Hi Thomas,
Thanks for the info.
Is it also possible to connect to cx50 to one DSP and amp?
E.g. by connecting the second cx50 with a cable to the first.
Even better would if the other speaker is not connected it would play mono and if they are two connected it would play stereo. Is that possible?
Kind regards,
Ton
tkl: Hi Thomas, Thanks for the info. Is it also possible to connect to cx50 to one DSP and amp? E.g. by connecting the second cx50 with a cable to the first. Even better would if the other speaker is not connected it would play mono and if they are two connected it would play stereo. Is that possible? Kind regards, Ton
Hi Ton and thanks for your question!
Yes, this is totally possible. If you have two CX50s connected to one BeoCreate 4-Channel Amplifier, you can activate the stereo mode, and then use mono for one. This needs to be done manually because the DSP doesn't really know if speakers are connected, but it's very easy to do – just a few taps/clicks in the setup tool.
Best,
Tuomas
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Where can I find more info about the setup tool?
And which players are supported?
Are there any requirements for the players?
tkl: Where can I find more info about the setup tool? And which players are supported? Are there any requirements for the players? Kind regards, Ton
The setup tool is web-based and located at http://www.bang-olufsen.com/recreate/setup/. When the necessary software is running on the Raspberry Pi, the setup tool can connect to it over the local network and get you through setting up the BeoCreate 4-Channel Amplifier. It works directly in the browser and doesn't need to be downloaded or installed.
From the start, the available sources are Bluetooth, Toslink, AirPlay 1 and Spotify Connect, so there's a wide variety of devices you can use it with. Note that there's no BeoLink (NL) integration – it's a standalone product at the moment. Of course, as the software for BeoCreate is open-source, everyone is welcome to dig in and experiment.
There's documentation of some of the software on HiFiBerry website: https://www.hifiberry.com/beocreate/beocreate-doc/
And of course I'm here to answer any questions you may have about it.
tph:Note that there's no BeoLink (NL) integration – it's a standalone product at the moment. Of course, as the software for BeoCreate is open-source, everyone is welcome to dig in and experiment.
Hi tph,
Are you working on NL integration, or is it something we must not expect too much? (I understand that bringing NL compatibility while working open source is a potential threat to B&O as it will allow people to create (no pun intended) speakers that could cannibalize the NL range...)
diisign.com
mbee: Hi tph, Are you working on NL integration, or is it something we must not expect too much? (I understand that bringing NL compatibility while working open source is a potential threat to B&O as it will allow people to create (no pun intended) speakers that could cannibalize the NL range...)
Hi mbee,
at this point I'll say that we're looking into it, but I wouldn't hold my breath (at least not yet). We will keep all of you posted about this and any other new features
The Bang & Olufsen create 4 channel amplifier is already available:
https://www.hifiberry.com/shop/beocreate/beocreate-4-channel-amplifier/Very nice idea!
How much heat does the unit produce?
I mounted an amplifier inside a cx100 together with a Chromecast, and the amp produced so much heat that the Chromecast became unreliable.
Hi
Go ask your questions directly at HifiBerry site.
Their technician Daniel is very fast with answers
I ask a lot regarding Beocreate 4 as it's running with Rasperry which I know absolute nothing about.Got all kind of questions answered fast and informative.Nice experience
/Leif
leogoeswild: I mounted an amplifier inside a cx100 together with a Chromecast, and the amp produced so much heat that the Chromecast became unreliable.
Which Amp ?
I am doing the very same thing using an LM3886 mounted directly to the bottom of the aluminium chassis works like a charm!
It gets warm, but not hot,- there is no need to take the supply voltage to the maximum!
The Cromecast needs to be on the outside in order for the antennas to work properly, NOT like the BeoCreate solution where its buried deep inside an aluminium box behind a massive ferrite core...
I really like this idea, upgrading and adding modern features over replacement.
I'm looking at ways of adding BT and or WiFi to my system, not sure this is the right thing, but the website does say something about it being the first product. I fascinated to find out what else they might come up with.
leogoeswild: How much heat does the unit produce? I mounted an amplifier inside a cx100 together with a Chromecast, and the amp produced so much heat that the Chromecast became unreliable.
Hi Leo,
the boards do get pretty warm, but in our tests inside various speakers (RL6000, RL2000, CX-series) this has never been an issue. It's built to handle it with grace.
kai:Looking at the website can the board run two pairs of speakers In different rooms and have Bluetooth on one and say Spotify on the other?
MrRoast:I like the idea but it’s a shame that to achieve stereo the speakers have to be physically tethered - surely there must be a way to do this programmatically?
Does it support DLNA, too or is this planned?
It just happens to be that I refoamed a pair of CX100's for myself last week. Just for testing purposes and with the idea to remove the S75's
So, to get some space back. Among all the stuff I have several RPI3's also laying around here.
So I printed the bracket and cap.
I'm just curious whether the investment will result in a decent sound in comparison with for instance a Beoplay M5.
At least it will give me some fun in building, configuring and testing.
And the bracket.
MrRoast:Thanks for the reply Tuomas, I’d considered the Airplay solution you mentioned but that would just be a pair of muxed down L/R signals not stereo if I understand correctly.
In the setup tool you can choose which channels the loudspeaker plays. With CX50 you have stereo (for connecting two to the same amplifier), L, R or mono options. CX100 gives you L, R or mono options. I think CX100 defaults to mono, but as said, this can be easily changed.
Received yesterday the nice looking packages.
Looks promising.
Pic 2.
Let's create.
Hello,I’m very interested with the beocrate board to create 4 independant CX100 speakers.I need to put one CX100 per corner of my room but the official way solution with 2 speakers connected via toslink is not possible. Totally wireless speaker allow more possibility.As sonos do, do you think it’s possible to configure a channel per speaker in beocrate app ? Is it preferable to use roon ?Many thanks for your answer.
Hello there,
I am sooo waiting for a solution to upgrade Pentas as well, although connecting 9 speakers may be a bit of a challenge if you want to get rid of the 2 passive filter boards..
Has anyone built the Beocreate CX100? I cant find a single video of a finished product. I wonder how they sound compared to the original.
I'm still looking for a black pair in good condition here in Germany...
This guys is the only one I know of that done it https://www.instagram.com/p/BfqLujkHdLq/Might be some other testimonies on the HiFiBerry forum.
Note that this was done before the CX100 profile was finalized, still using a modified CX50 profile.
While not a comparison to the original, he thinks it sounds better (with just one speaker) than his Beosound 1.
Beoplay A2Beoplay EarsetBeoplay H6 (Gen 2)Beoplay S3 (pair)Beoplay S8Beovox CX50 (2 pairs)Beovox RL 6000
Hmm, is the BeoCreate only for making a single speaker? Is there a setup for making it a wireless stereo pair?
leosgonewild: Hmm, is the BeoCreate only for making a single speaker? Is there a setup for making it a wireless stereo pair?
No options for wireless stereo right now, unfortunately, and I do not know if this will be possible. We have to play with the Raspberry Pi hardware, and its wireless capabilities aren't as extensive as those in our multiroom speakers.
The best we can offer for CX 50 and CX 100 right now are guides for wired stereo.
It runs Spotify Connect, right? Shouldn`t this be possible to solve by grouping the speakers from the Google Home app? That is what I have done with my Pentas.
leosgonewild: It runs Spotify Connect, right? Shouldn`t this be possible to solve by grouping the speakers from the Google Home app? That is what I have done with my Pentas.
Speaker grouping via Google Home requires Chromecast built-in, and Google have not open-sourced that. Spotify Connect, which we do have, is a different thing entirely.
Is the optical input on the board accesible from outside when mounted in the CX100?
leosgonewild: Is the optical input on the board accesible from outside when mounted in the CX100?
If you follow the current guides, then no – the only connection for power (and mini-XLR in the stereo guide). To have Toslink accessible you have to drill holes for it and seal them tightly, and the whole package of electronics probably needs to mount on the back plate.
Anyone is obviously welcome to do this and we encourage experimentation, but in the guides so far we've tried to modify the original loudspeaker as little as possible from the outside.
Ok, thanks for the info :)
Still the amplifiers laying here with the (reconed) CX100's. To busy to finish at the moment...
I think the needed 3D parts are an obstacle for most persons who wants to build.
I can provide them if someone needs them.
Beobuddy: I think the needed 3D parts are an obstacle for most persons who wants to build.
I see what you're saying. It's getting easier all the time to find places where 3D prints can be made, though. For example, some libraries have them. But the parts are also available for purchase from HiFiBerry for this reason.
IMO that was one of the easier parts — just went to 3D Hubs, found a guy in Berlin, explained what I was doing and he sent me the parts.
Soldering the mini XLR connectors and wires (without any soldering experience) was my biggest hurdle. Just finding all the components, and the damn 4-core wire was also difficult.
Now you can buy all this from HiFiBerry, definitelly doing that with my RL 6000
Currently working on my BeoCreate system.
Like many others on the HiFiBerry Community, I was struggling to just get it configured via the browser and BeoCreate image. I went out to buy a mouse and keyboard yesterday and connected it to the nearest thing I had to a monitor, my bedroom BV8. I went through the process of giving the Rpi a normal Raspbian image and started manually adding all the files from BeoCreate pieces.
Today has been a rainy, dreary day in Cologne so I have spent my morning working on it. Really glad to share that I successfully streamed from Apple Music on my iPhone X to the BeoCreate+Rpi via Shairplay. Volume control doesn't work right now but I'm making small bits of progress!
Cannot wait to really dive into Sigma Studio and build the DSP for my project and learn more.
Beo4 'til I die!
Evan: Currently working on my BeoCreate system. Like many others on the HiFiBerry Community, I was struggling to just get it configured via the browser and BeoCreate image. I went out to buy a mouse and keyboard yesterday and connected it to the nearest thing I had to a monitor, my bedroom BV8. I went through the process of giving the Rpi a normal Raspbian image and started manually adding all the files from BeoCreate pieces.
Sorry for the troubles – good to see your system up and running!
I'd like to take this moment to give an update on what's going on with BeoCreate:
We are very aware of the troubles with the current software setup experience. It was originally created as a quick, temporary solution, but we've had to use it for a lot longer than we would've liked. It's very fragile (as you've seen) and not very easy to maintain.
I'm working on replacing it with something new, called BeoCreate 2. It's built from the ground up to be rock-solid, modular and future-proof (there are some exciting features we want to add later on). BeoCreate 2 is still some ways out, but I hope to have an early version out for testing sometime during the spring.
Because I don't have enough hands to fix the current setup experience and work on BeoCreate 2 at the same time, I'm focusing on the latter – and I'm positive it'll be worth it. Despite this, if you have any questions I can help with, just let me know and I'll do my best to answer them.
Thanks for the update, Tuomas. I read your similar comments on HiFiBerry and I'm looking forward to the update.
I started my project not intending to use any of the pre-made guides (CX/RL/etc) so I knew I was going to have to go into the more DIY path and eventually break away from the pre-made configurations.
If you have any tips on re-connecting the TCP link for Sigma Studio I am all ears. I tested it yesterday evening and successfully wrote a DSP profile OTA. However today it isn't working. I assume its because I haven't reactivated something on the Rpi after one of the many reboots.
Between that and the source (itunes or iPhone) volume control as I mentioned above, those are the two things I need to iron out.
Thanks,Evan
