the BL19 in conjunction with the Avant only.
Exactly! :) I can imagine many people here would be very interested to get your impressions as Avant sounds already very impressive on its own. Now with an excellent sub... ...might be a very legitimate front part of a high quality surround system even without additional speakers.
I still remember the thread, where KMA talked about how a BL11 improved the sound of his new BV11.
I am sure, that the sound of the Avant will benefit massively from the BL19.
And, yes - just by adding some smaller rear speakers, you could even get a nice multichannel setup.
I - too - am looking forward to read about Michaels experiences with the sub.
AnalogPlanet: Chris:Give us a full review how you experience this combo. Never heard the BL19 in conjunction with the Avant only. Exactly! :) I can imagine many people here would be very interested to get your impressions as Avant sounds already very impressive on its own. Now with an excellent sub... ...might be a very legitimate front part of a high quality surround system even without additional speakers.
Exactly. I don't need additional speakers at the front at all :-) Please see my previous 2 posts for my review :-)
Duels:Your set-up looks great with the BL19. Interesting that in your original post you said the room was too small for a BL19! It never takes us long to convince ourselves does it?
haha ... well kind of ;-)
It came about because I was watching a movie and at the start with the dolby surround sound promo, there was literally no bass and I thought, oh no, that has to change...
I went to go and look for the BL 11 because it was smaller and more discreet, however, the guy at the store said that really for movies you would be better off with a 19 because it's not strong enough.. I was um-ming and arghghg-ing over the 2 and being that the price difference wasn't that great, and also I can put it anywhere, say next to the two chairs if i didn't like the look for felt it was too big .
But it's not boomy like the Bose Accoustimass is, nor my previous Sony, its just rich and warm. In my set up it's a worthwhile addition. I did in speaker setup when the Avant gives you the signal of the speaker, when i was on the 19 i turned it up to 80 and i thought there was an earthquake lol. Id never watch anything that loud.
Last night before watching Avatar BluRay where the PQ on the Avant was OUTSTANDING , i was looking for a movie with the Dolby promo and i couldn't find one!
Aussie Michael:haha ... well kind of ;-) It came about because I was watching a movie and at the start with the dolby surround sound promo, there was literally no bass and I thought, oh no, that has to change... I went to go and look for the BL 11 because it was smaller and more discreet, however, the guy at the store said that really for movies you would be better off with a 19 because it's not strong enough.. I was um-ming and arghghg-ing over the 2 and being that the price difference wasn't that great, and also I can put it anywhere, say next to the two chairs if i didn't like the look for felt it was too big . But it's not boomy like the Bose Accoustimass is, nor my previous Sony, its just rich and warm. In my set up it's a worthwhile addition. I did in speaker setup when the Avant gives you the signal of the speaker, when i was on the 19 i turned it up to 80 and i thought there was an earthquake lol. Id never watch anything that loud. Last night before watching Avatar BluRay where the PQ on the Avant was OUTSTANDING , i was looking for a movie with the Dolby promo and i couldn't find one!
paolomariano:Hi, I am really happy to read what you write. I am considering to add a bl19 as well to my setup: bv10-40, two bl12-3 as front and two bl12-2 ad rear. And what I want is just a rich and warm bass...
Raeuber:You will get it, be sure. The BL 19 is an outstanding sub.
Aussie Michael:And Paolo i believe it will look so beautiful in your room - so minimal
Michael, what a good looking UHD picture the Avant presents
Chris: Michael, what a good looking UHD picture the Avant presents
Yeah - you can almost smell the shoe
Chris:Michael, what a good looking UHD picture the Avant presents
Must be getting cold down in Melbourne now ;) Very nice TV looks good in your space! It doesn't look good just anywhere so you've done well. BL20s would go nicely with this lot I reckon!
