The Moment software version Release Notes
This post has 749 Replies | 13 Followers
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, May 31 2016 7:03 AM
Chris:
I wonder why it should been better without getting another update
I did a library reset again last evening.
Once the process was completed, i.e. check mark on in the About page (which does not mean that all my tracks and album are available for playing yet), I tried the MoodWheel middle ring and all was ok, each point had its own sequence of numerous tracks mixing my own collection and other similiar mood tracks.
At some point, once my DLNA library was completely processed (I can see that when the BeoMusic app shows me the real number of tracks and albums sitting on the NAS), I noticed that the MoodWheel was faded and not operating, sign to me that some processing was going on in the background.
This morning I checked again, the middle ring is operating as expected, I simply noticed a small difference with previous behavior: once you have pressed a point, only one track is shown to be played but within less than a minute other tracks are added to the list.
I will see this evening if the status is the same and I'll test the other rings.
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, May 31 2016 7:22 AM
Hi Mbolo01
I did the following yesterday, in accordance what Deezer asked me. It brought no solution so far this morning...
I answered Deezer today:
I tried the solution your team proposed, but it did not help to my problem with the Beosound Moment’s MoodWheel. The outer and middle ring of the MoodWheel are not playing any content from Deezer.
Let me explain in detail what I have been trying now:
- I unplugged the device several minutes completely from power. This brought no solution.
- The Beosound Moment has the latest update from May 11, version SW 1.7.7.1155-1.7.399.223963144
- (a:) I removed my Deezer credentials from the Beosound Moment service settings menu (picture-1), and added them again (account: xxxxxxxxxxx). This brought no solution.
- (b:) I removed my Deezer credentials from the Beosound Moment service settings menu and removed the Beosound Moment app from my account/applications on the Deezer website (picture-2). Next, I done a complete factory reset of the Beosound Moment.
- (c:) After the factory reset was done I unplugged the Beosound Moment completely from power and restarted the Beosound Moment after a couple of minutes.
- I reconfigured the Beosound Moment from a factory fresh start and added my Deezer credentials to the Beosound Moment service settings menu app. Next, I looked  into my account at the Deezer website for a reappearance of the Beosound Moment app in the applications. The app was reappearing again, but this brought no solution.
The strange thing is that the fault in the Moodwheel on the Beosound Moment only appeared after receiving the above mentioned software update on May, 11 from B&O. Before receiving this latest update, the MoodWheel was working well.
To avoid confusion, only the MoodWheel with the outer (picture-3) and middle ring (picture-4) is not giving me any Deezer content. This should be content coming from Deezer.
The inner ring (picture-5) plays content from my own DLNA collection, this works well as you can see on the pic.
Searching for music or playing a Deezer playlist from the Beosound Moment user’s menu works, I can view all my Deezer playlists and listen to them (picture-6). It’s only when I want to use the the MoodWheel for listening to Deezer moods, that it gives me no content.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, May 31 2016 7:57 AM
Hi Chris
The Deezer recommendation didn't work for me either, but I had no real hope as it sounded a standard answer for another type of device.
Try the library reset, you may be positively surprised
Giraffe
Posts 37
Giraffe replied on Tue, May 31 2016 8:50 PM
For me it's the same as with Mirco - the outer two rings show Deezer content but the inner ring only shows very few songs. Interesting how different the effects are.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Jun 2 2016 6:46 AM
Giraffe:
I have done the following test: (1) disconnect my Deezer account (2) reset the library (3) wait for the harvest to be done (confirmed by BeoTool) (4) go to sleep
After 8 hours, guess what? Middle and outer rings are faded, which is normal as Deezer is not configured, the inner ring has a reduced number of seeds instead of 1000, and between 0 and 10 tracks are following the seed, so I can play less than different 100 tracks using the MoodWheel ....... Fyi I have 32959 tracks according to BeoMusic.
Conclusion: Without Deezer the Moment MoodWheel does not operate as expected either, why would B&O blame Deezer for the outage then????
Chris
Ostend-BE
Posts 1,170
Chris replied on Mon, Jun 6 2016 11:07 AM
Hi, to all fans of the Beosound Moment.
Its been almost one month, after the latest software update, I encountered problems with the MoodWheel. It started to become a habit to take a test every day if there was any improvement.
This morning, like doing a ritual, I pressed once more on the middle ring and to my surprise it started playing content from Deezer for the first time in a month. I'm excited? No, not directly, there was a downside to it.
Deezer stopped playing after some 5 tracks. Simply, absolutely unexpectedly…
I pushed again on the middle ring, at another place. It started playing again… for some more or less 10 tracks.
Now I tried the outer ring (must be content exclusive of Deezer) and this time it plays randomly now for one hour…Then the music stops again. But there seems to be some strange improvement. Every push on the MoodWheel gives me a longer listening time.
At present there was no update available from B&O to the Moment, so who fixed my MoodWheel?
I did received in the past week(s) some answer from BeoCare:
- That they were aware of the problem.
- They will pass my problem to the team.
- To contact my dealer for a new MoodWheel (I did’t know the MoodWheel was hardware made?)
No really helpful solutions… And most important of all, no acknowledgment that the MoodWheel indeed was malfunctioning.
A couple of weeks ago I contacted Deezer and explained my problem. I get a very friendly answer that their team could not reproduce my problem with the Moment’s MoodWheel. So I wrote another mail to Deezer, this time I enclosed all necessary details with pictures, my Deezer account credentials, and…
Now I get another answer last Friday, that this information is very valuable and they would had a immediate look into this.
Could the problem come from Deezer and not from B&O? Would the problem lie with my account and the device’s app the Moment is running?
I don’t know who fixed it, but I presume it is Deezer. B&O or Deezer has no remote entrance to my Moment, so it has to be almost certainly Deezer who did some maintenance at my account.
I’m not to enthusiastic now and I'm not going calling loudly, everything is in good order. Let’s see if the MoodWheel keeps working tomorrow and the day after tomorrow, and …
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jun 6 2016 8:19 PM
Chris:
I did my 345th library reset since last month's upgrade and where Deezer "seems" to work for the middle and outer rings, the inner ring behavior is worst at each reset .... today I have the same sequence of songs for any point I'm pressing, interesting :-)
So by the sound of it the Moment is still a product that is so incredibly buggy that B&O should not be selling it. It's been what... 2 years on the market in this condition?
For the same price you could have bought a NAS a 4 iPads and you can bet everything would work a hell of a lot better.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Jun 8 2016 7:16 PM
Test of the week:
Factory reset!
Inner ring is back to normal, even better, no repeat in the circle, no repeat in the songs flow, enough songs per point, songs still added in alphabetical order and I have not determined yet if songs from my Deezer albums were included
Middle and outer rings: NOTHING
abyss
Posts 47
abyss replied on Wed, Jun 8 2016 8:07 PM
After the uptdate, the outer ring did not work. I disconnected my deezer-account an registered again. The inner and the outer rings worked, but not the middle ring. I disconnected the cable for loudspeakers for a view minutes. After reconnecting the cable, the rings started to behave as they should. Since then i had no trouble with the Moment.
So, I'm actually pretty happy with my moment. That said, we should expect more from B&O and they should also have this ambition.
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Jun 8 2016 8:30 PM
mbolo01:
Test of the week:
Factory reset!
Hurray, well done mbolo01.
I fired up this morning my Moment, and guess what... Outer and middle ring showed me nothing! Worked well for... two days. What a joke.
abyss:
Abyss, I'm not very religious, but in this case I would burn a candle. You are a very lucky man.
YannChris
Larmor Plage - France
Posts 232
YannChris replied on Sun, Jun 19 2016 8:55 AM
As a cautious guy,  I always wait for the feedback from other users to perform the upgrade...
So I didn't  this time and guess what's happening...
... l have the same issue with the inner ring showing only a few songs from Deezer instead of the content of my NAS.
I made several reset of my library with no result.
So I have to use the iPhone app to access my content.
I suspect Deezer to be a part of the problem.
Have a great week-end,
Yann
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Jun 19 2016 10:33 AM
Hi YannChris,
I'm surprised you have an update ready. My Moment shows nothing today,
Sorry I thought you had an update. Still running on the latest version from May11: version SW 1.7.7.1155-1.7.399.223963144.
For your interest: the inner ring is working as supposed, the outer ring gives me Deezer content but not endless (playing for around 10 songs) then I have to push it again and it keeps working endlessly, the middle ring shows no content at all.
I'm cautiously awaiting the next update. Have a great week-end to...
YannChris
Posts 232
YannChris replied on Sun, Jun 19 2016 10:46 AM
Chris,
the software version on my Moment is 1.6.6.1131....
I did not install the version which causes so many issues today
kind regards,
yann
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Jun 19 2016 3:02 PM
YannChris:
Chris,
kind regards,
yann
Hmmm...
Think this proves it is a Deezer problem.
If you have the problems but are still not on the latest release.
abyss
Posts 47
abyss replied on Sun, Jun 19 2016 5:53 PM
Meanwhile, i have the same troubles again (middle ring is not working).
one should expect from B&O being able to provide a update within a reasonable time  Hmm
Steph
France
Posts 1,059
Steph replied on Sun, Jun 26 2016 1:43 PM
The Interaction, Visual and Motion Design of the Moment was made by Tectonic, a US studio with clients like Amazon, Beats, HBO, Cisco, Samsung, Skype,...
Very strange the Moment is full of problems... Unsure
Link to B&O page on Tectonic website
I was ready to swap my BeoSound 5 for the Moment but...
koning
holland
Posts 4,220
koning replied on Sun, Jun 26 2016 1:59 PM
Don't do it...keep your BS5
Steph
France
Posts 1,059
Steph replied on Sun, Jun 26 2016 2:15 PM
I think so, but who knows... Wink
I really like the whole concept, the 2 sides, features like moodwheel and pattern play,...
koning
holland
Posts 4,220
koning replied on Sun, Jun 26 2016 2:19 PM
Wait for the MKII if there will be
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Jun 30 2016 12:31 PM
Looks like the Moodwheel is back to life
Chris
Ostend-BE
Posts 1,170
Chris replied on Thu, Jun 30 2016 12:42 PM
mbolo01:
Thanks mbolo01 for your alertness. All MoodWheel Deezer rings are working indeed.
I cross my fingers...
YannChris
Posts 232
YannChris replied on Thu, Jun 30 2016 4:39 PM
A new update?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Jun 30 2016 4:50 PM
Nope -  Deezer fix I guess .... While listening to my own music  (inner ring) i realized that one of the song played was not part of my NAS collection, I then decided to press the other rings to see if behavior had changed from nothing played to something played, and it had, without any BS Moment rebuild or reset, only regular power off/on
Chris
Ostend-BE
Posts 1,170
mbolo01:
You have it right. For some two months I received the following message in starting the Deezer for Mac app on my iMac: 'Deezer will change, we are working on a new homepage'.
Yesterday the new update was ready for download.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jul 1 2016 6:30 AM
Chris:
Deezer for Mac
Yep, I don't know why but I also made the link with the Mac app being changed and the MoodWheel issue.
The issue with the Moment started soon after Deezer app started to display this message and the issue with the Moment stopped soon after the Deezer app was updated. Now I'll wait for BeoCare to notify me it's fixed :-) counting days!
YannChris
Posts 232
Is it time for me to do the update?
At this time, the inner wheel only shows Deezer content and nothing from my NAS.
NAS content is only available through playlists.
Kind regards,
Yann.
Chris
Ostend-BE
Posts 1,170
Chris replied on Fri, Jul 1 2016 7:53 AM
YannChris:
Kind regards,
Yann.
Well YannChris, it actually looks that for whatever reason the MoodWheel is working again as it should.
As mbolo01 also mentioned, all indications are pointing now that the problem was caused thru the API from Deezer, because its strange that the MoodWheel now suddenly seems to be working at the same time Deezer released the update for OSX where 'Flow' is now also part of the homepage. So, I can cautiously say this fault on the Moment is solved.
A little more transparency from BeoNotCare on future problems would be very welcome, I would love to call it again BeoCare! As this thread now was evolving it scared a lot of people away from the Moment.
About your NAS server, I don't know. Its very difficult to answer your question, I'm running a Mac mini server with the latest Twonky server 8.2.1 and its running faultless with my Moment. I even use the sleep function from 11PM to wake-up at 5AM without any problem regarding the Moment. If I'm not wrong, I think member Hiort could give a better answer how the NAS behaves with the Moment actually now.
Anyway, I would upgrade to the latest software. It makes no sense to continue using older software.
But I understand, if it does not function you'll get a nasty feeling, especially if BeoCare remain silent and your dealer is looking at you like a fish on dry water.
This is one of the reasons why I like this forum so much, we are here to help each other when all else fails (or at least to give each other some courage).
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jul 1 2016 12:45 PM
YannChris - I would try a library reset first as the update will not do that for you and you may be in the same situation after the update.
If you have an IOS device, you can install and use BeoTool app to check your Moment status
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jul 1 2016 1:14 PM
Chris:
The Moment is now flawless in handling my NAS content. I run the Twonky version recommended by B&O: 7.2.7 on my iMac pointing to my Synology NAS iTunes library. My library has some 3000 songs so its not super big.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jul 1 2016 1:25 PM
Chris:
Would be really nice to have a Flow possibility on Moment as well.
PeterBOBP
Posts 133
Hiort:
Chris:
+1
Suggestion: start "flow" when you press the black "bulls eye" of the moodwheel
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jul 1 2016 1:44 PM
Hiort:
I confirm it is almost flawless now, I have Twonky 8.2 on my QNAP NAS and 34000 tracks on it, exception being: the "no sound" happening between seconds 12 and 20 while playing tracks from an album leveraging DLNA (not sure I have heard this behavior while playing music through the MoodWheel). Playing albums from Deezer does not have this issue. I have reported that to my reseller weeks ago (as BeoCare does not want to hear from me anymore) and I have no response.
Millemissen
Flensborg, Denmark
Posts 14,680
Hiort:
Isn't PatternPlay supposed to be a personalized and sophisticated 'version' of Flow?
PeterBOBP
Posts 133
good point.
Patternplay plays a source/playlist/radiostation/mood etc. based on your listening habits. It does not (at least I am not aware of that) play music (randomly) based on your music taste across your library. Flow is like a super randomizer on the full Deezer library taking into account your music taste / your favored tracks in Deezer.
Regardless; I use patter play a lot and it does give me in a lot of cases the correct radio station / music / mood on different times of the day / different day of the week.
Peter
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jul 1 2016 2:36 PM
Millemissen:
Hiort:
True, but sometimes you just want to tell Moment to play "whatever I may like". PatternPlay could play me e.g a radio station, because I usually listen to radio on that time that day.
Millemissen
Flensborg, Denmark
Posts 14,680
Hiort:
That's a good point!
PeterBOBP
Posts 133
Hiort:
Indeed.
Question about current behavior. Let's say Patternplay plays music from Deezer; is there is case where it actually plays Deezer's "Flow" or does it always plays a certain mood / playlist / radio station as I assumed in my previous post.The latter is my experience, but I am not 100% sure.
Do you know?
Peter
PS: I now play "flow" through my phone with bluetooth
PS2: you can check what patternplay is playing when you open the BeoMusic app an click on the "play" icon in the left down corner (i.e. it displays the music queue), but I am sure you already knew this.
Giraffe
Posts 37
Giraffe replied on Fri, Jul 1 2016 5:32 PM
Unfortunately I cannot say for myself - the inner ring of the Moodwheel shows *no* content any more, regardless if from Deezer or Twonky. The rest of the Moment's user interface does give me access to all content. I tried:
- resetting the library (surprisingly comes back after a few seconds with a check mark).
- removing the Deezer account and signing in back.
- removing the Twonky account and configuring it back.
Giraffe
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jul 1 2016 6:47 PM
Giraffe:
If you have the BeoMusic app, can you see the Twonky content through it? If yes can you play it?
Page 13 of 19 (750 items) « First ... < Previous 11 12 13 14 15 Next > ... Last » | RSS
