BeoGreg:What an iconic product Stones ! B&O at its best.
Stones:Seen from the same position as the Overture only turned 90 degrees left.
Setup complete... Connected my BeoGram 4500 today :-)
Other view
Other view..
Other view :-)
Last one.
Stones:Yes! Ever since a BS9000 replaced my Overture some years ago I have been missing the easy operation of my good old friend. Therefore I was happy to find a new every day use for it By the way: Here is the BS9000 with the BL6000. Seen from the same position as the Overture only turned 90 degrees left.
kuyttendaele:Other view :-)
Very good to see how timeless the TV and the Beosound look together.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Makes me want to get a beogram 4500. Any detail shots of that turntable you can share?
kuyttendaele:Setup complete... Connected my BeoGram 4500 today :-)
Beoberg:Thanks guys! Regarding setting up the S8 as a sorround system. Instead of one RJ45 cable there are two from the S8 sub to the television. One transmits the subwoofer signal (I choose the BeoLab 14 sub in the menu as it is identical) and for the other I choose BeoLab 14 satellites. Easy as pie. 5.1 sound stage is phenomenal. Great power from the S8 sub without taking the punch from the Lab 9's and the two S8 satellites have crystal clear audio for rears. Plus what an upgrade from 40" to 55" when watching movies. I am very pleased! BeoVision 11-55 MKI (primary), BeoLab 9 (front), BeoPlay S8 (sub+rears), BeoSound 5/BeoMaster 5, ML/NL converter, BeoVision 6-26 MKIV (bedroom), BeoVision Avant 32 DVD (retro gaming), BeoLab 3500 (living room) BeoLab 4000 (entertainment room), 2x BeoPlay S3 (PC), BeoLit 12 (kitchen), BeoPlay A1 (everywhere), BeoPlay H2/H3 (on the go)
Aussie Michael:That's excellent Beoberg. Do you know if you can use the S8 with a Receiver 1?
Beoberg would need two of those then!
Seems that he already has done the cabling, though [a]
Millemissen: Beoberg would need two of those then! Seems that he already has done the cabling, though MM
Yes but I was asking particularly as I was wondering if the Avant could use the S8 (as the Avant has the built in transmitter) if I could use a receiver 1 with the S8 as rears so I don't have to run a cable to the TV
Hi there, Aussie Michael,
I dunno regarding the receiver. It works perfectly with the BV11 and the Avant should have the same options for programming the individual sound signal from the powerlink outputs.
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
A photo from my messy kitchen.
A Danish TV showing a Norwegian TV show in a Swedish kitchen. Some Finnish chairs can also be seen.
...and yes, I'll take care of the cabling any day now ;)
The living room of our old apartment. My old Beolab 1, a white Sony Mediacenter PC where nearly every menu item has a corresponding B&O wallpaper. Controlled with a Beo 5. A selfmade (my dad and I) active subwoofer in reflective white color to limit its optical size a little bit. The subwoofer becomes visible if you click on the picture. Beolab 7.2 beneath a LG OLED TV.
Menu items of the Mediacenter:
and to prove my love to the brand despite it's current way in design and quality: Nearly all of my B&O items are laser engraved with my logo and my name. The name was removed on the pictures (on the Beo 5 it's engraved corresponding with the circle aluminium housing and so small that it doesn't disturb the asthetics of the device)Except the Beo 4, all engravings are very subtle on the natural aluminium. But if somebody steals my Beo 5 he should explain on ebay why my name is on the remote and not his ;)
Hi Beoworlders, new beovirus victim here ;-)
Anyway, on the table tonight is my bm 900s. The 900k is for the kitchen, had a bit of noise on 1 channel, so I'm testing if one of my spares is better. I just picked up the naked one and the bg 1000 from service today after waiting for 2 months.
Very excited to get them back in the RG Compact case :-) The best looking stand-alone system ever made? It is in my opinion. Fitted with an Essence mk2 for streaming and future multiroom integration.
Meanwhile the 6500 system is supplying the soundtrack .
Kris
Hi Kris,
Welcome Beovirus victim, you appear to have it bad but coupled with amazing good taste! Nice combination.
Love the furniture, by the way.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century, S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase, B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Thanks for the kind words jeff :-) by the Way, the tv bench is costum made (Home made) to fit between the pentas
Kromer:by the Way, the tv bench is costum made (Home made) to fit between the pentas
Very well done, very well done indeed. Excellent work.
What is the story behind the cabinet above the home made piece?
P.S. You are very welcome!
Piaf: Kromer:by the Way, the tv bench is costum made (Home made) to fit between the pentas Very well done, very well done indeed. Excellent work. What is the story behind the cabinet above the home made piece? Jeff P.S. You are very welcome!
Do you mean the small rotating cassette tape holder? Similar to this: https://www.etsy.com/listing/486279345/vintage-cassette-tape-holder-cassette
TWG - great photos thanks for sharing
Kromer I like your photos too - it appears you're from the same place as my mum in Denmark :-) 🇩🇰
TWG: The living room of our old apartment. My old Beolab 1, a white Sony Mediacenter PC where nearly every menu item has a corresponding B&O wallpaper. Controlled with a Beo 5. A selfmade (my dad and I) active subwoofer in reflective white color to limit its optical size a little bit. The subwoofer becomes visible if you click on the picture. Beolab 7.2 beneath a LG OLED TV. Menu items of the Mediacenter: and to prove my love to the brand despite it's current way in design and quality: Nearly all of my B&O items are laser engraved with my logo and my name. The name was removed on the pictures (on the Beo 5 it's engraved corresponding with the circle aluminium housing and so small that it doesn't disturb the asthetics of the device)Except the Beo 4, all engravings are very subtle on the natural aluminium. But if somebody steals my Beo 5 he should explain on ebay why my name is on the remote and not his ;)
This is looking great. Looks like Kodi? I'd also planned to add wallpapers, but couldn't find overly nice ones. We should have a thread on this with all of us posting links. Particularly love to see some of the more recent items. What do you think?
steve1977:add wallpapers, but couldn't find overly nice ones. We should have a thread on this with all of us posting links. Particularly love to see some of the more recent items. What do you think?
BeoNut since '75
Lots of holes ;-)
You can control the future and the past by controlling time!
BV14, BV10, BeoGram 3000, 4500, BS 9000, Moment, Core, Ouverture, Essence, Beo6, BROneBT, BeoTime, ML/NL, BLGW, BeoLab 2, 11, 18, CX100, BeoPlay A6, M3, E8/H3/H8
Millemissen: Lots of holes ;-) MM
Add sugar and you've also got it in your teeth but maybe cheese would be a better fit ;-)
alex_112: You can control the future and the past by controlling time!
Ah, but do you control the horizontal, and do you control the vertical? Can you change the focus to a soft blur, or sharpen it to crystal clarity?
Jeff: alex_112: You can control the future and the past by controlling time! Ah, but do you control the horizontal, and do you control the vertical? Can you change the focus to a soft blur, or sharpen it to crystal clarity?
Sorry, I forgot that playfulness is the Essence of full control. ;-)
old..VS ...new :)
marexy: old..VS ...new :)
BL12:s look awesome in that setting and it´s a very nice and sleek installation.
Happy with the sound?
A BV11 / 14 would be nice on that wall as well :)
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
sound ..hmmm
http://archivedforum2.beoworld.org/forums/t/11577.aspx
Hi
I have tested speakers on the floor with foam under spekers.
so ..only thik it can vibrate is speaker :(
Problem is contact / plastic housing- alu front /
