Beogram 7000 ebay seems too good to be true
seethroughyou
UK
Posts 999
seethroughyou Posted: Wed, Dec 16 2015 7:01 AM
Saw this Beogram 7000 from someone with good ratings but is so very cheap. Limited photos. No cartridge. There must be something I'm missing!  I would have expected it to fetch £300 or more but only £50...that can't be right. What do you think? Should I go for it or is there something amiss? Ebay can induce suspiciousness not often seen in one on a day to day basis.
 http://m.ebay.co.uk/itm/Bang-Olufsen-Beogram-7000-B-O-Plattenspieler-/151914964935?nav=SEARCH
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
leosgonewild
Helsinki, Finland
Posts 2,373
It's an auction. Not buy it now.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Dec 16 2015 5:05 PM
leosgonewild:
Yep, with 4 days to go, and as with most things on ebay, it's likely that 90% of the bidding will occur within the last few minutes of the auction.
Martin.
leosgonewild
Helsinki, Finland
Posts 2,373
My guess it will sell for +/- 300€
ErikVonAgnar
Posts 193
As leosgonewild says, I think this turntable is gonna land on +/- 300€.
Worth it? Well, it is quite expensive since what I can see, it is a MMC-4 cartridge.
See if you can get the BeoGram 6500. Same machine but often is set in a lower price. And look for a MMC-2 or 1 cartridge.Smile
//EA
Beo in white is my thingBig Smile
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
seethroughyou
UK
Posts 999
What cartridges are compatible with this and where can I buy them please?
seethroughyou
UK
Posts 999
ErikVonAgnar
Posts 193
The cartridges that are compatible are the MMC cartridges. MMC1-MMC5. The MMC1 is very rare and good. The most common one is the MMC4.
I think there is only one manufacture of "new" cartridges for Beo. -> http://www.sound-smith.com/lookup/bo-cartridges/146
I would suggest looking on eBay.
//EA
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
