@Chris
'DLNA update function' - in which way an update?
'..multiroom update is not for week 20 but for week 25' - I hear that for the first time!
Who is your source for that information?
Update fixed a bug making Bluetooth to disappear.
Also, I noticed a small improvement: When you select a song, there is an animation making the songtitle to "pulsate" until the song is actually played. Quite sure this feature was not there before. Its good to get an indication that Moment has responded to your selection.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Chris: And particularly bad news for those who are waiting, as I do: The scheduled multiroom update is not for week 20 but week 25.
Hopefully this will be when the Moment will be released in the US.
Apple Watch... Moment... the wait continues.
B&O offered us a new update. The Moment is now running SW 1.2.14.1018 - 1.2.284.206315794
This release introduced new features which you can search the content of Deezer and TunIn. Also Beolink multiroom functionality was added so that you can distribute music to multiple rooms in your home and to multiple B&O systems.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Chris: B&O offered us a new update. The Moment is now running SW 1.2.14.1018 - 1.2.284.206315794 This release introduced new features which you can search the content of Deezer and TunIn. Also Beolink multiroom functionality was added so that you can distribute music to multiple rooms in your home and to multiple B&O systems.
Finally!
Anyone tested?
All problems solved chris?
Very surprised here!
Trying the new software out now. The Moment looks suddenly more mature now.
Very exciting, suddenly TuneIn plays everywhere in the house.
Great!😃
I hope they have solved the nas problems to.
koning: Great!😃 I hope they have solved the nas problems to.
If you mean: searching in the content from your connected NAS/DLNA server - this was not part of the update.
It looks now a really mature system, my BS3200 looks a bit workless now.
I have to try the new search function, there is also a new button on the screen 'link' to send the AUX from the ML/NL converter to your Moment. It was worth the wait and for all the non-believers, B&O did it again!
@MM
Are they going to solved this in the next Sw update?
Chris: It looks now a really mature system, my BS3200 looks a bit workless now. I have to try the new search function, there is also a new button on the screen 'link' to send the AUX from the ML/NL converter to your Moment. It was worth the wait and for all the non-believers, B&O did it again!
Are you able to post some screenshots?
I´m at work currently and I´m so exited to see the improvements
Chris: ...It was worth the wait and for all the non-believers, B&O did it again!
Thanks Chris,
as you well know - I have always trusted that they would keep their promises.
Hopefully this might impress some of the 'naysayers'.
koning: @MM Are they going to solved this in the next Sw update?
I guess no one knows the answer to that.
It is a small company - we will probably see the improvements coming in small bits.
Chris: I have to try the new search function, there is also a new button on the screen 'link' to send the AUX from the ML/NL converter to your Moment.
That screen is more for choosing to (on the Moment connected speakers) listen to/join in to, what may already be playing from another device on the network e.g Deezer started from an Essence (2nd).
Chris: Very exciting, suddenly TuneIn plays everywhere in the house.
Tip!
If you connect an AirPlay compatible device to the line-in connection of the BS Moment, you will be able to distribute the sound (played to this device) on the network.
Sort of a workaround - but nice, otherweise (apart from involving iTunes on a computer) you won't be able to listen to airplayed content on multiple devices in a setup.
Millemissen: Chris: Very exciting, suddenly TuneIn plays everywhere in the house. Tip! If you connect an AirPlay compatible device to the line-in connection of the BS Moment, you will be able to distribute the sound (played to this device) on the network. Sort of a workaround - but nice, otherweise (apart from involving iTunes on a computer) you won't be able to listen to airplayed content on multiple devices in a setup. MM
MM what do you mean about line in? eg 3.5mm jack? In that case isn't that like connecting any AUX device?
I have now done the update. But how does the multiroom work..? I don't find it..
Normann:I have now done the update. But how does the multiroom work..? I don't find it..
I set my ML/NL converter in settings tab: AV master and networklink tab to Beosound Moment.
In configuration tab, sources visible on ML : choose Beosound Moment to radio with button of your choice
Is anyone able to make some screen shots.
Chris: Normann:I have now done the update. But how does the multiroom work..? I don't find it.. I set my ML/NL converter in settings tab: AV master and networklink tab to Beosound Moment. In configuration tab, sources visible on ML : choose Beosound Moment to radio with button of your choice
And the same with Deezer. Choose Moment to Deezer?
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:Oh oh oh it would appear that I might be able to selected wired speakers and speakers connected to a TV I am wondering if this usb thing will mean I don't actually need a beolink convertor.
If you don't have any ML product you don't need a NL Convertor
Ah, you know... A little B&O here, a little there
I am able to play e.g Deezer on mu Moment and pick up the sound in my link speakers.
But I am unable to press Radio in a linkroom (from BL3500) and get Deezer to play. Its says Radio on the speaker display but bo sound.
NL/ML Convertor configured so that Radio command is mapped to Moment and Deezer,
Any hints?
Aussie Michael: Millemissen: Chris: Very exciting, suddenly TuneIn plays everywhere in the house. Tip! If you connect an AirPlay compatible device to the line-in connection of the BS Moment, you will be able to distribute the sound (played to this device) on the network. Sort of a workaround - but nice, otherweise (apart from involving iTunes on a computer) you won't be able to listen to airplayed content on multiple devices in a setup. MM MM what do you mean about line in? eg 3.5mm jack? In that case isn't that like connecting any AUX device?
The BS Moment has a line-in connection - R/L phono/cinch - under the cover on the backside.
This acts as a 'source' on the Moment and now on the network - just like TuneIn , Deezer....
Since it has 'autosense' it will open up automatically, when the device, that is connected there, sends sound - and you will be able to listen to that.
The AirPlay device was just an example - since a lot would want this on the network as well.
It could be a CD-player, a vinyl player or anything... (personally I would connect a Playmaker).
By the way - this goes for the bluetooth connection also. Send sound via bluetooth to the Moment and you will (when the setup it properly configured) be able to hear it on the network.
Hiort: I am able to play e.g Deezer on mu Moment and pick up the sound in my link speakers.
I can play the sound from my V1 on my Moment, but can not figure out how to Get the sound from Moment on my V1..
do i have to configure something on my NL/ML converter?
Ahh, that's true.. But why can't i get sound out of the V1 ?
How do you guys do when you want to hear the music also on the V1 og BV11?
When i push the link button, the sound from the V1 comes on the Moment and the speakers connected to it..
@Normann
Is the Moment connected to the BV11 or to its own speakers?
What did you already do in order to try to get the sound on the V1?
Did you look for the Moment in the menu on the V1/BV11?
Did you try the 'Join' command on the remote?
Example:
ON ML tab:
And IR mapping:
