Saw this Beogram 7000 from someone with good ratings but is so very cheap. Limited photos. No cartridge. There must be something I'm missing! I would have expected it to fetch £300 or more but only £50...that can't be right. What do you think? Should I go for it or is there something amiss? Ebay can induce suspiciousness not often seen in one on a day to day basis.
http://m.ebay.co.uk/itm/Bang-Olufsen-Beogram-7000-B-O-Plattenspieler-/151914964935?nav=SEARCH
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
leosgonewild:It's an auction. Not buy it now.
Yep, with 4 days to go, and as with most things on ebay, it's likely that 90% of the bidding will occur within the last few minutes of the auction.
Martin.
As leosgonewild says, I think this turntable is gonna land on +/- 300€.
Worth it? Well, it is quite expensive since what I can see, it is a MMC-4 cartridge. See if you can get the BeoGram 6500. Same machine but often is set in a lower price. And look for a MMC-2 or 1 cartridge.
//EA
Beo in white is my thing
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
What cartridges are compatible with this and where can I buy them please?
The cartridges that are compatible are the MMC cartridges. MMC1-MMC5. The MMC1 is very rare and good. The most common one is the MMC4.
I think there is only one manufacture of "new" cartridges for Beo. -> http://www.sound-smith.com/lookup/bo-cartridges/146
I would suggest looking on eBay.
