Sandyb:Same here! IPhone got properly hot these last few days.....
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: Sandyb: Same here! IPhone got properly hot these last few days..... You can see under settings which app that consumes battery.
Same here!
Smart!
That confirms my suspicion. For the past 24 hours the B&O app consumed 72% of my battery !
Hi guys
Regarding the battery issue, we're on it. Getting quite hot in my pocket as well and sucks battery really fast. Will make a hotfix as soon as we have a solution.
Thomas, Bang & Olufsen
MrAndersen: @badgersurf: DLNA is supported. Settings->Music->DLNA and add your server? Could you please send a feedback on the missing MK1 then we will look into it
After deleting the app and doing a factory reset on the moment and Essences I have managed to get the DLNA working on the Mk2 Essence, but the Mk1 now shows up the music from my beomaster 5 but will not add it to the queue and will not play anything. the only thing I can get to work is Tunin (forgot that the Mk1 does not support deezer). Any idea as how to get music to play from the Beomaster 5 via DLNA and the app on a MK1 essence?
Toby
MrAndersen: Hi guys Regarding the battery issue, we're on it. Getting quite hot in my pocket as well and sucks battery really fast. Will make a hotfix as soon as we have a solution. Thomas, Bang & Olufsen
Dear MrAndersen,
first thank you, for taking on a new aproach with the App. Are there any plans to integrate a shuffle button for DLNA-content / DLNA-playlists in the near future? I can access all DLNA-content, but a shuffle-option for my playlists would be a really great option. My playlists are usually sorted by genres (Blues, Jazz, Pop, Rock...) If I start the playlist „blues“ now, it becomes very boring after a while, because it always starts with the same sequence of songs.
Maybe have a look on the ios app 8player. There is a shuffle option integrated. Or you could ad a section in the setting to turn on/off shuffle in general.
BR
Beroli
The shuffle function shows up in the BLGW programming screen. Therefore, maybe it is possible? We also need the ALL JOIN feature.
I'm finding with the new app that often not all of my devices will show up in the multi-room tab. However, I can join devices manually by using the on-device physical control.
+ 1000 for shuffle
Let's avoid always-the same-order boring playlists, especially when a single playlist hosts all the songs (ca 4000)!
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Another remark: Music from iTunes/Library/Songs displays only iTunes purchases and not AppleMusic downloads. Any chance to include downloads too?
+1000 for shuffle-play ... for me the most missing feature
Second would be the possibility to have volume-control on a BeoLink Converter!
vlohjr1:Does anybody experience that the new app drains the iPhone battery very quickly? It never happens with the old app?
Unknowin if it is related to battery drain, but I've noticed that the new app makes my iPhone hot, but now that you've mentioned it, yes, I've noticed a bit of a battery drain. However, I can live with that as long as the app isn't at the front, mainly because it does work better than BeoMusic.
Sal:Unknowin if it is related to battery drain, but I've noticed that the new app makes my iPhone hot, but now that you've mentioned it, yes, I've noticed a bit of a battery drain. However, I can live with that as long as the app isn't at the front, mainly because it does work better than BeoMusic.
Eclipse 65V1-32Beosound M5Essence MK2BLI
Hi!
any news about timer?
Seanie_230:Hi not sure if you are aware it there was a second beta yesterday with bug fixes so maybe try that BLGW - Rekindling the love of ML
steve1977:The latest beta includes support for legacy devices (e.g., beolit 12). it doesn't work for me. can anyone confirm that this is working?
Same here. It says support for legacy products and lists Beolit 12. In what way should this support manifest itself? I tried to go to "add new product" in the app, but my Beolit 12 is not discovered. I even tried a reset of the Beolit 12. On the other hand, how could it? It's not a beolink multiroom product, after all.
Does anybody know what kind of functionality one is supposed to get out of using these non-beolink legacy products with the app?
-h.
Hi Guys
Just to clarify. The support for A8, Playmaker, BeoPlay A9 MKI and BeoLit 12 is setup only. Those products cannot do more than they could before, that would require a software update of the products themselves and no further development is being done on those platforms. Sorry.
Best regards
Thomas Andersen, Bang & Olufsen
Mr Andersen,
steve1977:Thanks for the info. That's a pity. i still love my white Beolit. Hope remains that airplay 2 may support it...
Apple have said that supporting AirPlay 2 requires software or hardware updates to the speakers themselves. If Beolit 12 is no longer being developed, it will not receive these updates and therefore I don't see how it would ever work with AirPlay 2. However, AirPlay 1 speakers will likely continue to work with iOS and Mac OS just as before for many years to come.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
How about adding product icons for a slanted turntable (BeoGram 4500, 3000, 9000, etc.) and for a stacked system (BeoSystem 7000).
Hi
I have a Beo 14 40
Please could you add me to the beta programme for the iPad app
thanks
Bernard Howard
12 Nov 2917
Question. DLNA. Are cover art under albums supported in the app?
I currently use Synology NAS->LMS->Airplay Plugin->A6. Controlled via the iPeng app on iOS.
What do you mean by ‘cover art....supported’?
Do you mean when browsing the files - or in the player window when playing back?
Millemissen:What do you mean by ‘cover art....supported’?Do you mean when browsing the files - or in the player window when playing back?
No, you don’t get any album art in that list - you get it, when you open an album and see the tracks in it.
Don’t confuse the power of the LMS with the general weakness of a DLNA server (there might be different views for different servers and different players).
In the above example (using iPeng) is shown, what the main LMS server is capable of.
In the lower example is shown, what the DLNA part (it is a part of the current LMS server) is capable of in the app.
P.S. I still have my old Squeezebox Touch connected to the line-in of my Essence - just in case I want to browse my files more intense.
Imust admit, that I don’t do that very often - the convenience of staying in and controlling everything in one app is more appealing to me.
Why don’t you use the Jukebox to browse your collection, when you use the Moment as the player?
That might give you other options (?)
Thinking a bit more about this, I noticed that you wrote that you use an airplay plugin in the LMS server in order to airplay to the (in the example above) BeoPlay A6.
Since the (in the lower example) BS Moment has no support for airplay, you have to stick to the (plain) DLNA part of the LMS there.
On a side note: what is that plugin called, please?
Millemissen:On a side note: what is that plugin called, please?
MrAndersen: Hi all I'm sorry for my absence as of late. First of all, it has been a well-earned and needed summer holiday second, we have been brewing on something new. First some background. When we announced that we would remove BeoMusic we received a lot of negative feedback on the new app, both for missing features, but also on our UX approach in general. In any software team and in any company this creates some stir and cause for reflection on our work so far. We came to realize that we agreed with many of the grievances of our users and if we wanted to change track we should act now. So, we got to work with fresh eyes and with all the complaints given in our feedback channel both politely and angrily. This resulted in an entirely new navigation pattern and a new and Deezerless onboarding experience. We have also put the products we know you love front and center, in other words given them the position they deserve. This is just to mention a few things, there is much more. We have just put the very first beta of this on TestFlight (in review as of writing, should be out shortly) and would love you to check it out. Bear in mind this is early bits and still rough around the edges. This is the highlights New navigation New Home view for easy and beautiful product access Easier multiroom control Easier access to standby New player New onboarding experience (no Deezer unless you want it!) New product settings page Known issues Occasional products become unreachable, we would love to hear if you experience this Multiroom group disappears from the app in setups with many access points Product takes a few seconds to connect when coming from the background Meta data flickering in player bar Some product images are missing If you are a beta tester please use the feedback in the app for bug reports. If you are not a beta tester, please drop me a message in here and I will add you. Looking forward to your comments. Best regards, Thomas Andersen, Bang & Olufsen
Hi all
Known issues
Best regards,
This was Thomas' announcement in August last year .... since then after some testing by y'all we have seen the public release (version 1.6).
There now appears to be a NEW beta at version 1.7 that came out this weekend.
I am not sure which Beta thread we should use - I have posted this news in two.
The beta contents are:
1. Tone Touch (I have no idea what this is !)
2. Video during Login ... looks nice, but once logged in you don't see it again :(
Oh, and I have found I minor UI bug related to not being logged into Deezer with the account refresh.
BeoNut since '75
Are there any updates? The progress in the new app is mind-boggeling slow although in the right direction. I’m missing some basic functionality — the app should be as versatile as a beo-remote.
Hiort:I cannot figure out how to access my content...
mbolo01:Fully close the app and restart it BS Moment, BL 18, BL 19, A6, M5, A1, H5
