Hi guys,.. and Happy New Year 2015!
I'm trying to Airplay music to my BeoVision18 speakers.It works but,..The audio signal reaches an ATV3 connected to a BeoVision11 which is sending the WiSA signal to the speakers. Unfortunately there seems to be no way to turn off the screen during this.
Does anyone have a solution to getting the audio from my Mac to my speakers through the ATV+TV without requiring that the tv-screen be turned on?
thanks for any help.
/shawn
THE ANSWER is over here: http://archivedforum2.beoworld.org/forums/p/13289/115356.aspx#115356Kudos to the BeoWorld team for the hand-holding).(there seems no way for me to delete this forum posting here. :(.. otherwise I would).
Very nice set up Shawn.
There is indeed a way and MM is your guy to explain this. He'll be around shortly :)
Shawn already asked the almost same question in another thread today.
He was given the answer from me and kallasr immediately/simultaneously
Or is there a difference between both posts, that I haven't seen?
Haha cool thanks for that MM You Funky Kat :)
Hi MM
i'd be interested in how to do this but I can't access the link to the other thread
Do you mean this one?
Ah I see. Yes I have always used P. mute. With the mention of the wireless Beolab 18s. I thought there might be a new way
