so we just bought a house and the previous owners left their Beovision 4-50 (wall mounted) as a gift for us. Our other TVs are smart tv and we usually watch Netflix or amazon prime. I believe this is not a smart tv and doesn’t come with an hdmi port.
can anyone help me understand what exactly needs to be done to make this a smart tv or how to play Netflix or amazon prime on it. Sorry am not too tech savvy so not sure if it’s even possible. Thx
BeoNut since '75
Barry Santini:Just add an apple TV
elephant:Use an Apple TV
Then you should also tell the op how to connect it!
Millemissen:Then you should also tell the op how to connect it! MM There is a tv - and there is a BV.
I - for my part - would also want to wait, untill the op turns up again.
Important to know, whether he has just the panel left hanging on the wall...
....or if a System 2 etc etc is also there.
Millemissen:....or if a System 2 etc etc is also there
Thank you for suggestions. Attaching a pic of the tv where the wires are. It is at the bottom side of the tv. Since we got our house repainted we have the tv off of its wall mount. https
The link didn’t show up
https://ibb.co/dBcTPJ
Shmuupie: The link didn’t show up https://ibb.co/dBcTPJ
Is that the only cable going from the tv?
No control box (what we call a BeoSystem) there?
There is no black box it was just the tv mounted on the wall with some wires hanging which we thought connected to DVD player or their cable box and that they took those with them.
This is how it was before we removed it for getting the house painted
https://ibb.co/nwNory
Then you don’t have a tv - but a nicely framed Panasonic plasma display (which B&O used with the - missing - BeoSystem 2).
You can get some ideas for this here:
https://archivedforum2.beoworld.org/forums/p/4627/52867.aspx
Millemissen:Then you don’t have a tv - but a nicely framed Panasonic plasma display (which B&O used with the - missing - BeoSystem 2). You can get some ideas for this here: https://archivedforum2.beoworld.org/forums/p/4627/52867.aspx MM There is a tv - and there is a BV.
The speakers are included but there wasn’t any black box. The image I posted is from the house’s listing online. This is how they had it mounted.
Probably hidden somewhere in a cupboard/rack/closet.
Ask them if the movers took it with them….
Ralf
kallasr:Probably hidden somewhere in a cupboard/rack/closet.Ask them if the movers took it with them….Ralf
Hate to be sacrilegious BUT here is an opinion: Toss the TV and get an appropriate size replacement with current tech, buy a simple A/V receiver to place where the BS2 was, place the BL3s CORRECTLY (and consider mounting one stop downward), connect the Speakers (using CORRECT cables from Steve) and TV to the A/V receiver, add your input devices, and be done with it. The BL3 are a treat and the BV4 not so much.
poodleboy: Hate to be sacrilegious BUT here is an opinion: Toss the TV and get an appropriate size replacement with current tech, buy a simple A/V receiver to place where the BS2 was, place the BL3s CORRECTLY (and consider mounting one stop downward), connect the Speakers (using CORRECT cables from Steve) and TV to the A/V receiver, add your input devices, and be done with it. The BL3 are a treat and the BV4 not so much.
Or buy an original Avant tube set and a pair of binoculars.
Jeff
poodleboy:Hate to be sacrilegious BUT here is an opinion: Toss the TV and get an appropriate size replacement with current tech, buy a simple A/V receiver to place where the BS2 was, place the BL3s CORRECTLY (and consider mounting one stop downward), connect the Speakers (using CORRECT cables from Steve) and TV to the A/V receiver, add your input devices, and be done with it. The BL3 are a treat and the BV4 not so much. BS9000, Essence, BeoLit12, MX4200, BL3000, BV11-55
