A9 Keyring and LC2 hack ideas
This post has 4 Replies | 3 Followers
badlt762
Posts 2
badlt762 Posted: Tue, Dec 13 2016 11:53 AM
Dear Forum
I'm considering using a set of A9 keyrings as garage door opener remotes.
I've searched the net, but with no luck.
I'm contemplating this setup:
  1. A9
  2. LC2
  3. Some kind of relay
The A9 would trigger the LC2, which in turn would flip a relay and short circuit the terminals for the garage door opener (it does not require any additional voltage input)
My worry is, that I need to have 230v powering the LC2, the output current of the LC2 is also 230V - so a bad mix of voltage not to be fed to the opener.
What relay/device would I need?
Any input is highly welcome.
leosgonewild
Helsinki, Finland
Posts 2,373
As cool as it seems, anyone with a B&O remote can open your garage door.
badlt762
Posts 2
badlt762 replied on Wed, Dec 14 2016 8:07 AM
Damn... I hadn't thought of that....Thanks!
Will can the idea then.
TWG
Posts 1,672
TWG replied on Thu, Dec 15 2016 10:37 AM
and YOU will switch everybodys B&O lights when you reach for your car... might be a funny neighbourhood ;-)
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Dec 15 2016 11:13 AM
Funny  idea!
Remimds me of this:  https://www.youtube.com/watch?v=_CQA3X-qNgA
But about the trigger. You need a "trigger". When you switch on a light with the LC2, it stays on. So , any form of electronics behind the LC2 is needed.
And it only opens the door. WHat about closing? What distance can the A9-LC2 handle?
Page 1 of 1 (5 items) | RSS
