The Moment software version Release Notes
This post has 749 Replies | 13 Followers
Millemissen
Flensborg, Denmark
Posts 14,680
@Chris
'DLNA update function' - in which way an update?
'..multiroom update is not for week 20 but for week 25' - I hear that for the first time!
Who is your source for that information?
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, May 6 2015 10:07 AM
Update fixed a bug making Bluetooth to disappear.
Also, I noticed a small improvement: When you select a song, there is an animation making the songtitle to "pulsate" until the song is actually played. Quite sure this feature was not there before. Its good to get an indication that Moment has responded to your selection.
Sal
California, USA
Posts 1,197
Sal replied on Thu, May 7 2015 3:03 AM
Chris:
And particularly bad news for those who are waiting, as I do: The scheduled multiroom update is not for week 20 but week 25. Sad
Hopefully this will be when the Moment will be released in the US.
Apple Watch... Moment... the wait continues. Stick out tongue
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Jun 24 2015 8:35 AM
B&O offered us a new update. The Moment is now running SW 1.2.14.1018 - 1.2.284.206315794
This release introduced new features which you can search the content of Deezer and TunIn. Also Beolink multiroom functionality was added so that you can distribute music to multiple rooms in your home and to multiple B&O systems.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Jun 24 2015 8:37 AM
Chris:
Finally!
Anyone tested?
koning
holland
Posts 4,220
koning replied on Wed, Jun 24 2015 8:37 AM
All problems solved chris?
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Jun 24 2015 8:42 AM
Very surprised here!
Trying the new software out now. The Moment looks suddenly more mature now.
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Jun 24 2015 8:49 AM
Very exciting, suddenly TuneIn plays everywhere in the house.
koning
holland
Posts 4,220
koning replied on Wed, Jun 24 2015 8:52 AM
Great!😃
I hope they have solved the nas problems to.
Millemissen
Flensborg, Denmark
Posts 14,680
koning:
Great!😃
If you mean: searching in the content from your connected NAS/DLNA server - this was not part of the update.
koning
holland
Posts 4,220
koning replied on Wed, Jun 24 2015 8:56 AM
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Jun 24 2015 8:57 AM
It looks now a really mature system, my BS3200 looks a bit workless now.
I have to try the new search function, there is also a new button on the screen 'link' to send the AUX from the ML/NL converter to your Moment. It was worth the wait and for all the non-believers, B&O did it again!
koning
holland
Posts 4,220
koning replied on Wed, Jun 24 2015 9:03 AM
@MM
Are they going to solved this in the next Sw update?
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Jun 24 2015 9:05 AM
Chris:
Are you able to post some screenshots?
I´m at work currently and I´m so exited to see the improvements Stick out tongue
Millemissen
Flensborg, Denmark
Posts 14,680
Chris:
...It was worth the wait and for all the non-believers, B&O did it again!
Thanks Chris,
as you well know - I have always trusted that they would keep their promises.
Hopefully this might impress some of the 'naysayers'.
Millemissen
Flensborg, Denmark
Posts 14,680
koning:
@MM
I guess no one knows the answer to that.
It is a small company - we will probably see the improvements coming in small bits.
Millemissen
Flensborg, Denmark
Posts 14,680
Chris:
That screen is more for choosing to (on the Moment connected speakers) listen to/join in to, what may already be playing from another device on the network e.g Deezer started from an Essence (2nd).
Millemissen
Flensborg, Denmark
Posts 14,680
Chris:
Tip!
If you connect an AirPlay compatible device to the line-in connection of the BS Moment, you will be able to distribute the sound (played to this device) on the network.
Sort of a workaround - but nice, otherweise (apart from involving iTunes on a computer) you won't be able to listen to airplayed content on multiple devices in a setup.
Aussie Michael
Melbourne, AU
Posts 3,730
Millemissen:
Chris:
Tip!
MM what do you mean about line in?  eg 3.5mm jack?  In that case isn't that like connecting any AUX device?
Normann
Posts 277
Normann replied on Wed, Jun 24 2015 2:53 PM
Chris:
I have now done the update. But how does the multiroom work..?  I don't find it..
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Jun 24 2015 3:33 PM
Normann:
I set my ML/NL converter in settings tab: AV master and networklink tab to Beosound Moment.
In configuration tab, sources visible on ML : choose Beosound Moment to radio with button of your choice
koning
holland
Posts 4,220
koning replied on Wed, Jun 24 2015 5:04 PM
Is anyone able to make some screen shots.
Normann
Posts 277
Normann replied on Wed, Jun 24 2015 5:30 PM
Chris:
Normann:
And the same with Deezer. Choose Moment to Deezer?
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Jun 24 2015 6:08 PM
Noticed that the song and artistname now is shown on my BV11 when I play a Deezer song.
Seanie_230
UK
Posts 2,278
Oh oh oh it would appear that I might be able to selected wired speakers and speakers connected to a TV
I am wondering if this usb thing will mean I don't actually need a beolink convertor.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
BeoMegaMan
Posts 601
Seanie_230:
If you don't have any ML product you don't need a NL Convertor
Ah, you know... A little B&O here, a little there
Seanie_230
UK
Posts 2,278
Really it reads like it won't be needed if it replaces an audio master
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Brilliant news
When calling a source from a link room no longer switches the main room TV off its main room video source so it now works like the old Audio master and can be played in another room without affecting the main room.
This should be the same issue that some had with the main room activating when a timer was set in a link room.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
After talking to a dealer today he was able to play music to multiple tv's at the same time in the NL network.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Jun 24 2015 9:11 PM
I am able to play e.g Deezer on mu Moment and pick up the sound in my link speakers.
But I am unable to press Radio in a linkroom (from BL3500) and get Deezer to play. Its says Radio on the speaker display but bo sound.
NL/ML Convertor configured so that Radio command is mapped to Moment and Deezer,
Any hints?
Millemissen
Flensborg, Denmark
Posts 14,680
Aussie Michael:
Millemissen:
Chris:
Tip!
The BS Moment has a line-in connection - R/L phono/cinch - under the cover on the backside.
This acts as a 'source' on the Moment and now on the network - just like TuneIn , Deezer....
Since it has 'autosense' it will open up automatically, when the device, that is connected there, sends sound - and you will be able to listen to that.
The AirPlay device was just an example - since a lot would want this on the network as well.
It could be a CD-player, a vinyl player or anything... (personally I would connect a Playmaker).
By the way - this goes for the bluetooth connection also. Send sound via bluetooth to the Moment and you will (when the setup it properly configured) be able to hear it on the network.
Normann
Posts 277
Normann replied on Wed, Jun 24 2015 9:41 PM
Hiort:
I can play the sound from my V1 on my Moment, but can not figure out how to Get the sound from Moment on my V1..
do i have to configure something on my NL/ML converter?
Seanie_230
UK
Posts 2,278
Why would you need a convertor for a v1 and moment as they are both NL?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Normann
Posts 277
Normann replied on Wed, Jun 24 2015 10:13 PM
Ahh, that's true.. But why can't i get sound out of the V1 ?
How do you guys do when you want to hear the music also on the V1 og BV11?
When i push the link button, the sound from the V1 comes on the Moment and the speakers connected to it..
Millemissen
Flensborg, Denmark
Posts 14,680
@Normann
Is the Moment connected to the BV11 or to its own speakers?
What did you already do in order to try to get the sound on the V1?
Did you look for the Moment in the menu on the V1/BV11?
Did you try the 'Join' command on the remote?
Chris
Ostend-BE
Posts 1,170
Example:
Chris
Ostend-BE
Posts 1,170
ON ML tab:
Chris
Ostend-BE
Posts 1,170
And IR mapping:
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Jun 25 2015 6:23 AM
Tunein channel information and song played is now displayed:
Smile
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Jun 25 2015 6:34 AM
Artist artwork has been added in the background when a Deezer or NAS song is played. Nice I would say.
Page 2 of 19 (750 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
