Beoremote One software
This post has 15 Replies | 4 Followers
PhilLondon
London
Posts 3,637
PhilLondon Posted: Sun, Apr 24 2016 3:27 PM
Anyone knows how to check the software version of the Beoremote One?
Beoworld app with direct photo upload and emoticons.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Press and Hold the OK button for at least 5 seconds, then while still holding the OK button pressed, press and hold the MENU button for at least 5 seconds. So you are still holding down both buttons, then press LIST and the Service Menu will be displayed.
Beware it times out quite quickly and you may need to do the above commands more than once.
Regards Keith....
mawheele
Posts 258
mawheele replied on Mon, Apr 25 2016 10:15 AM
Interesting. How do you update this remote or does it get updated automatically from the TV when that also gets flashed?
Keith Saunders
Posts 5,495
mawheele:
It does not get updated from the TV and has only ever had one update and that was to remove the OPTION menu
Regards Keith....
PhilLondon
London
Posts 3,637
PhilLondon replied on Mon, Apr 25 2016 11:28 AM
Thanks, After trying quite a few times, I managed to get to the menu.
My FW is 1.0.1452, I suppose it's the earlier one as I have an Option menu.
As I mentioned before there is a bug in that firmware... the LIGHT > LAMP button does send the wrong IR code, so I can't control my lamps individually.
No sure if they have fixed that in the newer software...
Keith, do you have a Beoremote One with the updated firmware??
Keith Saunders
Posts 5,495
Unless you were one of the very few who had the first units to be made, then the version will be 1.0.1452
Regards Keith....
PhilLondon
London
Posts 3,637
... so they've been aware of this bug for months and have not worked on a fix :-( ...
Chris Hassell
London
Posts 396
Keith Saunders:
Regards Keith....
Hi Keith, are there any other hidden menus/settings on the BeoremoteOne that you know of?
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Millemissen
Flensborg, Denmark
Posts 14,680
Any news there?
How is the update (if any) done?
In the factory or could it be done by a B&O dealer/technician?
By the way - this thread ought to be moved to the new subforum as well.
Keith Saunders
Posts 5,495
Millemissen:
I have moved this thread to the new forum..
Regards Keith....
Keith Saunders
Posts 5,495
PhilLondon:
The lamp issue was resolved in May 2016 and all BeoRemote One produced after 2nd May 2016 have version 1.1.1549 software which includes the fix.
This updated version also fixes a few other issues including:-
  1. Cannot programme LC1 and LC2
  2. LAMP + Digit turns on light scenario with multiple lamps instead of just a single lamp
  3. No lamp increase or decrease light function on BeoRemote One
  4. No RECORD for BeoSound 4 A.Mem recording
  5. BeoRemote One - List button reacts very slowly
  6. Incorrect Dutch translation of "join" in the Netherlands
Unlike the Bluetooth version, the unit can only be updated with a board replacement part number 2775052
Regards Keith....
jans
Belgium
Posts 394
jans replied on Tue, Jan 31 2017 7:07 PM
Keith
How do check the software version of a Beo Remote One BT? Is it the same sequence as you described below?
Jan
Keith Saunders
Posts 5,495
jans:
Keith
Jan
Yes, it's the same except the MENU button on the BT version is shown with a house shaped symbol.
Regards Keith....
Beozip
Posts 368
Beozip replied on Wed, Jul 5 2017 1:12 PM
Hi Keith
please can you make a picture from the new/latest Softwarescreen of the BR 1 (no BT Version) and shows us here?
BeoCare do not know what I mean. Thank you Smile
best regards
lawrencejmcook
Posts 742
To those (like me) who did not know all this was possible, I paired my BeoRemote One BT with my BeoSound Essence MkII. When I pressed the stand-by button on the remote to turn off the BeoSound, the remote’s screen said “Updating application”.
After the download completed (very slowly!), the remote rebooted.
After reboot, the remote’s screen said “Updating database”.
After the download completed (slightly faster), the remote rebooted.
After reboot, it showed a low battery indicator, prompting me to replace them!! 😄
I had no idea that you could update the remote from a BeoSound, so I thought I would add the info and details of my experience here.
Lawrence
BOBrb
Posts 88
BOBrb replied on Sun, Nov 3 2019 12:52 PM
That's the same with the BV 14-55.
Page 1 of 1 (16 items) | RSS
