4K and the Avant
This post has 45 Replies | 2 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
jvdl:
The UBD-K8500 is a good player, not much options but OK. I have it connected to the Avant 85
Thanks Smile
Is it quick to load a disc ?
jvdl
Netherlands
Posts 129
jvdl replied on Fri, Jul 29 2016 11:28 PM
To load a disk it is acceptable and quite fast. Quality of the 4K is realy good.
Aussie Michael
Melbourne, AU
Posts 3,730
So last night I purchased the Samsung 4K Blu Ray player because there was a special on at Myer where it was $429. The Panasonic is going to be double the price and I'm not sure of the feature set is going to be doubly good.
Before j purchased I went to the B&O store here to confirm if it would work, they said they have no reason why it wouldn't
It did work however when you put a disc in and it loads there is a splash screen that tells you that the connected television is not a HDR television and to press ok to continue. A little bit odd.
It loads very quick and playback is fast.
I wonder if I change my HDMI cable if I won't get that message ?
riverstyx
SouthWest UK
Posts 938
No need to change any cables. The message is correct as the BV doesn't support HDR (high dynamic range) and likely just means you need to change the default hdmi format in one of the menus of the player so this message doesn't appear every time.
Martin.
vlohjr1
Posts 553
vlohjr1 replied on Wed, Aug 3 2016 10:36 AM
Aussie Michael:
How was the picture quality? Do you see the need for HDR for a bv?
Aussie Michael
Melbourne, AU
Posts 3,730
The picture quality was nice. It wasn't that much better than blu Ray. I tried a 4K disk Superman.
The sound was astronomical- wayyyy better than blu Ray.
Maybe other disks are better than Superman.
As soon as I tried to default the picture at 2160 it juddered a bit in a scene. So I changed it back to auto and it was fine.
Page 2 of 2 (46 items) < Previous 1 2 | RSS
