Can you tell me how to make the cables?
the rs232 to rj45 cables i need to make so i need the wiring scheme.
the HDMI to dvi is a simpel connector
and do you have any idea ik and how to connect and wire the Beostand connector to a Beovision 7-55 floorstand?
i am planning om putting my Beovision 4-50 on a beovision7-55 floorstand and so it would be fantastic to be able to rotate the stand.
thanx for the help
i am planning om putting my Beovision 4-50 on a beosystem 4 and put it on a beovision7-55 floorstand and so it would be fantastic to be able to rotate the stand.
2 the HDMI to dvi is a simpel connector, am i right?
Best regards
Luuc
Sorry wrong thread. Can’t seem to delete.
Luuc: Can you tell me how to make the cables? i am planning om putting my Beovision 4-50 on a beosystem 4 and put it on a beovision7-55 floorstand and so it would be fantastic to be able to rotate the stand. so the question is: 1 the cables from the beovision from rs232 to rj45 cables i need to make so i need the wiring scheme. Could you help me with that part? What colors need to be on which pin? 2 the HDMI to dvi is a simpel connector, am i right? thanx for the help Best regards Luuc
hi, maybe this helps.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
I have a similar task.
But I do not understand one detail...
... RJ45 to DSUB9 male.
DSUB Pin 5 is GND - but does not go to any PIN in the RJ45?
Even though RJ45 has Blue GND but on Pin 4....?
Thanks in advance!
Ralf
