Flash your B&O - new thread!
This post has 5,642 Replies | 42 Followers
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Jul 8 2016 5:41 PM
@razlaw:
Very sorry to hear about your wife, can fully understand how you feel about the Aston model. My wife is still with me, and I still have the first present she ever gave me, a framed picture, hanging on the wall and always will. First presents are filled with memories and emotion.
As for the 3000, it's such a stunning looking piece still, and so iconic, that it'd be a shame not to have it on display, especially since it's wired into the setup and functional. Perhaps the wall near the 5, or on the cabinet with the car in front of or beside it?
You have a wonderful setup or rather setups. Very tastefully done and highlights the beauty of B&O.
Jeff
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jul 8 2016 7:44 PM
Jeff:
Agree,
Should look great on the cabinet!
badgersurf
Posts 539
If you try on the cabinet then it it does not work it's easier to move than fixing to the wall.
Razlaw
Posts 4,345
Razlaw replied on Fri, Jul 8 2016 10:14 PM
Jeff:
@razlaw:
Jeff
Beovirus victim, it's gotten to be too much to list!
Thank you so very much.
Razlaw
Posts 4,345
Razlaw replied on Sat, Jul 9 2016 2:23 AM
Razlaw
Posts 4,345
Razlaw replied on Sat, Jul 9 2016 2:24 AM
elephant
AU
Posts 8,219
I vote 3000 on its stand; and will confer with the design authority for her vote.
Ass expected ... she overruled my response ๐Ÿ˜Š
BeoNut since '75
Razlaw
Posts 4,345
Razlaw replied on Sat, Jul 9 2016 5:07 AM
elephant:
Ass expected ... she overruled my response ๐Ÿ˜Š BeoNut since '75
Thanks for both opinions!
I am tending to agree with you....the stand.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jul 9 2016 6:43 AM
Man, tough call...both look good. Using the stand does put both sources near each other, the BS5 and the 3000 and the wall mounted remote. So, I'd probably go for the stand. And let's you put the car back in pride of place.
Jeff
TWG
Posts 1,672
TWG replied on Sat, Jul 9 2016 6:48 AM
Sorry, to hear about your wife, Razlaw!
Why don't try best of both worlds?:
1.) Put the 3000 on the cabinet, as far to the wall as possible and the little gift in front of it?
2.) Put the 3000 on the cabinet and install a minimalistic super small shelf on the wall to just hold the car. I would place it on the wall above the TV.
3.) 3000 on the cabinet and the car mounted with small invisible ankles on the wall. You can use small enough ankles that can be nearly invisble behind the car: https://www.cwmeyer.de/tradepro/shop/artikel/gross/HE180-010421.jpg
CB
> You are Here <
Posts 1,762
CB replied on Sat, Jul 9 2016 8:03 AM
On the cabinet is the obvious place for me.
If under the BS5, the doors of the 3000 will open each time you're going to use the BS5... not very pleasant.
Beautiful colour and setup anyway Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Looks much miore 'integrated' with the tv standing on the cabinet.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sat, Jul 9 2016 8:17 AM
BS 3000 on the cabinet with wee Aston in front of it or in another nice place.
The stand is nice but too much round stands on your floor for my taste (tv, speakers x2, BS3000) and the doors will open for the use of Essence or BS5.
Razlaw
Posts 4,345
Razlaw replied on Sat, Jul 9 2016 3:16 PM
Thank you all for all of the comments and suggestions. I think I will place it on the cabinet.  That is where it was originally, in our former home as when we purchased the 3000 we did not initially buy the stand for it.
I had the 3000 on the stand  for years, but the Beosound 5 was on top of the cabinet. The Beosound 5 was too low to use comfortably while on the cabinet which is why I moved it to the wall. It also allowed for the cables to be hidden in the wall and the Beomaster 5 to be hidden in my basement. I had the 3000 on the stand under the 5 briefly. I disconnected it as it did not function well with the Beosound 5 being the audio master and I wanted access to Spotify. However now with the Essence I do not need to have Spotify on the Beosound 5 so I can once again have the 3000 as the audio master.
Placing it on the cabinet simplifies cable management as the surge protector and masterliness junction box are in the cabinet and the hole in the wall for the cable to the Essence is just behind the TV.  With the 3000 on the stand, I need to run a Masterlink cable from the 3000, around the corner behind the BL1 and over to the cabinet, as well as running the cable to the Essence around the corner and into the wall. Also, the power cord either has to be plugged in to outlet behind 3000, under the 5 and be very visible, or again run all the way to the cabinet.
I had not thought about it before, but now that it has been mentioned, I have to agree that all of the circular bases are a bit much if I leave the 3000 on the stand.
I have two concerns about the 3000 on the cabinet. If they really bother me I can always move it back to the stand. First one is that as I use the stairs behind it I may see the cables and back of the 3000. Also, I have always liked the way the relative heights of the cabinet and the BV10 approximate the height change/angle of the staircase behind them. the 3000 will alter that effect.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sat, Jul 9 2016 9:09 PM
For the cables on the back of BS 3000 Razlaw I suppose you have the original plastic cable cover. You can ad a black B&O "socket" so you will only see the neat socket and not the cables.
I see your point about the stairs and height of the cabinet/tv but the Beosound is so nice and iconic I'm sure it won't alter anything.
Razlaw
Posts 4,345
Razlaw replied on Sat, Jul 9 2016 10:34 PM
I do still have the back cover. Although two tabs have broken off and it does not stay in place well.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sun, Jul 10 2016 10:33 AM
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Jul 13 2016 6:06 PM
Speaking of Beosound 2 in an other thread, here is one :
leosgonewild
Helsinki, Finland
Posts 2,373
Sal
California, USA
Posts 1,197
Sal replied on Wed, Jul 13 2016 8:21 PM
leosgonewild:
Beautiful greenery on the outside, beautiful music on the inside. What a relaxing room it must be :-)
Duels
England
Posts 2,553
Duels replied on Wed, Jul 13 2016 8:45 PM
Classic. Who's place is that Leo?
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Wed, Jul 13 2016 9:23 PM
@leosgonewild
What is powering the Pentas ?
leosgonewild
Helsinki, Finland
Posts 2,373
My fanille has been running a nursing home for 50 years, and it just closed down.
So my father has a VERY big house now Big Smile
The Pentas are powered by ICEpower 250asp modules Wink
And yesterday we played them on maximum. And did not care about neighbours. Amazing experience!!!
Duels
England
Posts 2,553
Duels replied on Wed, Jul 13 2016 9:59 PM
leosgonewild:
Very nice!
Earle
Posts 223
Earle replied on Wed, Jul 13 2016 10:42 PM
leosgonewild:
HAHA... is that why there's a screwdriver on the table? I trust some screws rattled loose while on max vol.
Peter Pan
Posts 2,088
Peter Pan replied on Thu, Jul 14 2016 1:26 PM
Hello leogonewild
We have the same set up, so I borrowed your image.
The setup plays just max - great sound.
Greetings and thank you - Peter  Yes - thumbs up
leosgonewild
Helsinki, Finland
Posts 2,373
What did you use it for? Big Smile
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Thu, Jul 14 2016 8:47 PM
leogonewild...
Here
leosgonewild
Helsinki, Finland
Posts 2,373
Thats lying, Peter Big SmileBig SmileBig Smile
Aussie Michael
Melbourne, AU
Posts 3,730
Razlaw:
I vote off the stand and on the unit
Razlaw
Posts 4,345
Razlaw replied on Fri, Jul 15 2016 12:30 PM
Aussie Michael:
I am waiting for a new cable to be delivered and then will be setting it up on the cabinet, off of the stand. Smile
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Fri, Jul 15 2016 6:42 PM
@Razlaw
You have some unique pieces in an unusual strong color!
Every single piece stand proud alone, and I think you should open up your placement.
I would move the stand elsewhere, and let the TV and speakers be one entity, let it present itself!
The Stand and the BS can easily carry its own weight elsewhere..
Just my two cent,- since I absolutely love the color!
Duels
England
Posts 2,553
Duels replied on Fri, Jul 15 2016 7:50 PM
BEOVOX141:
@Razlaw
Agree. Good idea.
Razlaw
Posts 4,345
Razlaw replied on Fri, Jul 15 2016 8:57 PM
I agree with you both. However, I already have a hole in the wall that passes to the basement that makes it very easy to run, and hide, the cable to the Essence which is in the basement. Also easy to connect Masterlink as there is a junction box in the cabinet. Also, I don't have any other location that I consider really great to place and display it, but I will take another look around the house.
The fret on the BV 10 was my own creation to match the older cabinet, Beolab 1s and Beolab 6000s I have in the room. I purchased a BV 5 fret which was available in the right color, removed the fabric and used it to recover the BV 10 fret.
Aussie Michael
Melbourne, AU
Posts 3,730
Where the a9 gone
Featuring the blue kvadrat cover
Beold
Denmark
Posts 69
Beold replied on Sat, Jul 16 2016 9:26 AM
Very nice. Goes very well with the coulor of the walls!
Office: Beomaster 3000-2 with Beovox P45 (all in white)
Living room: Beomaster 7000 and Beogram 7000 with Beovox RL 7000 (all in white)
Kitchen: Beocenter 2300 with Beovox 4500 (not available in white :-(
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Jul 16 2016 10:14 AM
A new piece from the Kartell Ettore Sottsass collection complements the Beocenter6 on the landing.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Simonbeo
Posts 1,451
Simonbeo:
Razlaw
Posts 4,345
Razlaw replied on Sat, Jul 16 2016 5:17 PM
Duels:
BEOVOX141:
@Razlaw
Agree. Good idea.
Again, thanks for all of the kind comments, compliments, and opinions. Unfortunately I have not been able to find a more suitable place for the Beosound 3000 than the places we have been discussing.
But, again, as everyone here has such good taste, I have an off the wall question on how another option might look.  My friend that was going to buy my Beolab 9s decided not to as he thinks the treble is too bright for his taste. So now I am trying to decide where I might be able to place my Beolab 9s.
One option is in my bedroom to replace the Beolab 4000s I have there. But due to sound quality, I have been trying to decide if I want to place the 9s where my Beolab 1s are right now. It would destroy the perfect color symmetry  that exists now, with the burgundy BV10, cabinet, BL1s and BL6000s as rears. I have three sets of covers for the 9s so the three options I see right now if I place the 9s where the 1s are, would be as follows:
1. 9s with black covers, no other change to the setup (maybe get a black fret for the BV10)
2. 9s with white covers, no other change to the setup (maybe get a white fret for the BV10)
3. Or the most outrageous option, blue covers on the 9s, new blue fret on the BV10, and replace the rear Beolab 6000s with 4000s that are also blue.
With the third option everything would be blue except the cabinet. So I would remove it from the setup. Mount the satellite receiver and and surge protector on the back of the BV10 with brackets from STB, or find a way to hide them in the basement, and place the BS3000 on it's stand where the cabinet is, between a Beolab 9 and the BV10.
I completely agree with the comment made here about too many circular bases with the 1s, the 10, and the 3000.  I completely agree with it now that it has been mentioned and agin my thanks for pointing that out to me.  But with the 9s I would lose two of those circular bases.
Thanks in advance for any opinions, comments, or suggestions. I will post a picture of how the blue would look in the room.
Razlaw
Posts 4,345
Razlaw replied on Sat, Jul 16 2016 5:21 PM
Just tried to post a thank you for comments, and a couple questions. Nothing offensive other than perhaps too many thank you, too many questions, and too many B and O products listed...LOL  Received the following response:
Post Pending Moderation
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
If the administrator has configured this forum to support email notifications you will receive an email when your post is either approved or denied (if you have emails enabled in your profile).
since when is the Flash thread a "forum that requires a moderator to approve"?
Page 74 of 142 (5643 items) ยซ First ... < Previous 72 73 74 75 76 Next > ... Last ยป | RSS
