OLUFSEN FORM 1 REPLACEMENT FOAMS
This post has 65 Replies | 7 Followers
armany92
Posts 1
armany92 Posted: Mon, Sep 3 2012 3:58 PM
Hello people, i have been searching all the weekend this replacement (pads form 1), and i couldn't find anything. I remember that some years ago i found a dealer from beoworld and another one from ebay, but now anything. Someone could help me? I'm from spain, so i think that the online buying is my only way.
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Welcome to BeoWorld!
Discussed a few weeks back here on site ... Sadly, there is no solution. There was some chatter about an attempt at reproducing them but I don't think that got very far -nor do I expect that it will.
  • One B&o bottle opener
  • One fancy gun
azuccari64
Posts 3
azuccari64 replied on Wed, Feb 27 2013 11:46 PM
Hi, any news on replacement ear pads for form 1 headphones?
Thank you
Arnaldo
Orava
Finland
Posts 991
Orava replied on Thu, Feb 28 2013 7:43 AM
I bought new ones from B&O store, maybe year ago. Aren't they aviable anymore?
azuccari64
Posts 3
Orava:
That's what I've been told by my B&O store...
Orava
Finland
Posts 991
Orava replied on Thu, Feb 28 2013 11:08 AM
Too bad Sad. They could keep them on stock, wouldn't cost much to them... I think...
How about cut them from acoustic foam? Kind used as speaker fret?
BYPAHTEC
Posts 4
BYPAHTEC replied on Thu, Feb 28 2013 5:47 PM
In my experience, even replacing with the NOS pieces -you suffer the same issue.
I replaced mine. They sat on a shelf for a year unused. I picked them up and the pads crumbled into oblivion.
The only solution is a replacement using different (than original spec) foam.
Do not waste your money on OEM replacements.
Orava
Finland
Posts 991
Orava replied on Thu, Feb 28 2013 6:17 PM
Oh, mine are still ok. Maybe yours were wrongly stored?
azuccari64
Posts 3
I changed mine last time 10 years ago and they became dust in my fingers when last week  I picked up the earphones after a couple years of sleep...
The Secret Alpaca
Somewhere in Europe.....
Posts 46
I've heard on the grapevine that an original replacement sponge kit has been located, unopened and unused.
The owner has already spoken to s sponge manufacturing company to see if they might be able to help - so hopefully it may not be too long before a solution is found to this issue.... Wink
Orava
Finland
Posts 991
Orava replied on Fri, Mar 1 2013 3:17 PM
The Secret Alpaca:
Ooooh Surprise A real collectors item. Those could not be opened and used.
Orava
Finland
Posts 991
Stick out tongue
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Orava:
Well, they were adjacent to some Form 2's, a pair of Sennheisers, and several A8's with their little foam skins ... none have had the same issue.
It was the original material spec -it simply crumbles into dust.
These things happen. I once had a pair of NB tennis shoes and the soles literally turned to dust after a while! Laughing
  • One fancy gun
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
The Secret Alpaca:
Huge!
If this pans out, I will be first in line!
  • One fancy gun
Orava
Finland
Posts 991
Orava replied on Fri, Mar 1 2013 6:05 PM
ɓʋɾɑɳɫɘɮ:
Yes, I have bicycle handles starting to melt down. I just might be that we don't have to worry about plastic waste in future... Or maybe usefull things dissapear and waste stays.
About Sennheisers, I had pair of those yellow ones, and their foams vanished to dust.
Wade
New York City
Posts 24
Wade replied on Thu, Mar 21 2013 8:56 PM
Any word on where the proper kind of foam could even be sourced? I live in NYC and if someone suggests a place here I'd be happy to go check it out in person.
Meanwhile, I'm working on the leather strap modification as well as creating some of my own foam pads to make my Form 1s comfortable enough to use. I'll start a picture thread once I'm done.
bwaje
Posts 32
bwaje replied on Thu, Apr 4 2013 4:52 PM
I have found this dealer : Scan Sound , they have in stock plenty of replacement foam : http://www.scansound.com/headphones_earpads_covers#Cushions
maybe the oval 50 mm would do the job ?
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Not even in the same ballpark!
  • One fancy gun
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Apr 5 2013 9:05 AM
I can now confirm that after a couple of months working with one of the UK's leading sponge manufacturers, trialling and testing different sponge grades and adhesive film types, we've just placed an initial order for 100 sets of replacement Form 1 pads.  They are of a slightly higher grade acoustic foam than the originals, and the adhesive tape sections are of 3M quality we are told.
Tooling costs, and being such a small quantity at a time has meant we will have to be selling them at £29.95 a set - but if it means saving a pair of Form 1's then it's got to be worth it.  If we'd have ordered around 1,000 sets we could have got the price down to £24.95 a set - but we worked out it would literally take 3-4 years to even recoup our original outlay. Bad business..
It should be a few weeks before we get them, and i'll keep you informed.
Kindest Regards
Lee
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Well done that man!
Regards Graham
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Fri, Apr 5 2013 11:29 AM
Yes great news. Now I need to source some Form 1's
If you think nobody cares, try missing a couple of payments.
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Apr 5 2013 11:36 AM
Will they be called Foam 1's then?
I'll get me coat...
--mika
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Apr 5 2013 12:25 PM
tournedos:
I'll get me coat...
Put it back on, that was funny! Big Smile
peria
Posts 321
peria replied on Fri, Apr 5 2013 6:38 PM
Nice. I have a very clean pair of F1, but this will do the trick. Sad that I don't really use headphones at home. Still, sign me up.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sat, Apr 6 2013 10:14 AM
Didn't the original Form 1 headphones have foam pads covered by some sort of snap-on leathery material covers, and both the foam and the covers were liable to break-up? Or maybe I'm thinking of some other headphones. I seem to recall that B&O sourced their leather covers from another manufacturer and that for some time you could get the covers if you knew which other headphones had the same covers.
I take it that this offer is for the foam inserts only???
Graham
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
vikinger:
Yes, you are thinking of the U70.
The Form1 has a total of (4) four foam only pads: one for each ear and secondary pads in the above ear/temple area.
  • One fancy gun
vikinger
Posts 5,422
ɓʋɾɑɳɫɘɮ:
vikinger:
Thanks Jeff. It was the U70 I was thinking of.
Graham
Ben_S
UK
Posts 631
Ben_S replied on Sat, Apr 20 2013 11:21 AM
Hi Lee,
Any news on these? Mine are desperate for some new foams!
Ben
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Apr 20 2013 11:25 AM
Ben:
Hi Lee,
Ben
We chased them up yesterday and we should have them within the next 7-10 working days Yes - thumbs up
Lee
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Apr 20 2013 11:38 AM
Hi Lee,
great news!
Please put me on the list..:)
Stefan
Ben_S
UK
Posts 631
Ben_S replied on Wed, May 8 2013 1:01 PM
Any news on these? :)
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Wed, May 8 2013 2:18 PM
Bad news...
We heard from the manufacturer, who told us they were on their way to setting up the machine to make them....  that they were sub-contracting them to a company in Germany, who now want us to order £14,600 worth of the sponges - and they also want a few hundred pounds "tooling costs" on top of that. This would also push the cost of a pair of the sponges up to around £40 - and we'd need to be selling around 10 pairs a DAY to make it viable. Something we're clearly never going to do.
Naturally, we've told them to get stuffed - and the company in the UK are seeing what they can do for us instead.
We're as disappointed as you, but we're still trying...
Lee
Angry
Ben_S
UK
Posts 631
Ben_S replied on Wed, May 8 2013 2:36 PM
Ah, Thanks for the update! So frustrating for everyone I guess!
bwaje
Posts 32
bwaje replied on Thu, Aug 22 2013 9:43 AM
I was enough lucky yesterday, I went to my local B&O dealer and asked him about Form1 foams...And he could find the last  kit of foam available, and gave it to me for free !
See picture below,  they measure exactly 40mm X 40mm; the foam quality seems very light, so I don't know if they will keep steady along the years...
I could not detach the stickers with the risk of riping the foam, so I sticked some double face tape on the headphone.
i'm so sad that thse very basic compnents cannot be find, IMO the product price should be around $5 according to the poor quality of the foam.
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
bwaje:
GOOD LUCK! At least the price was correct!
I bought the same NOS pair for ~75USD a few years back and they did not last much more than a year.
Funnily enough, last weekend I grabbed mine in a hurry after sitting dormant forever. After a quick listen, I found both ears stuffed full of lovely black micro-powder.
Maybe I'll tackle the project out of spite.
  • One fancy gun
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Thu, Aug 22 2013 4:39 PM
My new ear pads lasted 18 months.  Just came right off, leaving adhesive and a thin layer of foam behind.  I PVA'ed them back in place and so far that works.  Until the next time they die.  Maybe I'll head to Joann's and Michael's and do some brainstorming this weekend.
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Rich:
Rich, and anybody else interested...
Let's see who can come up with a solution, marketable or not -in the next week!
You have until next Saturday, August 31st @ midnight (your local time) to post pix of your attempts.
+5 extra points for genuinely successful.
+10 extra points for genuinely entertaining.
Highest score gets the powdered remnants of my pair of OEM foam pads sent in a plastic bag.
Lowest score gets front row tix to the 2013 Cliffrow Choir Xmas Xtravaganza.
  • One fancy gun
Puncher
Durham
Posts 11,729
Puncher replied on Fri, Aug 23 2013 7:47 PM
ɓʋɾɑɳɫɘɮ:
Rich:
How thick are they? Is there any "internal" form or are they just flat foam stuck to a card with a hole in it? (Wouldn't flat acoustically transparent "foam cut to shape and stuck to a card with a hole in it" work)? Why not?
Ban boring signatures!
Puncher
Durham
Posts 11,729
Puncher replied on Fri, Aug 23 2013 8:03 PM
Material shouldn't be a problem.
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
-50 points to Pounchy for unentertaining content.
  • One fancy gun
Page 1 of 2 (66 items) 1 2 Next > | RSS
DigiCert Secured Site Seal
