Beovision 4-50
This post has 22 Replies | 0 Followers
Shmuupie
Posts 8
Shmuupie Posted: Thu, Jul 19 2018 8:09 AM
so we just bought a house and the previous owners left their Beovision 4-50 (wall mounted) as a gift for us. Our other TVs are smart tv and we usually watch Netflix or amazon prime. I believe this is not a smart tv and doesn’t come with an hdmi port.
can anyone help me understand what exactly needs to be done to make this a smart tv or how to play Netflix or amazon prime on it. Sorry am not too tech savvy so not sure if it’s even possible. Thx
Barry Santini
New York
Posts 543
Just add an apple TV
elephant
AU
Posts 8,219
elephant replied on Sat, Jul 21 2018 10:15 AM
Use an Apple TV
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
Barry Santini:
elephant:
Use an Apple TV
Then you should also tell the op how to connect it!
elephant
AU
Posts 8,219
elephant replied on Sat, Jul 21 2018 12:57 PM
Millemissen:
Good point
It would help to know what is the backend.
Perhaps the OP can say which variant of the beosystem he has ?
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
I - for my part - would also want to wait, untill the op turns up again.
Important to know, whether he has just the panel left hanging on the wall...
....or if a System 2 etc etc is also there.
elephant
AU
Posts 8,219
elephant replied on Sat, Jul 21 2018 9:41 PM
Millemissen:
True
And doesn’t it have to be a System 3 to get HDMI in support ?
BeoNut since '75
Shmuupie
Posts 8
Shmuupie replied on Sat, Jul 21 2018 10:22 PM
Thank you for suggestions. Attaching a pic of the tv where the wires are. It is at the bottom side of the tv. Since we got our house repainted we have the tv off of its wall mount. https
Shmuupie
Posts 8
Shmuupie
Posts 8
Shmuupie
Posts 8
Shmuupie replied on Sat, Jul 21 2018 10:24 PM
The link didn’t show up
https://ibb.co/dBcTPJ
Millemissen
Flensborg, Denmark
Posts 14,680
Shmuupie:
Is that the only cable going from the tv?
No control box (what we call a BeoSystem) there?
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 22 2018 12:30 AM
Both MM and I are hoping that somewhere there is the B&O black box and also a B&O remote control !
And did they give you any manuals ?
See the pictures below ...
Remote = https://beocentral.com/beo4
Televisions (just for reference)
https://beocentral.com/search?q=BeoVision+4
https://beocentral.com/beovision4-50
https://www.beoworld.org/prod_details.asp?pid=546
With the paid BeoWorld membership you will have access to manuals should they be missing
This is the black box that MM and myself are looking for
https://www.beoworld.org/prod_details.asp?pid=961
Or it’s predecessor
https://www.beoworld.org/prod_details.asp?pid=960
or it’s successors
https://www.beoworld.org/prod_details.asp?pid=863
https://www.bang-olufsen.com/en/collection/televisions/beosystem-4
And from one of the manuals how they all are inter-connected included the IR-eye that the Beo4’s signals are received by and relayed through the systems
BeoNut since '75
Shmuupie
Posts 8
Shmuupie replied on Sun, Jul 22 2018 8:46 AM
There is no black box it was just the tv mounted on the wall with some wires hanging which we thought connected to DVD player or their cable box and that they took those with them.
Shmuupie
Posts 8
Shmuupie replied on Sun, Jul 22 2018 8:50 AM
This is how it was before we removed it for getting the house painted
https://ibb.co/nwNory
Millemissen
Flensborg, Denmark
Posts 14,680
Then you don’t have a tv - but a nicely framed Panasonic plasma display (which B&O used with the - missing - BeoSystem 2).
You can get some ideas for this here:
https://archivedforum2.beoworld.org/forums/p/4627/52867.aspx
elephant
AU
Posts 8,219
elephant replied on Mon, Jul 23 2018 2:47 AM
Millemissen:
That is the harsh verdict :(
If you have retained contact with the previous owners it may be worth ringing them for confirmation.
Also check what happened to the left & right BeoLab 3 speaker’s I think I see in the latest photo.
BeoNut since '75
Shmuupie
Posts 8
Shmuupie replied on Wed, Jul 25 2018 12:08 AM
The speakers are included but there wasn’t any black box. The image I posted is from the house’s listing online. This is how they had it mounted.
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Jul 25 2018 7:42 AM
Probably hidden somewhere in a cupboard/rack/closet.
Ask them if the movers took it with them….
Ralf
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 26 2018 12:46 AM
kallasr:
Ralf
Hopefully by accident
BeoNut since '75
poodleboy
Posts 303
poodleboy replied on Thu, Jul 26 2018 6:09 PM
Hate to be sacrilegious BUT here is an opinion: Toss the TV and get an appropriate size replacement with current tech, buy a simple A/V receiver to place where the BS2 was, place the BL3s CORRECTLY (and consider mounting one stop downward), connect the Speakers (using CORRECT cables from Steve) and TV to the A/V receiver, add your input devices, and be done with it. The BL3 are a treat and the BV4 not so much.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Jul 26 2018 10:58 PM
poodleboy:
Or buy an original Avant tube set and a pair of binoculars.
Jeff
elephant
AU
Posts 8,219
elephant replied on Fri, Jul 27 2018 9:48 AM
poodleboy:
BS9000, Essence, BeoLit12, MX4200, BL3000, BV11-55
If the beosystem X has gone, you are right.
I suspect BL3s also went.
So you are doubly right.
I have a sense the panel was left on the wall for the same reason you made your recommendation.
All a bit sad.
BeoNut since '75
Page 1 of 1 (23 items) | RSS
