Beovision 4-65 use with beosystem 4
This post has 8 Replies | 2 Followers
georgey007
Posts 74
georgey007 Posted: Sat, Apr 1 2017 3:08 PM
Hello
I'm thinking of changing the beosystem 3 to a beosystem 4 and use with my bovision4-65 mk3. Would this be possible... what with the cam and the ir port ?
Regards
DocLeisure
Posts 101
Hello,
works perfect, I recently switched from BeoSystem3 to BeoSystem4 on my BeoVision4-50 MK III.
You would need two new cables for the TV, because everything is RJ45 now. If you have the skills, making those cables is no problem, otherwise ask your local dealer.
And keep in mind, as everything is RJ45, you need some adapters for your speakers as well - asuming they are connected via PowerLink.
One last thing: the TV has to be measured by a specific USB device, otherwise there is a short warning everytime you turn the TV on. This does not harm the functionality, simply is anoiing.
Go for it, it is a completly new experience.
Best regards
Doc Leisure
PS: You will gain a NetLink device and loose link room TV...
georgey007
Posts 74
Thanks this are very good news indeed
Luuc
Posts 6
Luuc replied on Sat, Apr 8 2017 10:54 PM
Can you tell me how to make the cables?
the rs232 to rj45 cables i need to make so i need the wiring scheme.
the HDMI to dvi is a simpel connector
and do you have any idea ik and how to connect and wire the Beostand connector to a Beovision 7-55 floorstand?
i am planning om putting my Beovision 4-50 on a beovision7-55 floorstand and so it would be fantastic to be able to rotate the stand.
thanx for the help
Luuc
Posts 6
Luuc replied on Sun, Oct 8 2017 7:41 PM
i am planning om putting my Beovision 4-50 on a beosystem 4 and put it on a beovision7-55 floorstand and so it would be fantastic to be able to rotate the stand.
so the question is:
1    the cables from the beovision from rs232 to rj45 cables i need to make so i need the wiring scheme. Could you help me with that part?
     What colors need to be on which pin?
2    the HDMI to dvi is a simpel connector, am i right?
thanx for the help
Best regards
Luuc
Beolab1
Rotterdam
Posts 22
Beolab1 replied on Tue, Oct 10 2017 2:44 PM
Sorry wrong thread. Can’t seem to delete.
Beolab1
Rotterdam
Posts 22
Beolab1 replied on Tue, Oct 10 2017 2:48 PM
beoandy
sissi not kangaroo
Posts 329
Luuc:
so the question is:
thanx for the help
Best regards
Luuc
hi, maybe this helps.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Jul 12 2021 6:43 PM
I have a similar task.
But I do not understand one detail...
... RJ45 to DSUB9 male.
DSUB Pin 5 is GND - but does not go to any PIN in the RJ45?
Even though RJ45 has Blue GND but on Pin 4....?
Thanks in advance!
Ralf
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
