Dear Forum
I'm considering using a set of A9 keyrings as garage door opener remotes.
I've searched the net, but with no luck.I'm contemplating this setup:
The A9 would trigger the LC2, which in turn would flip a relay and short circuit the terminals for the garage door opener (it does not require any additional voltage input)My worry is, that I need to have 230v powering the LC2, the output current of the LC2 is also 230V - so a bad mix of voltage not to be fed to the opener.
What relay/device would I need?
Any input is highly welcome.
Damn... I hadn't thought of that....Thanks!Will can the idea then.
and YOU will switch everybodys B&O lights when you reach for your car... might be a funny neighbourhood ;-)
Funny idea!
Remimds me of this: https://www.youtube.com/watch?v=_CQA3X-qNgA
But about the trigger. You need a "trigger". When you switch on a light with the LC2, it stays on. So , any form of electronics behind the LC2 is needed.
And it only opens the door. WHat about closing? What distance can the A9-LC2 handle?
