What Are You Working On Now
This post has 1,308 Replies | 20 Followers
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Sun, Mar 3 2013 5:32 PM
Søren Mexico:
I hate that felt stuff in there.
Not to mention that there was glue all over the crossover so it was stuck to everything.
It would have taken forever and a lot of elbow grease to remove it all so I didnt bother.
Instead I cut out the old caps tight leaving the  wire leads behind. I then spooled the wire leads of the new caps around the old wire leads ,added flux,and laid the solder down thick.
Søren Mexico
Mexico City
Posts 6,411
The Dickster:
Søren Mexico:
My first crossovers I desoldered all the caps and then resoldered it all, now I just cut off the the old ones close to the board and solder the new ones to the old solder unions.
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Sun, Mar 3 2013 6:01 PM
I wasted a lot of time and money on fancy resistors and foil caps early on but I have since learned they dont really improve the sound as opposed to standard electros.
At least my ears cant tell any difference.
Pretty much the same has panned out recapping Beomasters. I am done shopping  the boutiques caps for the most part.
I like my RK Fuji's just fine
BO
Halmstad, Sweden
Posts 728
Refoaming some speakers.
//Bo.
A long list...
Søren Mexico
Mexico City
Posts 6,411
Bos00:
Looks more like a Bean canning factoryBig Smile, good special tools, and then enjoy the beans while you test the speakers.
Søren Mexico
Mexico City
Posts 6,411
The Dickster:
Same here, using Nichicon or Panasonic, will look for Fuji nex time.
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Just stopping by to say hello.
No projects whatsoever for a long time now -just been enjoying!
  • One B&o bottle opener
  • One fancy gun
beocool
Alankomaat
Posts 6,194
beocool replied on Sun, Mar 3 2013 7:20 PM
ɓʋɾɑɳɫɘɮ:
As much as I like this stuff I leave it to the professionals. Wink
Vähintään yhdeksänkymmentä prosenttia suomalainen!
Rich
Orlando, Florida, USA
Posts 2,598
Fully desoldered Beovox P30 drivers and crossover inductors, awaiting boutique capacitors and resistors.  :-P
Rich
Posts 2,598
Rich replied on Sun, Mar 3 2013 7:43 PM
beocool:
ɓʋɾɑɳɫɘɮ:
Me, too, now, except the loudspeakers.  They're easy.
Rich
Posts 2,598
Rich replied on Sun, Mar 3 2013 7:44 PM
ɓʋɾɑɳɫɘɮ:
Hello back.  WedThred on Sunday?
Søren Mexico
Mexico City
Posts 6,411
Rich:
Do you hear the difference with expensive caps. My hearing is shot, after many years in the print shops.
Ricardo
Moonbase 5
Posts 418
Søren Mexico:
Rich:
I know mines shot from all the sex, drugs and rock n roll played very loudly.
Here are my P30's all recapped, new fabric and hooked up to. you guessed it.  a Beomaster 2400 type 1 single chip 32 step volume control model. If you will notice I have mine at mid wall height or "ear level" mounted sideways angled to the rooms center.
DMacri
United States
Posts 881
DMacri replied on Sun, Mar 3 2013 10:05 PM
I noticed some increased cracking sound from the right C75 speaker in my link room (bathroom) recently. I feared damage to my woofer because it seemed to happen with each strong bass note, although I was not driving the very hard. I went right up to the speaker and could clearly hear a static sound and thought the worst. I checked the speaker connections and found they seemed fine. I was able to move the woofer without any undue sound, and it's the bottom one with the rubber surround, so all seemed well. I loosened the screws and the internal connections seemed fine.
Then I realized I installed the 2041 box myself, so what I'd I had a loose speaker wire at the box? I installed the box during one of the hottest, most humid days of summer, and I remember a high level of frustration making the connections. Did the "wire pull test" with my needle nose pliers and sure enough, the green wires were loose. Wait, that's an understatement, they were just barely in contact with each other and the terminal. I fixed it by cutting, stripping, and tinning the wires before pushing each one individually into the terminal strip and tightening the screw. Apparently, I tried to just get it done last time, and in my haste, only had a single strand make contact, which had since let go.
Do it right the first time and you won't have to redo it later. Anyway, now not only is the connection correct, but I swear the sound is better than ever. Especially the bass. Maybe one less thing to worry about.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Rich
Posts 2,598
Rich replied on Mon, Mar 4 2013 1:18 AM
Søren Mexico:
Rich:
S45-2s:  Martin's kit capacitors, left resistors alone, replaced damping material
S40s:  Used Solen capacitors, left resistors alone, replaced damping material
M70s:  Used Solen capacitors, replaced resistors, replaced damping material but went back to original damping material
C50s:  Used Solen capacitors, left everything else alone
All sound great.  I think the sound of the S45-2s is improved with the new damping material, but putting the original damping material back in the M70s made them sound better.  It's a matter of personal taste, probably.
I have never done a critical listening test between poly and electrolytic capacitors (new).  I can tell you that changing the capacitors on the S45-2s was the difference between a working speaker and a speaker "with a bad midrange."  Needing to fix that S45-2 led me to this site and the dreaded Beovirus.  But it wasn't until I refoamed my S40s that I was truly hooked.
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Mon, Mar 4 2013 2:14 AM
Rich:
Søren Mexico:
Rich:
Ok
I used Dayton Audio caps and resistors on one set of S45 and then standard electros without new resistors on another set of S45 both were the 3 way speaker. Couldnt tell a bit of difference between the two.
What I will say is that it really doesnt matter whether you use foil caps or electros or opt for new resistors. The benefits in improved sound quality after the 30 plus year old caps are replaced can be enormous. It is a win win situation no matter what choice of capacitor you make
I noticed a distinct improvement in overall clarity on the P30's once they were done. I have a 20 plus year old Cona to do next. I used NTE 100V Bipolar 4.7 .7.5 and 15 - not a single replacement cap was original spec
Søren Mexico
Mexico City
Posts 6,411
I dont think the calues of the caps are that important, 30 years ago a very good cap were + - 10 %, those originals were probably 20 %, so not getting the exact size is not that important. And if one find the org. sizes they are mostly expensive.
Rich
Posts 2,598
Rich replied on Fri, Mar 8 2013 12:45 AM
Finished the P30s Monday. Sounded pretty good in the 4000 system in the dining room, but not so great in the garage 1900 system with initial placement on the wall where S40s were. I will experiment with placement this weekend and post a picture or two. (Otherwise it didn't happen.)
Orava
Finland
Posts 991
Orava replied on Sat, Mar 9 2013 12:33 PM
Lazy? Me? Nooo.....
Actually I  found  quite pleasant to work this way, elements are steady and level all time.
Rich
Posts 2,598
File this under "Pictures Or It Didn't Happen":  Beovox P30 added to Beosystem 1900 in the garage.  Listened to two cassettes this morning:  Bonnie Raitt Nick of Time and Bruce Springsteen Born in the USA.  The P30s sound fine in their present location, so maybe the experimentation with placement will wait until another time.
Søren Mexico
Mexico City
Posts 6,411
Rich:
I think the wall you hang them on has to have a good sound reflection capability, the wall they are hanging on looks kind of soft and perforated, you should try on a hard wall, painted gypsum or concrete, I have my P45s against a concrete wall, and just moving them 2" away from the wall, flaws the sound.
Rich
Posts 2,598
Rich replied on Sat, Mar 9 2013 3:22 PM
Søren Mexico:
Rich:
There is exactly one place in the garage they can hang without rearranging the entire garage:  where they currently are.  Entire house is wood frame construction.
Ricardo
Moonbase 5
Posts 418
Orava:
Lazy? Me? Nooo.....
Plus you get to eat the Yogurt first and it is really good for you.
Orava
Finland
Posts 991
Orava replied on Sun, Mar 17 2013 12:51 PM
Inside tuning indicator....
And guess what! There is a loose magnet! Hmmm, little more challenging than speaker magnets...
It is not B&O but BM3000 family and BM5000 looks to have similar.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Mar 17 2013 12:56 PM
Well I for one have always failed at repairing galvanometers with loose magnets (typically, Revox and Uher). Good luck with this one !
Jacques
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Sun, Mar 17 2013 3:06 PM
Playing with string - check it out an AM radio antenna DIN. Something you dont see very often
Orava
Finland
Posts 991
Orava replied on Sun, Mar 17 2013 5:20 PM
chartz:
Decided to try without dismantling thing, centering (shimming:)) magnet and glueing.
BO
Halmstad, Sweden
Posts 728
Stuff in progress.Smile
//Bo.
A long list...
Rich
Posts 2,598
Rich replied on Sat, Mar 30 2013 7:41 PM
Replaced the idler tire of a "non-working" Nakamichi BX-300 cassette deck today.  Bought the deck for $50, got the idler tire for $10, spent an hour on her, and now she works quite well.  Definitely the best deck I own, but I'm looking for a BC9000 or BC8004!
Orava
Finland
Posts 991
Orava replied on Tue, Apr 2 2013 9:06 AM
Not nice...
Gentle moisturing...
Vacuuming with some adapters... (1200W and these are rated for 60W Surprise)  Slurps.
Well, allmost perfect. Would be better if I haven't try with a needle first.
Søren Hammer
Denmark
Posts 953
Whistle
Double decks. Double fun. Spring cleaning and recapping time!
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Evan
USA
Posts 3,621
Evan replied on Mon, Apr 22 2013 3:03 AM
BO:
Is that a Yamaha R-7 I spy on the shelf?!?
Beo4 'til I die!
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Apr 22 2013 10:10 AM
Evan:
BO:
Well quite a good guess but not right on. It's an RX-450 which i bought brand new in 1988. A quite good sounding receiver.
It does look quite similar to the R-7.
//Bo.
A long list...
Evan
USA
Posts 3,621
Evan replied on Mon, Apr 22 2013 3:42 PM
bos00:
//Bo BC9500, BG 9500, Beolab Penta II, Beovox Penta, BL 1000, BL 7000, BL 1000, Beo4, MCP 6500, . Beomaster 901, Beomaster 3000, Beotalk 1100, Beotalk 1200, Beotalk 4000, Beocom 5000. Beovox 1500, Beovox 3000, Beocenter 2300, Beocenter 4000, Beogram RX2, Beosound Ouverture.
Darn. I had a feeling I would be wrong... There are so so many Yams from that era.
My first receiver was my father's R-7, also from that age.
I don't doubt for a second that it sounds anything other than great :-)
Beo4 'til I die!
Evan
USA
Posts 3,621
Evan replied on Wed, Apr 24 2013 6:45 PM
Exporting this solid model to a 3D printer shortly... Anyone wanna guess what it is?
Beo4 'til I die!
Menahem Yachad
Jerusalem, Israel
Posts 1,249
That's exactly what I need - about a dozen of them - end-stoppers for the metal curtain rods! Very nice styling. Laughing
Actually I have another project idea, which could be sold as spare parts for a certain BeoMaster - l'll be in touch!
Menahem
tamtapir
Örebro, Sweden
Posts 521
tamtapir replied on Wed, Apr 24 2013 7:33 PM
Menahem Yachad:
Menahem
The plastic cd clamper for Beocenter 9000? I buy one! Or seven.
Evan
USA
Posts 3,621
Evan replied on Wed, Apr 24 2013 9:18 PM
Menahem Yachad:
Menahem
LaughingLaughingLaughing
Well if your hanging curtains you might be interested in this new and improved buttressed version! Stick out tongue
Looking forward to your next challenge!!!!
Beo4 'til I die!
Orava
Finland
Posts 991
Orava replied on Thu, Apr 25 2013 6:47 AM
tamtapir:
Whole winter I were thinking to do it, but.... Havent get to it yet.
Evan
USA
Posts 3,621
Evan replied on Thu, Apr 25 2013 1:22 PM
tamtapir:
If you can get me an accurate drawing or send me an original part I can try and reproduce it.
Beo4 'til I die!
Page 17 of 33 (1309 items) « First ... < Previous 15 16 17 18 19 Next > ... Last » | RSS
DigiCert Secured Site Seal
