Beware of firmware version 1.15.16926
This post has 166 Replies | 6 Followers
andy_js
Englandshire
Posts 223
andy_js replied on Fri, Jan 12 2018 12:34 PM
Roger:
Quick update from Struer:
They are confident all remaining issues will be solved by the next sw update - expected released within 2 weeks.
It would be nice if they had waited until then, rather than release this beta quality software.
andy_js
Englandshire
Posts 223
andy_js replied on Sat, Jan 13 2018 10:52 PM
1.15.17882.117133709 just came out.  I'm not sure what the changes are.
mbee
Paris, France
Posts 1,842
mbee replied on Sun, Jan 14 2018 8:52 AM
Currently not available on my Essence and A9...
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Jan 14 2018 10:46 AM
mbee:
Only on BS1 and M5 as of now.
1990
Posts 521
1990 replied on Sun, Jan 14 2018 11:50 AM
My M5 is on 1.15.17882.117133709 since Thursday, smooth operation, no drop-outs yet. Some lag on Deezer HiFi, but I guess that's my slow internet more than Beo-firmware
Roger
Norway
Posts 417
Roger replied on Tue, Jan 16 2018 7:56 AM
Still waiting for the major sw upgrade, but the wireless speakers (incl Essence mk2) is now working without any issues at all - they incremental fixes lately must have done something right. Great work by the sw team!
Roger
AnalogPlanet
Vienna, Austria
Posts 678
Lucky you.
My A9Mk2 now randomly stops Deezer playback and sits silent, just too tired with B&O issues honestly. Even the B&O app coming frequently to halt mode... ...close, reopen and hope it works next time.
Millemissen
Flensborg, Denmark
Posts 14,680
Not saying, that this could cause trouble in a NL environment, but it surely shows how complicated things have become nowadays....
....at least when you want to mix devices from different vendors - each having ‘their way’ of doing things.
http://4k.com/news/4k-streaming-fans-beware-google-chromecast-google-home-are-ruining-wifi-connections-23034/
jimcaj
Denmark
Posts 126
jimcaj replied on Tue, Jan 16 2018 1:04 PM
Roger:
Good to know. I'm still hoping for an A6 update arriving before Feb. That's when the warranty runs out. Fingers crossed.
AnalogPlanet
Vienna, Austria
Posts 678
Millemissen:
Not saying, that this could cause trouble in a NL environment...
Well, I think you might be right. Too bad I can't turn disable Google Cast to test it (there is no "Turn Google Cast off" controls within B&O app or I might be overlooking it).
Today's log btw says: "Google cast doesn't start after update, disable google cast". Well, I did not update the A9 recently but still I'm suspicious it might indicate something linked to Cast issues as you said... Let's see.
andy_js
Englandshire
Posts 223
andy_js replied on Tue, Jan 16 2018 10:58 PM
To B&Os credit I think the issues are finally solved.  My BeoSound 1 & 2 are working great.
Millemissen
Flensborg, Denmark
Posts 14,680
AnalogPlanet:
Millemissen:
It seems that Google has admitted that they have to work on the Chromecast devices to eliminate these troubles.
http://www.techradar.com/news/google-device-disrupting-your-wi-fi-a-fix-is-on-the-way
Just hoping that these changes/fixed will be considered for the Cast part of the B&O devices as well - as far as/if these are affected from the problems.
Not being able to use Chromecast on my Essence box at the moment (current public sw version, with a momentary disabled Chromecast version: 1.25.91810) is a pia.........sometimes.
jimcaj
Denmark
Posts 126
jimcaj replied on Fri, Jan 26 2018 2:23 PM
Roger:
Quick update from Struer (Jan 12 2018):
Any news on the A6 update?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Jan 26 2018 2:42 PM
AnalogPlanet:
Actually you can do a factory reset. Then during reinstalling do not accept Googles Chromecast conditions. Chromecast is not "switched on".
I did so with my Essences, A6 and BS35. Since then no dropouts or any problems at all.
Millemissen
Flensborg, Denmark
Posts 14,680
Roger:
More than 2 weeks have passed now!
Any news?
Roger
Norway
Posts 417
Roger replied on Fri, Feb 2 2018 12:52 PM
@MM:
B&O sw dept issued a statement on Tuesday confirming that they have managed to identify the wifi issue and fix it. Tests so far shows that the issue is solved, but they will continue with more extensive test cycles to rule out as many side effects as possible (finally?). The release is said to be "in the next weeks" or as soon as possible - if there are no side effects.
Roger
bab
Posts 22
bab replied on Fri, Feb 2 2018 1:02 PM
Any word on whether Google Chromecast built-in will work in this new release?
wditters
Posts 5
wditters replied on Sun, Feb 18 2018 11:57 AM
So last sign from B&O was on January 30th. Still no firmware update. Since I am a Tidal user and not a Spotify user, this has effectively crippled my 2 A6's and my A9 ... Really hard pressed to sell them all and select Bluesound products going forward ...
koning
holland
Posts 4,220
koning replied on Sun, Feb 18 2018 1:14 PM
I bought a bluesound node II
No wifi dropouts  no app problems no nas problems
E 549,00 Euro's   Great audio quality
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Feb 18 2018 3:30 PM
I’m on the beta track and received beta 1.16.19505 for my A6 and 1.16.19506 for my M5 and BS1.
That reinstated Cromecast on the A6.
I do not use Chromcast regularly but the times I tried it worked with no problems. Have a group including all my devices.
Experience no dropouts.
/C
Ulrike
Germany
Posts 174
Ulrike replied on Sun, Feb 18 2018 6:04 PM
Hiort:
Thanks Hiort for informing.
If you're experiencing any issues would you keep us informed, please?
I got a firmware rollback by Beocare end of December to enable Chromecast again for my A6. So far everything works flawlessly for my 4 speakers GCC Multiroom. So, being wary, I disabled the automatic firmware update for my B&O speakers.
GCC I definitely need because sadly it's the only way for streaming Qobuz to B&O speakers.
Thanks in advance.
Ulrike
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Feb 19 2018 2:07 PM
Ulrike:
I will Smile
wditters
Posts 5
wditters replied on Tue, Feb 20 2018 8:14 AM
How does one enter the beta testing group?
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Feb 21 2018 10:48 AM
Received a new beta version yesterday.
Think a public release is very close now.
wditters
Posts 5
wditters replied on Mon, Feb 26 2018 10:54 AM
Truly hope so ... Chromecast is critical in my Tidal and Android centric household ...
jimcaj
Denmark
Posts 126
jimcaj replied on Mon, Feb 26 2018 2:02 PM
Hiort:
I saw dropouts on my A6 with Deezer and Wifi on the current official fw ...640. I gave up using it in december, when the word was a release within few weeks.
Well - still waiting.
Ulrike
Germany
Posts 174
Ulrike replied on Mon, Feb 26 2018 6:32 PM
Thanks Hiort for keeping us informed :)
So we will wait for things to come.
Millemissen
Flensborg, Denmark
Posts 14,680
Roger:
Roger:
@MM:
Roger
‘within two weeks’ - ‘in the next weeks’....hmmmm!
Long gone now!
Anyway, as long as they are getting things right, it’s ok....I guess.
My Essence (MK2) is still on 1.15 .17881
(By the way - now as before - with no issues apart from the missing Cast support)
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Feb 27 2018 11:31 PM
Hopefully the requirements for their new s/w engineers includes a thorough knowledge of and understanding of regression testing methodology.
Jeff
seethroughyou
UK
Posts 999
Jeff:
Jeff
Beovirus victim, it's gotten to be too much to list!
I can guarantee you that they won’t bother with this at all.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
jimcaj
Denmark
Posts 126
jimcaj replied on Wed, Feb 28 2018 5:50 AM
Finally. New A6 fw installed. 1.16.20033.
I just tested Deezer Hi-Fi in group with M3 for over half an hour. Over Wi-Fi. No dropouts so far. On the earlier fw, I had dropouts after 5-10 mins.
Looking good
Roger
Norway
Posts 417
Roger replied on Wed, Feb 28 2018 8:28 AM
Some news as of Feb 28th and new SW releases:
-                     Beoplay A6, Beoplay A9 (2nd gen.), BeoSound Essence (2nd gen.), BeoSound 35: v.1.16.20033
-                     Beoplay M5, BeoSound 1, BeoSound 2: v.1.16.19506
-                     BeoSound Core: v. 1.1.19507
-                     Beoplay M3: v.1.1.19508
These software versions fix/improve the following issues:
-                     WiFi connectivity issues are now fixed
-                     Chromecast built-in functionality is now restored (was affecting only Beoplay A6 and Beoplay A9)
-                     Essence Remote robustness is restored
-                     Fixing issues related to TuneIn radio
-                     Solve some of the lately experienced multiroom issues (we still know that there are some more open multiroom issues, that will be addressed in next following software releases)
-                     Improved First Time Setup experience, with the latest Bang & Olufsen App
-                     The Essence Remote can now be used also over IR (with BeoSound Essence Box) and behave the same way as when used over Bluetooth (i.e. it can also JOIN)
Roger
Norway
Posts 417
Roger replied on Wed, Feb 28 2018 8:37 AM
On a side note:
Hooked up a Google Home Mini (approx. $50) in the same room as the BeoSound 2, told the app that Spotify is my preferred music provider and that the Mini should play any music through the BS2 (and not the tiny Mini's speaker). Now the Mini will talk back when asked "smart speaker" questions regarding calendar, weather, news etc - and I can just say "Hey Google", as I enter the room, followed by "play some Bruce Springsteen" - and the BS2 comes to life and plays. No phone, no app. You can even use a single Mini to control all the wireless (chromecast) B&O speakers by saying "play Diana Krall on chromecast your-device-name".
Super easy to say "Hey Google, wake me up with music at 7 am". Google will then ask for type of music, and you can use e.g. Spotify or TuneIn, given playlists etc.
Suddenly my BS2 is more advanced than the HomePodBig Smile
Roger
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Feb 28 2018 9:09 AM
Roger:
Super! Thanks for sharing.
Millemissen
Flensborg, Denmark
Posts 14,680
Roger:
Thanks Roger ;-)
As of today......my Essence (MK2) has not yet updated - maybe tonight then ;-)
Question: Cast now restored/affected only A6 and A9?
Why are only A6/9 mentioned - my Essence hasn’t had Cast support for a while too.
Question: ‘Essence Remote can now be used......’?
Any more informations on this - user cases/exactly what is new (apart from joining)?
Chris Hassell
London
Posts 396
Very interested in the IR thing
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Roger
Norway
Posts 417
Roger replied on Wed, Feb 28 2018 9:39 AM
The Essence remote was fixed, but was un-fixed due to the roll-back of the SW. The roll-back quick fix had some side effects.
The wifi and cast issues (ie leaving the products useless) only affected the A6 and A9, the other wireless speakers "just" suffered from instability/drop-outsBig Smile
Hopefully this post goes through - I've put on the moderator's watch list (by request from Struer, I guessUnsure)
Roger
jimcaj
Denmark
Posts 126
jimcaj replied on Wed, Feb 28 2018 12:14 PM
@Roger: After the device fw updates of yesterday, I’ve experienced strange behaviour in the Beotool app. Crashes and wrong reporting. Update pending?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Feb 28 2018 2:04 PM
I was expecting M5 tone control with this release Sad
@jimcaj: BeoTool works for me
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen:
My Essence and also my M3 were now updated - I did it manually....could not wait ;-)
Cast is back on the Essence - what has changed by the M3, I don’t know (yet).
Page 4 of 5 (167 items) < Previous 1 2 3 4 5 Next > | RSS
