New Beosound
This post has 104 Replies | 1 Follower
Millemissen
Flensborg, Denmark
Posts 14,680
Think of NL as the modern ML - and of WiSA as wireless PowerLink (WPL)
steve1977
Posts 911
steve1977 replied on Fri, Jul 15 2016 9:08 AM
Millemissen:
I had never set up a multi-room with ML. However, I thought it was possible via ML to have a pair of BL in a separate room (e.g., play music from a BV7 to a pair of speakers in room A and also in room B. That's what I am missing now as BLs do not support NL unless I buy an Essence for each room that I would like to add. Or do I glorify the old days and this was not possible via ML either?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Jul 15 2016 9:15 AM
steve1977:
But to do so you had to install ML cables to the other room, connect the ML to f.e. a Beolink Active speakerkit. The BL are connected to this kit with PL-cables
the Essence in your example is the active speakerkit (or you could use the BL NL/ML converter as Beolink Active). The use of the Essence has advantages. It is a complete system which can be used locally but can be "joined" by other NL devices in other rooms
steve1977:
You do. NL has more possibilities than ML.
Millemissen
Flensborg, Denmark
Posts 14,680
With ML you could (and still can) distribute sound from a central Audio or Video master to other (Slave/Link) rooms.
These rooms can participate or not - only one source at the time can be distributed.
A set of BL's isn't enough, though  - you need (along with the ML-cabling) an Active Link box.
Today with NL you can distribute different sources (at rhe same time) to and from the NL devices.
Think of an Essence as an Active Link box with its own sources built-in from which you also can distribute sound to other NL components.
There is no Master and Slave in a NL setup like with the ML structure - this makes NL (and NL products) far more flexible than the old ML ( and ML products).
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Jul 15 2016 9:37 AM
Millemissen:
Quite confusing! The Essence is a complete system on it's own.
steve1977
Posts 911
steve1977 replied on Fri, Jul 15 2016 10:55 AM
Thanks for your replies, this all makes sense.
It is a pity that the Essence cannot be easily connected to BV7 as it lacks ML. I have seen the work-around buying an expensive Almando system or using line-in, but no longer having the chance to use speakers without using the Beo4.
I assume it is less likely that we will see ML with an MK3 of the Essence?
paolomariano
Posts 639
Hi! Smile
Don't get me wrong, but don't you all think you are off topic?! Wink
Millemissen
Flensborg, Denmark
Posts 14,680
paolomariano:
Hi! Smile
Don't be offended, but don't you all think you are off topic?!
You're right, of course - and wrong too.
This is about a/the new BeoSound.
Since we don't know much, there is not much to say/write about.
A discussion about what 'people' expect from a modern BS or explaining the differences between ML and NL can't do any harm imo.
P.S. If you have any news about the coming BeoSounds, feel free to interrupt ;-)
elephant
AU
Posts 8,219
elephant replied on Fri, Jul 15 2016 1:01 PM
steve1977:
@immediately preceding post: yes we seem to be off topic yet it's important to understand the past to predict the future.
In the MCL world (pre-ML) I had remote passive speakers governed by a simple B&O switch.
In the ML world we had three options.
1/ Integrated the previous generation's passive speakers via ML and a passive controller box.
2/ Integrating active speakers via an active controller box.
3/ Attaching integrated speakers with built in controller.
The 3rd option example is the BeoLab 3500.
Today's equivalent in NL is the BL35.
In today's world #2 is the essence.
And finally today's #1 is the NL/ML gateway ?
So the new BeoSounds will hopefully be more examples of variations on #3 ... and perhaps the equivalent of a mark III essence ?
BeoNut since '75
steve1977
Posts 911
steve1977 replied on Fri, Jul 15 2016 1:30 PM
Thanks, very helpful. Learnt a lot about ML and NL.
My world would be great if the essence had ML to integrate old and new world. the NL/ML adapter somehow does it, but cannot be controlled by the essence knob (or other join button) and has no integrated sound system.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Jul 15 2016 2:24 PM
steve1977:
the NL/ML converter is the in-between the old world (ML) and the new world (NL).
f.e. I have two NL/ML converters to integrate a BS3000 and a BS9000 in a complete NL system (several components).
The opposite is also possible: integrate a ML tv-set with the new NL audio (Moment, Essence mkII, A6, A9, the new ones)
there is a IR-eye available for the NL/ML converter with a join button
steve1977
Posts 911
steve1977 replied on Fri, Jul 15 2016 3:09 PM
thanks. possible to connect essence knob via IR eye or Bluetooth? or just for beo4?
Millemissen
Flensborg, Denmark
Posts 14,680
steve1977:
If you mean the converter?
The ir-eye is for Beo4/BeoremoteOne - no control there via bluetooth/Essence-knob.
And Join-in via touching the ir-eye, of course.
steve1977
Posts 911
steve1977 replied on Sat, Jul 16 2016 7:54 PM
Thanks. What do you mean by "touching the IR eye"?
Millemissen
Flensborg, Denmark
Posts 14,680
The eye has a 'join-button' - have a look in this guide:
http://www.bang-olufsen.com/da/customer-service/product-support/accessories/beolink/beolink-converter
steve1977
Posts 911
steve1977 replied on Sat, Jul 16 2016 8:46 PM
Wow, now I got it. The IR eye is basically the the equivalent of the Essence knob. Not as nice and wired, but basically same functionality.
Does anyone the cable length when buying at B&O? Assume best to buy directly from a dealer incl. cable, eye and wall holder?
Millemissen
Flensborg, Denmark
Posts 14,680
Have a look at the pic here:
http://archivedforum2.beoworld.org/forums/p/16023/139217.aspx
Steve at Sounds Heavenly might also be able to provide the cable lenght you would wish for.
steve1977
Posts 911
steve1977 replied on Sun, Jul 17 2016 10:35 AM
Millemissen:
Thanks. Not fully clear to me from the photo, but it appears that all is included and even states a 10m cable is included (which is enough for my purpose). Let me go and see my dealer on Monday. This is really great news!
Assume "join" and "play" can be programmed through the app what is preferred source to play and also what other device to join (e.g., device 1 plays source a and device 2 plays source b).
steve1977
Posts 911
Millemissen:
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 17 2016 11:07 AM
steve1977:
Assume
Never ass=u+me.
BeoNut since '75
steve1977
Posts 911
steve1977 replied on Sun, Jul 17 2016 11:17 AM
elephant:
steve1977:
Assume
Never ass=u+me.
Mmh, so this will not work? So. how does "play" decides what source to play and "join decides what other device to join?
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Jul 17 2016 4:30 PM
steve1977:
You configure what source PLAY shall trigger.
When you press Join, you get any source that currently play over the network NL or ML.
If there are more sources playing over NL, you can flip to the next by pressing Join again.
steve1977
Posts 911
steve1977 replied on Tue, Jul 19 2016 8:45 AM
Thanks, perfect. This is how it should be.
benoit
France
Posts 646
benoit replied on Thu, Aug 11 2016 7:20 AM
Do we have fresh news about these new Beosound 1 and 2? The TVs have been shown... Any leaked photos of the sound systems?Whistle
The cable workshop, Leics, UK
Posts 2,165
Millemissen:
Hi Millemissen,
Sorry for the slow reply, yes I can build this cable in any length required:-
http://soundsheavenly.com/bang-olufsen/143-ir-infared-remote-cable-for-beosound-essence-wiring-chart-included.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 3 of 3 (105 items) < Previous 1 2 3 | RSS
