Beoworld app with direct photo upload and emoticons.
Press and Hold the OK button for at least 5 seconds, then while still holding the OK button pressed, press and hold the MENU button for at least 5 seconds. So you are still holding down both buttons, then press LIST and the Service Menu will be displayed.
Beware it times out quite quickly and you may need to do the above commands more than once.
Regards Keith....
Interesting. How do you update this remote or does it get updated automatically from the TV when that also gets flashed?
mawheele: Interesting. How do you update this remote or does it get updated automatically from the TV when that also gets flashed?
It does not get updated from the TV and has only ever had one update and that was to remove the OPTION menu
Thanks, After trying quite a few times, I managed to get to the menu.
My FW is 1.0.1452, I suppose it's the earlier one as I have an Option menu.
As I mentioned before there is a bug in that firmware... the LIGHT > LAMP button does send the wrong IR code, so I can't control my lamps individually.
No sure if they have fixed that in the newer software...
Keith, do you have a Beoremote One with the updated firmware??
Unless you were one of the very few who had the first units to be made, then the version will be 1.0.1452
... so they've been aware of this bug for months and have not worked on a fix :-( ...
Keith Saunders:Press and Hold the OK button for at least 5 seconds, then while still holding the OK button pressed, press and hold the MENU button for at least 5 seconds. So you are still holding down both buttons, then press LIST and the Service Menu will be displayed. Beware it times out quite quickly and you may need to do the above commands more than once. Regards Keith....
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Any news there?
How is the update (if any) done?
In the factory or could it be done by a B&O dealer/technician?
By the way - this thread ought to be moved to the new subforum as well.
Millemissen: By the way - this thread ought to be moved to the new subforum as well.
I have moved this thread to the new forum..
PhilLondon: As I mentioned before there is a bug in that firmware... the LIGHT > LAMP button does send the wrong IR code, so I can't control my lamps individually.
The lamp issue was resolved in May 2016 and all BeoRemote One produced after 2nd May 2016 have version 1.1.1549 software which includes the fix.
This updated version also fixes a few other issues including:-
Unlike the Bluetooth version, the unit can only be updated with a board replacement part number 2775052
jans:Keith How do check the software version of a Beo Remote One BT? Is it the same sequence as you described below? Jan
Jan
Yes, it's the same except the MENU button on the BT version is shown with a house shaped symbol.
Hi Keith
please can you make a picture from the new/latest Softwarescreen of the BR 1 (no BT Version) and shows us here?
BeoCare do not know what I mean. Thank you
best regards
That's the same with the BV 14-55.
