Regards
Kiran
Born in NL; I ride ML
beolion:Ubiquiti is pretty amazing. It’s my best investment in my infrastructure to date. Beside my on single AP AC-LR (which covers my 314 m2 house), I also have the USG, a couple of Unify switches with POE and a Unify Controller. Works flawless and performance is incredible. You won’t regret it!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
When you say wall-mounted, I assume the AP is positioned vertically?
Not a good idea... The radiation pattern of the AP`s is designed for ceiling mounting.
See this article
https://help.ubnt.com/hc/en-us/articles/115012664088
Tim
Duels:Mirror tv. It’s a mirror and a tv I guess? Not seen one of those before.
Go steady Kiran... BL3500's don't like wet areas! I know from experience! Keep the bathroom well ventilated if you're filling up the bath or running a shower All the best, Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
BAND'OH!:Go steady Kiran... BL3500's don't like wet areas! I know from experience! Keep the bathroom well ventilated if you're filling up the bath or running a shower All the best, Simon.
Hi Kiran
Are you renovating your old famy house or you purchase that house not long ago ?
Do you have family ...as i can't see any signe of family ...sorry ...just asking ?
Nice progress trough.
Just a tipp...maybe you should do some indise wall pritection behind TV.
Hi
sorry ..i do not think in any negativ way ..
ony as i can see on photos :)
Just now ...i'm on the process of thinking ..of integration in my house ..but...there are some issue by other family menbers :(
marexy: sorry ..i do not think in any negativ way .. ony as i can see on photos :) Just now ...i'm on the process of thinking ..of integration in my house ..but...there are some issue by other family menbers :(
Kiran, you might find this interesting re smart home integration.
https://www.youtube.com/watch?v=azNK_Tgkb30
It's not using B&O products, but its a nice end result.
Anyway, its probably worth 8 minutes of your time.
Later.
Sandyb:Kiran, you might find this interesting re smart home integration.
BAND'OH!: Go steady Kiran... BL3500's don't like wet areas! I know from experience! Keep the bathroom well ventilated if you're filling up the bath or running a shower All the best, Simon.
I have mine now for 5 years mounted in the bathroom. Especially in winter, when it's cold outside, I never open the window, only let the bathroom door stay open after showering or bathing.
Never had a problem with the BL3500 there.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Kiran:They think its only a mirror...When I say its a TV too, they don’t believe me...
P.S. I swear I'm going to design a lampshade to clip onto those Ubiquiti WAP's...
BeoIce:Especially in winter, when it's cold outside, I never open the window, only let the bathroom door stay open after showering or bathing.Never had a problem with the BL3500 there.
trackbeo:Doesn't look like a Seura. What brand is it? P.S. I swear I'm going to design a lampshade to clip onto those Ubiquiti WAP's...
Kiran:If only the light rings on the WAPs were a little brighter. They would make a great blue night light...
You may add a higher voltage than the standard 48V POE to get them light brighter
BeoIce:You may add a higher voltage than the standard 48V POE to get them light brighter
He was joking; hopefully you are too. For anybody else who runs across this by searching: yes, LEDs can get a little brighter but pretty soon they overheat. The curve is surprisingly steep: https://electronics.stackexchange.com/questions/256336/does-led-brightness-change-with-voltage
ngnear:https://unifi-led.ubnt.com/
Kiran:Dormer progress... Slate roof view ... Regards Kiran Born in NL; I ride ML
BeoNut since '75
Now Kiran - where would the new BS Edge fit in.....if?
Millemissen:Now Kiran - where would the new BS Edge fit in.....if?
