Essence Mark 2
This post has 202 Replies | 6 Followers
Millemissen
Flensborg, Denmark
Posts 14,680
carlito:
Thanks Elephant
 His advice was that you only switch on/off the system with the remote, everything else you do with the Beo App.
Your dealer seems not to be well informed.
Maybe he should have said, that untill today it is not known, which controls will be possible using the ir-eye (via remote or direct on the eye).
It is a software-thing - I suppose we will be wiser in September/October.
As of today there is no official support for a connected ir-eye (which does not mean, that it won't work).
AnalogPlanet
Vienna, Austria
Posts 678
elephant:
One solution is MM's magical blue box,
Or you could just use two cables and one H6 and an H8
And you probably get zero dropouts
Hahaha, well that would be something. :)
Now seriously, looking forward towards cable-free NL setup, I am also more and more wondering if the MM's magic "NL Connect Box" might be an improved Receiver 1 with NL chips/SW inside? And what if there would be also BT streaming capability? :)
Alternatively, if Essence Mk2 would have BT streaming then it is even more simple. :) <3
carlito
Posts 239
carlito replied on Tue, Jul 28 2015 9:45 AM
The perfect solution would be to have a Bluetooth remote  when you enter the room AND the possability to control the Essence with IR commands as well... #wishlist
Do you have experience with the IR eye? If there is a need from people here i will try to get one for testing purpose...
TWG
Posts 1,672
TWG replied on Tue, Jul 28 2015 9:55 AM
carlito:
which seems to be given after adding the IR eye!? Hope somebody will test it out sonner that possible. :)
Millemissen
Flensborg, Denmark
Posts 14,680
carlito:
That is the way things can work.
Of course we are interested in 'you testing the ir-eye'.
But do remember, that the real thing won't be possible before after the 'big update' later this year.
All I was told is, that the ir-eye works - but not with full support for all commands (yet).
In the FAQs on the B&O website about the BS Moment there is a chart, which indicates which function, you can activate (on the BS Moment) with the BeoRemote One/the Beo4. That might be a hint to what will be possible with the Essence.
elephant
AU
Posts 8,219
elephant replied on Tue, Jul 28 2015 11:05 AM
mjmedlo:
I ordered mine today.
Hopefully 2 weeks out.
On the brink of ordering ... might even do it tomorrow ... however the delivery in AUS is in September Sad
Mind you that might save me from Software disappointments Embarrassed
Unless the software slips to October [:\'(]
BeoNut since '75
carlito
Posts 239
carlito replied on Tue, Jul 28 2015 12:17 PM
didn't found the mentioned chart, but have a look on this (from the B&O FAQ)
In order to operate BeoSound Essence with Beo4, you must connect an IR receiver (material number: 8089119) to the socket marked IR-IN on BeoSound Essence.
Operate BeoSound Essence with Beo4 …
Beo4 button  Source or function
RADIO Internet radio/ TuneIn
A.AUX* Line-in connected source
N.MUSIC Spotify
Centre button** Pause/play
PLAY/GO Resume playback
STOP Stop playback
>>  <<   Previous/next
 Image Adjust volume up
 Image Adjust volume down
 Image Switch BeoSound Essence to standby
Some apps may react differently to the described commands. Also the commands do not apply to a Line-in connected source. Playback must be started on the connected source.
* To use A.AUX, press LIST repeatedly on Beo4 to bring up the 'buttons' in the Beo4 display, then press the centre button to activate the source.
** The pause function is not available on a Beo4 without navigation button.
Note! Operation with the Beo4 remote control can only take place when the name of the source shows in the display: RADIO, A.AUX and N.MUSIC.
BeoSound Essence is only supported for use with Beo4. You cannot use BeoRemote One with BeoSound Essence.
How do I operate BeoSound Essence with my Beo4?
Millemissen
Flensborg, Denmark
Posts 14,680
It is a strange thing - in these FAQ's you some times find stuff, that is not mentioned in the user guides - or that the dealers don't know of.
I'll post a screenshot from the 'Moment-FAQ', when on my Mac later. There the Remote One commands are mentioned.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Tue, Jul 28 2015 1:17 PM
carlito:
The IR-Receiver cost € 98.-
What a pettiness from Bang & Olufsen ?!
The IR-Receiver is integrated in the Playmaker
which cost half price compare a BeoSound Essence.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Tue, Jul 28 2015 1:41 PM
Millemissen:
Nowadays manual instructions by Bang Olufsen
are poorly written and incomplete No - thumbs down
Millemissen
Flensborg, Denmark
Posts 14,680
So - now you've got your foot in the door!
This was not the point of my post.
Shouldn't be a big problem to you, since you have transformed yourself to DeviaBoy68
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jul 28 2015 2:26 PM
I expect everybody is going to use an iOS or Android device to use the Beomusic 2.0 app to controll their system.
Controll of own Music collection, TuneIn, Deezer, controll of the joining of different NL products. Since I have access to a beta version I use a remote for music listening hardly anymore.
lonfred
Posts 200
lonfred replied on Tue, Jul 28 2015 3:05 PM
Will the Essence Mark 2 be able to use as an audio master in a ML system together with BLC and a ML video master? What will be the difference be between the Essence mk2 and a Moment? My dealer has give me a good deal for a Moment but I dont know what to choose...
carlito
Posts 239
carlito replied on Tue, Jul 28 2015 3:50 PM
First question: What is BLC?
From my point of view the new NL concept is without Audio master. It is more like one system (e.g. Essence) is playing and others sources (e.g. A9) is "joining" the same source (e.g. Deezer, Spotify)
The Moment is a more elaborated Essence (mood wheel) - or in other words an Essence with an iPad. To be honest, I was never dived deep into the Moment topic as i don't like the design.
Millemissen
Flensborg, Denmark
Posts 14,680
carlito:
A BLC is a converter - meant is the NL/ML Converter, that is use to integrate NL and ML (= MasterLink products e.g. the BV7).
You are right - there is no 'master' in a NL setup.
But the AudioSystems have different functions and may also be quite different in the handling.
With the BS Moment you get the features 'MoodWheel' and PatternPlay' - something, that you won't have with the Essence (2nd gen) or with the A9 (2nd gen).
And you get a dedicated tablet (that cannot be misused for non-audio things) with an integrated control wheel. Some people like the pure basic wooden side - others the more exploring panel side. No need for an extra tablet.
With the Essence/the A9 you get AirPlay and Spotify Connect.
You can use the 'Wheely' with all of them - and the BeoMusic app.
Of course it is a matter of preference (and taste), which one you buy.
You can have both in a setup - by the way.
They can all work as standalone units or as part of a NL network.
elephant
AU
Posts 8,219
elephant replied on Tue, Jul 28 2015 5:35 PM
lonfred:
I recommend becoming very educated in the Moment by playing with it in the store -- spending several hours across several visits
Don't jump simply because of a deal
Unless dealer is a true consultant who has learned your wants & needs over several years
BeoNut since '75
lonfred
Posts 200
lonfred replied on Tue, Jul 28 2015 5:37 PM
Thanks. But to be clear, if I take away my ML BC2 and put an Essence there instead with an BLC could I assign the radio button on a Beo4 to start playing and controll Deezer (I suppose on an IPad) in an ML Linkroom?
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Tue, Jul 28 2015 10:38 PM
Millemissen:
Maybe I have one foot outdoor but the second is always in Beo. Big Smile
Maybe I own more Beo products like you. Stick out tongue
Millemissen
Flensborg, Denmark
Posts 14,680
BeoBoy68:
carlito
Posts 239
carlito replied on Sat, Aug 1 2015 9:16 PM
Short update. Installed the Essence MK2 today. Overall experience is very good. The BeoMusic App is currently NOT working with the new Essence. The last update of the App was back in January this Year.
Workaround: Spotify via Bluetooth is working, TuneIn is working (Configured via BeoSetup App). ITunes Library connected via Aux-In from my DAC (controlled via Remote App from Apple).
Keep you posted when the update is ready
vlohjr1
Posts 553
vlohjr1 replied on Sat, Aug 1 2015 10:06 PM
carlito:
Hi carlito
Does it have wisa?
carlito
Posts 239
carlito replied on Sun, Aug 2 2015 8:00 AM
Yes, after the major software release in September or later this year. My dealer loan me a Transmitter 1 until then.
Millemissen
Flensborg, Denmark
Posts 14,680
...and the price?
elephant
AU
Posts 8,219
elephant replied on Sun, Aug 2 2015 10:23 AM
Millemissen:
...and the price?
In AUS, the price of an Essence Mark I minus the price of its remote
i.e. The Essence Mark II appears to be priced at the same as the Mark I at a white box for white box level
The Mark II's remotes are separate and I suspect have a range of prices I.e. a trade off between an IR eye for existing Beo remotes, versus the table top
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
elephant:
That is the reason, why I still can't believe, that it will come with built-in WiSA.
Would be nice, if it does, though.
badgersurf
Posts 539
I popped into a dealer near where I work, I was told that the Mk2 was £850, and did not come as a seperate box and remote. So just hoping thy were wrong.
also told there was no upgrade available for those who brought an original Essence
elephant
AU
Posts 8,219
badgersurf:
I am not sure which part you are hoping is wrong !
£850 is more expensive than the standalone box in AUS, so maybe GB is packaging the remote with it and charging more ?
My understanding (in AUS anyway) is that if you have a pre-existing Mark I and you buy a second new Mark II to get multi-room, then you get the original upgraded. Which makes sense - why upgrade if there is no requirement for additional features ?
BeoNut since '75
MARKFS
Posts 90
MARKFS replied on Sun, Aug 2 2015 7:27 PM
Here is a short video on how the Multiroom system works with the Essence Mark 2.
The other link is to the new Beosound Essence page on Bang & Olufsens webpage. The page isn't really ready yet, but you can get some information out of it.
https://vimeo.com/116215210
http://www.bang-olufsen.com/da/sound/sound-systems/beosound-essence-new
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks - appreciate that.
The first video should be well known to most (interested) Beoworlders. It was even rumoured, that the 'joining' of the A9 was faked, because the sw was not finished at that time...
The second was mentioned in a thread started on last saturday by the user Emil.
I wonder, when the guys in Struer will notice, that a not-finished webpage is online 😴
koning
holland
Posts 4,220
koning replied on Sun, Aug 2 2015 8:17 PM
Or they let us think that we got something 😂
TWG
Posts 1,672
TWG replied on Mon, Aug 3 2015 6:59 AM
Millemissen:
It's just another sad and embarassing sign of Bang & Olufsens way down in quality, design, service...
But the Essence remotes are beautiful, even if their internals (rubber) are failing.
MaximL
Sydney, Australia
Posts 19
MaximL replied on Mon, Aug 3 2015 11:48 AM
Thanks for your updates on the Australian situation, elephant. I'm a long-time lurker who just signed up.
I made probably the mistake of buying a Beosound Essence MK I second-hand from the US recently (in transit), since it was only afterwards I started following these threads on the MK II.
Wondering if you have any specific comments on:
  • If the remotes for the MKII are exactly the same?
  • What the AUD cost of the MKII box will be?
  • If I would have any chance to 'upgrade' short of just buying a completely new box?
I suppose that if I'm not interested in multi-room in the near future and planned to plug the Essence in via an ethernet connection anyhow that there is actually next to no different between MKI and MKII?
carlito
Posts 239
carlito replied on Mon, Aug 3 2015 2:29 PM
Hi and welcome to Beoworld
Here a non exhasutive list of pro's from the MK2 version
  • Same price tag (at least here in Switzerland)
  • Essence "wheely" remote equal to MK1
  • Apple lossless capabilities
  • WISA on board (after major software release in September / October)
  • Deezer integration
What else?
carlito
Posts 239
carlito replied on Mon, Aug 3 2015 2:30 PM
double post - please delete
BeoMegaMan
Posts 601
carlito:
What else?
There is no WISA in the MKII.
Ah, you know... A little B&O here, a little there
linder
United States
Posts 983
linder replied on Mon, Aug 3 2015 9:03 PM
If the MRK2 does decode Apple Lossless, I might buy it.  However I would buy it only after the beta test of the app is finished.  Bang & Olufsen's software has always been a problem.  I was beginning to look elsewhere for a new system.
Deezer has not been available in the US.   B&O will have a real problem convincing people here about the benefits of Deezer.  I have been using Apple Music and like it.  All of my ripped music is Apple Lossless.
elephant
AU
Posts 8,219
elephant replied on Mon, Aug 3 2015 11:57 PM
MaximL:
I believe so
AUD946.00 -- although note MM's caution of how can that be if they are adding WISA
Not for me to say, but given the messages I had received from the dealer this year I doubt it
Possibly.
It may be that the Mark I will get a software upgrade whereas the Mark II has hardware and software.
So the Mark I will work, will be enjoyable, and may get some enhancements.
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Tue, Aug 4 2015 12:21 AM
BeoMegaMan:
I think we have conflicting rumours unless a sheep has whispered in your ear.
They absolutely should - even if costs a tad more, or produce a Transmitter 2 (or T-mini) that is just a simple stereo+sub system. IE the existing Transmitter cut in "half" with only a PL1 input (and a non-B&O input)
BeoNut since '75
BeoMegaMan
Posts 601
elephant:
They absolutely should - even if costs a tad more, or produce a Transmitter 2 (or T-mini) that is just a simple stereo+sub system. IE the existing Transmitter cut in "half" with only a PL1 input (and a non-B&O input) BeoNut since '75
No rumor. It doesn't have it.
vlohjr1
Posts 553
vlohjr1 replied on Tue, Aug 4 2015 7:16 AM
BeoMegaMan:
No rumor. It doesn't have it. Ah, you know... A little B&O here, a little there
I concur. My UK dealer confirmed it.
Page 3 of 6 (203 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
