Beolab 4000 vs. 17
This post has 60 Replies | 1 Follower
StKong
Copenhagen
Posts 320
StKong Posted: Fri, Jan 13 2017 12:04 PM
I love the Beolab 4000, it's sound and design.
Since the form factor is almost the same on the Beolab 17, I have considered the speaker, but I don't think it sounds great.
It is of course state of the art tech, but I compared it in store to a set of BL3 and in my opinion Beolab 17 don't come close in clarity.
Considering the high price of BL 17, aAm I wrong in getting a couple of used Beolab 4000?
Wireless connectivity is not crucial to me.
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Fri, Jan 13 2017 3:18 PM
I have the 17's and I like them a lot. They were close to US $5000 for me to buy though. The price you pay for a used pair of BeoLab 4000's generally run about $750, a little more or less depending on condition, and not long ago I bought a new pair of BeoLab 4000's on eBay for $1500.  I don't think there is any way you could go wrong getting a used pair of BeoLab 4000's as they are very fine speakers!  I think you can still buy a new pair of grills from BeoShop.co.uk if that is an issue.
marexy
Posts 710
marexy replied on Fri, Jan 13 2017 4:17 PM
yust go for BL4000
I deal with used B&O for 10 years and they are one of the best price performance spekers form B&O ever!!!
I just instal at my home new BL 12.3 and i'm not happy with soud. BL 4000  for 300 € were premium im my room + woofer for 200€ ...much better sound than new B&O for 5000€.
Millemissen
Flensborg, Denmark
Posts 14,680
Agreed - the BL4000's are good, but don't compare old/aged speakers with new ones.
If I would have to choose between - theoretically - new 4000's and the BL17's, I would not hesitate to get the 17's.
However - as things are - you get a very good set of speakers with the 4000's.....often at a very good price.
Please beware of the older ones (MK1), because the foam inside may crumble and damage the speakers.
I've had mine checked and 'cleared' - and am still very pleased with them and the sound.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Jan 13 2017 5:24 PM
Unfortunately, I've not had the opportunity to hear the BL4000 and BL17 side by side. But, I do feel the BL17 is an ugly duckling compared with the BL4000, which is still to me one of the most beautiful Beolabs ever made, right up there with the BL8000. Considering the price difference, and the looks, and the fact that the BL4000 is a good sounding speaker, I wouldn't hesitate to buy a pair. If you want more bass I think you'd be better off adding a 2nd hand BL11 to them than in putting in as much money as the BL17s cost. I've heard the BL17s and think they sound quite good, with, if I recall correctly, more punch than the BL4000s, but I think I'd still go for the BL4000s. Your opinions may vary of course!
Jeff
marexy
Posts 710
marexy replied on Fri, Jan 13 2017 5:51 PM
on the BL 4000...MK1 90% all faults is foam rotting.
when decomposed generates acid that corrodes the joints in electronics.
I repair at least 30 pairs with that fault.
but for 20%  price of new BL17 you get really good used BL 4000 speaker will still operating many years and low cost of repair if necessary.
StKong
Copenhagen
Posts 320
StKong replied on Sat, Jan 14 2017 2:53 AM
marexy:
yust go for BL4000
Thanks for your input, Marexy.
I am getting a pair of BL4000 if I can source a good set. Is it oossible to check for damaged foam yourself?
Interesting that you mention Beolab 12-3. I was just introduced to them in a store today, and I think they sounded very crisp and clear with a good resonance, while being very appealing to the eye. Of course I could not listen to 4000 for comparison, but next to the Beolab 17, I think the acoustic lens worked wonders and now I am actually considering getting a pair for my corner room, since the price is almost half of the original retail price due to discontinuation.
I noticed your set-up on the flash-thread, and it looks really good with the 12-3's, so I am sorry to hear that you are not happy with them. Could it be an installation issue.
If I get them, they will be wall-mounted as well.
StKong
Copenhagen
Posts 320
StKong replied on Sat, Jan 14 2017 3:21 AM
Thanks for your replies as well, Mark-N, Jeff and Millemissen.
I have noticed that used Mk2 are twice the price of a Mk1 pair.
I have read different opinions on this and other forms about the difference in amplifier, and it seems to be a question of religion as is often the case with speakers.
Some prefer ICE-power, some don't.
Would you recommend getting the newest version, or would it make better sense to find a good used first-generation pair and have them repaired if the foam eventually disintegrates?
How big of an operation are we looking at?
PK
Posts 82
PK replied on Sat, Jan 14 2017 9:19 AM
MK1 don't have a switch for corner position, wall mount or free standing as the newer BL has. So they can sound a bit boomy if mounted in a corner or close to a wall. If you wan't MK1 you should get them on the floor stands for best sound. Plus, the flood stands looks excellent! Really adds a premium to the looks.
I have two pairs of MK1 4000, one in silver and one in gold and if you can find gold, get it. Absolutely stunning! Much nicer looking than the latest brass editions!
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Jan 14 2017 2:41 PM
StKong:
BL4000mk2 and the BL4 use the same ICE power amplifiers (slightly modified) and they regularly fail. They are not that reliable as the mk1's.
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Jan 14 2017 2:47 PM
The Mk 2 use the amplifier from the Beolab 4 - slightly dodgy design in my view, not the same as the bigger speakers. I have two sets of Mk1 4000s - a blue set and a gold set - both brilliant and no problems with either. When I went round Struer, 4000s are in just about every room - clearly because they are cheaper but also because they can be put almost anywhere and sound good. Don't know what they have these days - Geoff?
Peter
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jan 14 2017 3:05 PM
Peter:
Interesting Peter, and one of the reasons it's good to have the forum here, I'd not heard about the problems with the BL4000 and IcePower amps. I know that, outside of reliability, a lot of the things I hear said against IcePower has more to do with the typical audiophile view of if it ain't a class AB old style amp, preferably with tubes, it has to be evil incarnate. But reliability is an important consideration. Given that, and the price, I'd go with MkI's personally, and if boomy adjust the bass.
I love them wherever I've seen them, on a shelf, on floor stands, mounted on the wall (stunning on each side of a BS9000 or such). I had a pair for evaluation briefly when I was deciding between them and the BL8000. They sounded amazing, but the 8000 had better bass and were better suited for my listing in the room I had, but it was a close thing as the 4000s sounded very good and would have been easier to sit on the mantle. Ultimately I decided to arrange the room differently and mantle mounting was not important. Stunningly good looking speaker though, after looking at small box speakers for decades, the graceful leaf shaped cabinet design just blew me away.
Someday I'll pick up a used pair.
Jeff
jowus
Posts 161
jowus replied on Sat, Jan 14 2017 3:46 PM
Hi Jeff, the 17's were made out of the 4000's, so how can you say it's ugly? In Design wise, they just differentiate it a little bit. And they sound way better than the 4000's. I don't see it ugly at all. Maybe, the only thing ugly about it is the Price but not the Speaker itself.
StKong
Copenhagen
Posts 320
StKong replied on Sat, Jan 14 2017 4:22 PM
jowus:
The thing is that the new ones, while aesthetically appealing, in no way possess the effortless elegance of the 4000.
In terms of size they are similar, but the shape makes all the difference to me.
Smile de gustibus EST disputandum
StKong
Copenhagen
Posts 320
StKong replied on Sat, Jan 14 2017 4:25 PM
Jeff:
Thanks for the clarification, PK, Beobuddy, Peter and Jeff.
I am going to find one or two nice pairs in the Mk 1-iteration and hope the foam is in good condition.
Any suggestions on how to make sure this is the case without taking the speakers apart?
I gather that temperature fluctuations and humidity play a part in the deterioration .
Thanks again!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jan 14 2017 4:31 PM
jowus:
How can I say it's ugly? Well, I didn't say ugly, I said the 4000s were better looking, to me. But how can I say it. It's easy. It's ugly! See how easy that was? Stick out tongue Actually, I do think the 17s are unattractive, and don't find the materials they are made of as attractive as the 4000s. Sonically, I think they are better, but better than say a used pair of 4000s with a BL11? At a lower price? That would be superior in my opinion, your ears may differ of course.
Jeff
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Sat, Jan 14 2017 5:33 PM
I seem to have read about issues with the power switch on some of the MK 1 models.  Was this the case?  I know the MK 2 did away of the power switch and just have the status light.  I will see if I can find those threads, but I do not have much luck with the search function.
Neil
Posts 9
Neil replied on Sat, Jan 14 2017 6:24 PM
I don't have a pair of Beolab 4000's, but I believe that the easiest way to inspect the foam is to unclip the speaker grill and remove the tweeter from the front by removing the two screws. If the foam is black, then it is probably original, as the replacement updated foam is white. Removing and changing the foam requires the speaker to be dismantled.
I don't know the percentage rate of foam failure, but the problem also applies to the Beolab 8000.
jowus
Posts 161
jowus replied on Sat, Jan 14 2017 10:54 PM
Hi Jeff,'
When I first saw the 17's, that's what I thought, but, after listen to it and seeing it few times, I love it them the most. I owned the 4000, and I don't have the need for 17's, but the size of it and the sound, I'll get it in a heart beat if I need one. Trust me is just a redone of the 4000's, the same as the 8000's being 18's now and 9's being 20's now.
Michael
Sweden
Posts 2,578
Michael replied on Sat, Jan 14 2017 11:02 PM
Beolab 4000 shares form factor with BL17 which is the obvious replacement. The BL17 is much much improved in every way. The sound is impressive for such a small speaker and certainly price wise in the beolab range. The design with the circle can be discussed but it looks much more recent than BL4000 does. Bl4000 sounds okey but not good enough in lows. Most speakers sounds good with a subwoofer added. If you have a BL2 sure go for whichever speakers you want. If you don't want a subwoofer go for BL17 or something else better for full range on its own. They are great at it and they also have wisa and toslink. I think the bl4000 looks a bit dated but still beautiful. And very heavy(!).
Millemissen
Flensborg, Denmark
Posts 14,680
StKong:
You won't - unless you take the speaker apart....
....or wait untill it stops functioning.
Taken apart you will be able to see how far the 'rot-process' is - and might be able to rescue it/keep it sound by removing the foam.
If it already has stopped working, you mostly will have to replace all the electronics - which I would not call a cheap operation.
jowus
Posts 161
jowus replied on Sat, Jan 14 2017 11:36 PM
Thank You Michael. Is like saying 2000 Mercedes Benz is better looking than the current. Off course, material wise, they're going to be stronger than the current but who wants to carry heavy stuff at the moment. My 2006 LCD TV weights heavily on the wall but that doesn't mean is better than the current Light weight TV. I still don't see 4000's better or nicer than 17's Period!
jowus
Posts 161
jowus replied on Sat, Jan 14 2017 11:37 PM
Thank You Michael!👍🏾👍🏾👍🏾👍🏾
henrik
Sweden
Posts 458
henrik replied on Sun, Jan 15 2017 8:55 AM
Michael:
Yes, I think the circle looks terrible (but I like the rest of the design). It bothers me, because I think the BL17 is a really nice product apart from that. It's only the circle that I dislike, but I dislike it so much that I actually prefer ANY other Beolab to it when it comes to visuals. I have really tried to like it, but so far I have unfortunately failed.
StKong
Copenhagen
Posts 320
StKong replied on Sun, Jan 15 2017 11:21 AM
jowus:
Surely, we can agree that newer does not always mean more beautiful? Smile Or more appealing, even if technically better.
To remain in the Mercedes analogy:
Electric windows and gasoline injection are far superior technologies to Solex-carburettors and hand-rolling windows, but which of these two cars would you rather drive? It's a matter of opinion.
In my book charm, appeal and aesthetics play a large part when assessing a product.
Tech specs account for tech specs alone, and with price considered, perhaps the 4000 is a good and charming choice.
jowus:
Are older products generally stronger than the new ones, or how do you mean?
jowus:
I never heard that heavier is supposedly better, and I don't think it is reflective of the B&O engineering philosophyIndifferent
Do we know for a fact that Beolab 17 is lighter than Beolab 4000? The aluminium used in the cabinet looks thick.
StKong
Copenhagen
Posts 320
StKong replied on Sun, Jan 15 2017 11:30 AM
Michael:
If WISA is not necessary, what else would you recommend? BL3?
Michael:
Are they very heavy? Or do you think they look heavy?
StKong
Copenhagen
Posts 320
StKong replied on Sun, Jan 15 2017 11:34 AM
Millemissen:
So without taking them apart, buying a pair is a case of Russian roulette. Maybe they're fine, maybe they're not.
Very comforting Smile_ That speaks in favour of new speakers.
StKong
Copenhagen
Posts 320
StKong replied on Sun, Jan 15 2017 11:40 AM
henrik:
I am trying to like it as well. To me, the plastic on the sides don't help. Neither does the fact that the logo reads upside down when tilt-mounted on a wall.
Michael
Sweden
Posts 2,578
Michael replied on Sun, Jan 15 2017 11:41 AM
StKong:
I have a pair of Bl4000 and I find them quite heavy, especially for the quite simple sound they actually do produce. The BL17 has much more punch to it, not sure how much they weigh. I don't think the circle design is ugly. And it is easy to match a nice profile, like black sides, aluminum and textile for example.
But that was my two cents. Make your decision, you have all data you need :).
BL3 is also nice though but the rubber texture editions have issues with material deterioration.
I also want to point out that BL4000 is not a foam rot speaker.
StKong
Copenhagen
Posts 320
StKong replied on Sun, Jan 15 2017 11:57 AM
Michael:
Thank you for the 2 cents, Michael.
Which version of BL3 I prone to deterioration? I have tried looking that up, but I find nothing conclusive.
And you say that BL4000 is not susceptible to foam rot, which contradicts what others in this thread say.
It isn't easy being a lay-person. ParadiseParadise
Steve_torque
Dorset, UK
Posts 145
Hi, I have had the lab3's and now have the 4000's connected to my essence. I liked the lab 3's but just missed the lower end, call it warmer, fuller sound, not sure. I really like my 4000's and don't miss the lab3's. especially now the essence has bass and treble control, just upped the treble a little and the 4000's sound great.
It may be the room and my taste of course, but for the money, as said before, the 4000's are great speakers. I have the silver with grey frets and they blend in very well.
I've also never really taken a shine to the 17s, they do sound very good though. If you can get the 4000s from a pre owned specialist (lifestyle av etc), then you get a warranty to give you some piece of mind, that's what I did.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Jan 15 2017 4:01 PM
With respect to foam rot, the usual "foam rot" was/is with older speakers that used foam instead of rubber for the speaker surround, that part that connects the edge of the cone to the metal or plastic ring of the speaker basket. The B&O 4000 uses rubber for that, in the past just about all speakers that used foam surrounds had problems, the foam would rot away leaving the edge of the woofer flapping in the breeze. This was due to a particular type of micro-organism that attacked the foam, in addition to ozone/oxygen in the air, etc.
The foam people are talking about with the 4000 is inside the speaker, its used to absorb reflected sound inside the speaker and such, and it can deteriorate and contaminate the electronic boards on the amplifiers and corrode the printed circuit boards.
Two different types/places for the foam! I know I'm tempting fate with my 1997 BL8000s but I've never had the foam replaced and they still work, knock on aluminum.
Jeff
StKong
Copenhagen
Posts 320
StKong replied on Sun, Jan 15 2017 7:58 PM
Thanks stevegee and Jeff. This forum is great.
Now that we seem to have exhausted the foam issue and I feel much wiser, the way forward is to find a dealer who will offer some sort of warranty. Here in Denmark several used pairs come with 12 months warranty.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Jan 15 2017 8:28 PM
Why not ask Lee? Everything I have bought from him has always been of the best quality - one of my pair of 4000s came from him.
Peter
marexy
Posts 710
marexy replied on Mon, Jan 16 2017 6:00 PM
sorry ...but i'm still on BL4000 side.
Just did repair in one pair with serial No 13.....and foam rot problem ...again..
and now play like new...and inside transformator is 30W or so ...not more ...and they play ..omg ..they play for these 30W .... :)
i did test side by side with my new BL 12.3 ...2500 €
 you will not believe this old speaker can do so much for 200€ -online buy .
and bass driver is the same as in old CRT Avant 32 TV  ( 20 years old ) ..and tweeter to.
i'm positive that new one's BL with wireless and ICE power amplifer will not last half so long without any service or firmware problems or so :(
StKong
Copenhagen
Posts 320
StKong replied on Tue, Jan 17 2017 1:59 PM
marexy:
This is really interesting, marexy.
Thanks for sharing.
How do you assess the 12-3's dynamic range compared to the 4000?
I read elsewhere that you are dissatisfied with the installation and related vibration issues.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Jan 17 2017 4:37 PM
One of the things I think is good about getting a 2nd life pair of either the 4000s or the 8000s is that you get a very good sounding, iconic piece of B&O style by what was, in my opinion, the finest designer/stylist B&O has had, all for a pittance compared with the new gear. I will grant you that the new gear sounds marginally better, the 17 has better bass for example, but to my eyes none of the new gear is as attractive as the older gear.
If the old gear sounded awful, or significantly worse, that'd be one thing, but the improvements are incremental and the older gear already sounded very good. I'd prefer, for sonic and aesthetic reasons, a pair of 4000s and a BL11 over a pair of BL17s, and I think bass would be better and cost lower.
Opinions will vary of course, but I feel absolutely no desire to swap my BL8000s or my BL9s for 18s or 20s.
Jeff
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Jan 17 2017 8:29 PM
And of course, therein lies B&O problem! The vintage kit was built to last and it does!
Peter
StKong
Copenhagen
Posts 320
StKong replied on Wed, Jan 18 2017 7:01 AM
Peter:
Peter
Has quality really gone markedly down in later years to an extent where durability is an issue and should be considered when investing in newer models?
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Wed, Jan 18 2017 9:41 AM
StKong:
Peter:
Peter
I think it is justify in your mind that you don't have to spend more for new components!  It will take about 10 years to see failures of the BeoLab 17's while BeoLab 4000's are still generally going strong, and I don't think we will see that.
Page 1 of 2 (61 items) 1 2 Next > | RSS
