seethroughyou:I couldn’t get the problems resolved and they got worse when I used my NAS or Deezer Hifi (elite) so returned it for a full refund. Now using Roon off my Mac and it is absolutely exquisite and 100% reliable. Will buy a small MacMini, load Roon and keep it hidden away in a cupboard feeding the BL90 with a USB digital stream. Check out Roon.
- Flere
smile and enjoy the moment
No, I just download albums I really like to my NAS and happy to pay for them to support the classical music labels. I had considered Tidal (which Roon allows) but heard that it isn't as good as Deezer for classical. Deezer wasn't in my perspective good enough for classical in terms of depth of material so Tidal is likely worse still for classical. It's great for Jazz, Rock, Electronic, Taylor Swift etc...but not for serious classical listeners. I have for now decided that for me, the best option is to download albums from Chandos, Deutsche Grammophon, Naxos...etc. Streaming services for classical have a long way to go. Have heard from others though that Roon and Tidal work seamlessly!
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
seethroughyou:No, I just download albums I really like to my NAS and happy to pay for them to support the classical music labels. I had considered Tidal (which Roon allows) but heard that it isn't as good as Deezer for classical. Deezer wasn't in my perspective good enough for classical in terms of depth of material so Tidal is likely worse still for classical. It's great for Jazz, Rock, Electronic, Taylor Swift etc...but not for serious classical listeners. I have for now decided that for me, the best option is to download albums from Chandos, Deutsche Grammophon, Naxos...etc. Streaming services for classical have a long way to go. Have heard from others though that Roon and Tidal work seamlessly!
seethroughyou:On my BL90 and Roon you can change volume three ways. 1. Change using IR eye and Essence remote. 2. Change using BL90 app 3. Change in Roon I use option 1. You must try Roon - it is beautiful and sophisticated.
seethroughyou: You must try Roon - it is beautiful and sophisticated.
Those, who are interested in the Roon software - and find a Mac Mini a bit to much/overkill - might be interested in these articles from an expert:
http://archimago.blogspot.com/search?q=Roon
