New app release hits beta
This post has 155 Replies | 5 Followers
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Aug 24 2017 12:45 PM
Sandyb:
Same here!
IPhone got properly hot these last few days.....
You can see under settings which app that consumes battery.
CasperI
Posts 93
CasperI replied on Thu, Aug 24 2017 1:13 PM
Hiort:
Sandyb:
Same here!
Smart!
That confirms my suspicion. For the past 24 hours the B&O app consumed 72% of my battery !
MrAndersen
Posts 226
Hi guys
Regarding the battery issue, we're on it. Getting quite hot in my pocket as well and sucks battery really fast. Will make a hotfix as soon as we have a solution.
Thomas, Bang & Olufsen
badgersurf
Posts 539
MrAndersen:
@badgersurf: DLNA is supported. Settings->Music->DLNA and add your server? Could you please send a feedback on the missing MK1 then we will look into it
After deleting the app and doing a factory reset on the moment and Essences I have managed to get the  DLNA working on the Mk2 Essence, but the Mk1 now shows up the music from my beomaster 5 but will not add it to the queue and will not play anything. the only thing I can get to work is Tunin (forgot that the Mk1 does not support deezer). Any idea as how to get music to play from the Beomaster 5 via DLNA and the app on a MK1 essence?
Toby
Beroli
Germany
Posts 316
Beroli replied on Thu, Aug 24 2017 11:35 PM
MrAndersen:
Hi guys
Dear MrAndersen,
first thank you, for taking on a new aproach with the App. Are there any plans to integrate a shuffle button for DLNA-content / DLNA-playlists in the near future? I can access all DLNA-content, but a shuffle-option for my playlists would be a really great option. My playlists are usually sorted by genres (Blues, Jazz, Pop, Rock...) If I start the playlist „blues“ now, it becomes very boring after a while, because it always starts with the same sequence of songs.
Maybe have a look on the ios app 8player. There is a shuffle option integrated. Or you could ad a section in the setting to turn on/off shuffle in general.
BR
Beroli
Sandyb
Posts 2,186
Sandyb replied on Thu, Aug 24 2017 11:55 PM
+1 for shuffle!
beojeff
USA
Posts 2,012
beojeff replied on Fri, Aug 25 2017 11:37 AM
The shuffle function shows up in the BLGW programming screen. Therefore, maybe it is possible? We also need the ALL JOIN feature.
I'm finding with the new app that often not all of my devices will show up in the multi-room tab. However, I can join devices manually by using the on-device physical  control.
YannChris
Larmor Plage - France
Posts 232
YannChris replied on Fri, Aug 25 2017 3:51 PM
+ 1000 for shuffle
Let's avoid always-the same-order boring playlists, especially when a single playlist hosts all the songs (ca 4000)!
Thanks  Stick out tongue
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
AnalogPlanet
Vienna, Austria
Posts 678
Another remark: Music from iTunes/Library/Songs displays only iTunes purchases and not AppleMusic downloads. Any chance to include downloads too?
ChrisBerlin
Posts 36
+1000 for shuffle-play ... for me the most missing feature
Second would be the possibility to have volume-control on a BeoLink Converter!
vlohjr1
Posts 553
vlohjr1 replied on Thu, Sep 14 2017 10:18 PM
Does anybody experience that the new app drains the iPhone battery very quickly? It never happens with the old app?
Sal
California, USA
Posts 1,197
Sal replied on Thu, Sep 14 2017 10:31 PM
vlohjr1:
Unknowin if it is related to battery drain, but I've noticed that the new app makes my iPhone hot, but now that you've mentioned it, yes, I've noticed a bit of a battery drain. However, I can live with that as long as the app isn't at the front, mainly because it does work better than BeoMusic.
vlohjr1
Posts 553
vlohjr1 replied on Thu, Sep 14 2017 11:34 PM
Sal:
Yes it also makes my phone hot as well thanks for confirming
steve1977
Posts 911
steve1977 replied on Fri, Sep 15 2017 12:04 AM
The latest beta includes support for legacy devices (e.g., beolit 12). it doesn't work for me. can anyone confirm that this is working?
Seanie_230
UK
Posts 2,278
Hi not sure if you are aware it there was a second beta yesterday with bug fixes so maybe try that
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
liviu_o
Posts 157
liviu_o replied on Fri, Sep 15 2017 6:50 AM
Hi!
any news about timer?
steve1977
Posts 911
steve1977 replied on Fri, Sep 15 2017 8:53 AM
Seanie_230:
Hi not sure if you are aware it there was a second beta yesterday with bug fixes so maybe try that BLGW - Rekindling the love of ML
i've seen the bug fix data, but didn't help to find the beolit. anyone succeeded?
Henrik
Norway
Posts 165
Henrik replied on Fri, Sep 15 2017 8:56 AM
steve1977:
Same here. It says support for legacy products and lists Beolit 12. In what way should this support manifest itself? I tried to go to "add new product" in the app, but my Beolit 12 is not discovered. I even tried a reset of the Beolit 12. On the other hand, how could it? It's not a beolink multiroom product, after all.
Does anybody know what kind of functionality one is supposed to get out of using these non-beolink legacy products with the app?
-h.
MrAndersen
Posts 226
Hi Guys
Just to clarify. The support for A8, Playmaker, BeoPlay A9 MKI and BeoLit 12 is setup only. Those products cannot do more than they could before, that would require a software update of the products themselves and no further development is being done on those platforms. Sorry.
Best regards
Thomas Andersen, Bang & Olufsen
steve1977
Posts 911
steve1977 replied on Fri, Sep 15 2017 10:36 AM
Thanks for the info. That's a pity. i still love my white Beolit. Hope remains that airplay 2 may support it...
liviu_o
Posts 157
liviu_o replied on Fri, Sep 15 2017 2:32 PM
Mr Andersen,
tph
Denmark
Posts 161
tph replied on Fri, Sep 15 2017 3:30 PM
steve1977:
Apple have said that supporting AirPlay 2 requires software or hardware updates to the speakers themselves. If Beolit 12 is no longer being developed, it will not receive these updates and therefore I don't see how it would ever work with AirPlay 2. However, AirPlay 1 speakers will likely continue to work with iOS and Mac OS just as before for many years to come.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Wed, Sep 27 2017 7:45 AM
Wake up Lan now enabled, great! App is getting there, keep up the good work.
Still waiting for color choice on product icons in homepage and finetuning the colorbalance between white/greys and blacks in app pages
beojeff
USA
Posts 2,012
beojeff replied on Wed, Sep 27 2017 1:25 PM
How about adding product icons for a slanted turntable (BeoGram 4500, 3000, 9000, etc.) and for a stacked system (BeoSystem 7000).
Riverscene
Posts 1
Riverscene replied on Sun, Nov 12 2017 11:36 AM
Hi
I have a Beo 14 40
Please could you add me to the beta programme for the iPad app
thanks
Bernard Howard
12 Nov 2917
Fansastic
Posts 768
Fansastic replied on Mon, Nov 13 2017 8:45 PM
I have a question regarding the BV14/Horizon implementation in the app, is it the app that needs to be updated, the TV software or both?
I’ve be waiting for this implementation for many months and checking for updates on a daily basis but not sure what is needed. Dev team of the app says they are almost there and very interested when to expect this feature in the beta release?
jimcaj
Denmark
Posts 126
jimcaj replied on Wed, Nov 15 2017 2:25 PM
Question. DLNA. Are cover art under albums supported in the app?
I currently use Synology NAS->LMS->Airplay Plugin->A6. Controlled via the iPeng app on iOS.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Nov 15 2017 2:32 PM
Nope
Millemissen
Flensborg, Denmark
Posts 14,680
What do you mean by ‘cover art....supported’?
Do you mean when browsing the files - or in the player window when playing back?
jimcaj
Denmark
Posts 126
jimcaj replied on Wed, Nov 15 2017 5:18 PM
Millemissen:
Something like this from iPeng
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Nov 15 2017 10:00 PM
Nope
Millemissen
Flensborg, Denmark
Posts 14,680
No, you don’t get any album art in that list - you get it, when you open an album and see the tracks in it.
Don’t confuse the power of the LMS with the general weakness of a DLNA server (there might be different views for different servers and different players).
In the above example (using iPeng) is shown, what the main LMS server is capable of.
In the lower example is shown, what the DLNA part (it is a part of the current LMS server) is capable of in the app.
P.S. I still have my old Squeezebox Touch connected to the line-in of my Essence - just in case I want to browse my files more intense.
Imust admit, that I don’t do that very often - the convenience of staying in and controlling everything in one app is more appealing to me.
Why don’t you use the Jukebox to browse your collection, when you use the Moment as the player?
That might give you other options (?)
Millemissen
Flensborg, Denmark
Posts 14,680
Thinking a bit more about this, I noticed that you wrote that you use an airplay plugin in the LMS server in order to airplay to the (in the example above) BeoPlay A6.
Since the (in the lower example) BS Moment has no support for airplay, you have to stick to the (plain) DLNA part of the LMS there.
Millemissen
Flensborg, Denmark
Posts 14,680
On a side note: what is that plugin called, please?
jimcaj
Denmark
Posts 126
jimcaj replied on Thu, Nov 16 2017 4:06 AM
Millemissen:
Airplay bridge.
Sorry. Didn’t want to highjack this thread. No more LMS talk from me Smile
elephant
AU
Posts 8,219
elephant replied on Sun, Mar 11 2018 5:11 PM
MrAndersen:
Hi all
I'm sorry for my absence as of late. First of all, it has been a well-earned and needed summer holiday second, we have been brewing on something new. First some background. When we announced that we would remove BeoMusic we received a lot of negative feedback on the new app, both for missing features, but also on our UX approach in general. In any software team and in any company this creates some stir and cause for reflection on our work so far. We came to realize that we agreed with many of the grievances of our users and if we wanted to change track we should act now. So, we got to work with fresh eyes and with all the complaints given in our feedback channel both politely and angrily. This resulted in an entirely new navigation pattern and a new and Deezerless onboarding experience. We have also put the products we know you love front and center, in other words given them the position they deserve. This is just to mention a few things, there is much more.
We have just put the very first beta of this on TestFlight (in review as of writing, should be out shortly) and would love you to check it out. Bear in mind this is early bits and still rough around the edges.
This is the highlights
  • New navigation
  • New Home view for easy and beautiful product access
  • Easier multiroom control
  • Easier access to standby
  • New player
  • New onboarding experience (no Deezer unless you want it!)
  • New product settings page
Known issues
  • Occasional products become unreachable, we would love to hear if you experience this
  • Multiroom group disappears from the app in setups with many access points
  • Product takes a few seconds to connect when coming from the background
  • Meta data flickering in player bar
  • Some product images are missing
If you are a beta tester please use the feedback in the app for bug reports. If you are not a beta tester, please drop me a message in here and I will add you. Looking forward to your comments.
Best regards,
This was Thomas' announcement in August last year .... since then after some testing by y'all we have seen the public release (version 1.6).
There now appears to be a NEW beta at version 1.7 that came out this weekend.
I am not sure which Beta thread we should use - I have posted this news in two.
The beta contents are:
1. Tone Touch (I have no idea what this is !)
2. Video during Login ... looks nice, but once logged in you don't see it again :(
Oh, and I have found I minor UI bug related to not being logged into Deezer with the account refresh.
BeoNut since '75
L1NO
Posts 250
L1NO replied on Tue, May 29 2018 7:44 AM
Are there any updates? The progress in the new app is mind-boggeling slow although in the right direction. I’m missing some basic functionality — the app should be as versatile as a beo-remote.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, May 31 2018 7:31 AM
New Beta out. 1.9.0.13459
GUI is now changed.
Must be something wrong.... I don´t get it.
Its just a number of tiles. The tabs in the bottom is removed. I cannot figure out how to access my content...
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, May 31 2018 7:39 AM
Hiort:
Fully close the app and restart it
jans
Belgium
Posts 394
jans replied on Thu, May 31 2018 7:46 AM
mbolo01:
Fully close the app and restart it BS Moment, BL 18, BL 19, A6, M5, A1, H5
Correct. I had to do the same.
Has anyone noticed other changes than the new Home page?
Page 3 of 4 (156 items) < Previous 1 2 3 4 Next > | RSS
