LG 2019 OLED TV- WiSA Wireless- Soundbar- Dolby Atmos audio.
This post has 965 Replies | 3 Followers
pauliander
Posts 81
pauliander replied on Fri, Apr 26 2019 6:32 AM | Locked
Hi Peter, great thread!
Is there any news on smaller B&O wisa speakers such as for instance a Wisa beolab 3 or a Wisa center speaker?
Placing the beolab 17 as rear surround speakers in our living room is a no go for my wife...
Peter Pan
Posts 2,088
Peter Pan replied on Fri, Apr 26 2019 8:35 AM | Locked
HI pauliander, and thank you.
We can hopefully expect a larger range of WiSA compatible active speakers from Bang & Olufsen.
But at present I have not heard of such an initiative. Personally, I have requested one WiSA center
speaker designed to fit naturally under LG's C9 panels.
pauliander
Posts 81
pauliander replied on Fri, Apr 26 2019 11:20 AM | Locked
A very good idea that Wisa center speaker. It seems to me a gap in B&O’s range of Wisa of speakers.
Do you think that the LG usb dongle will suffice or will we still need a proper Wisa receiver? In other words is there a need that B&O develops a Wisa beosystem 5?
Peter Pan
Posts 2,088
Peter Pan replied on Fri, Apr 26 2019 1:08 PM | Locked
Yes, I think the WiSA usb dongle will be enough with LG's 2019 OLED TV, it's proven, see picture at the end of page 40.
Now, LG's 2019 OLED TV is coming out. Then there will soon be someone testing the WiSA usb dongle connected to
LG's 2019 OLED TV. We need some patience.
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Apr 27 2019 8:11 AM | Locked
Update from tomsguide.com - Click here.
Note this section:
Smart home interaction is vastly improved, with support for all manner of smart home devices.
LG has teamed up with the Open Connectivity Foundation (OCF), so you'll be able to control
all of your smart stuff — lightbulbs, door locks, smart washers and dryers, and more.
Anything that uses OCF's certification standard can be connected to the TV and controlled
from the comfort of your couch. - Click here.
Peter Pan
Posts 2,088
Peter Pan replied on Sun, Apr 28 2019 6:41 AM | Locked
Here is the user interface for controlling eg. OCF-compatible devices on LG TV:
Peter Pan
Posts 2,088
Peter Pan replied on Sun, Apr 28 2019 6:44 AM | Locked
May 2009 I bought BeoVision 7-40 Full HD, mk III. which also works fine today. I'm happy with that, because this
gives me good opportunity to follow the development of LG's TV, which will be my next TV. Here my setup today.
Peter Pan
Posts 2,088
Peter Pan replied on Sun, Apr 28 2019 9:16 AM | Locked
LG OLED C9 TV
Model C9 belongs to the lineup of OLED TVs LG 2019 and is the successor to last year's model C8 .  The main
differences between C9 and C8 are: the ports of the latest HDMI 2.1 standard, an upgraded video processor, an
updated webOS 4.5 platform with artificial intelligence functions, support for wireless multichannel WiSA sound,
and improved gaming performance due to VRR support (similar to Freesync). The design of the model largely
repeats last year’s, albeit with some changes.
The C9 model is available in three screen diagonal versions: 55, 65 and 77 inches (model designations for the
market are LG OLED55C9PLA, OLED65C9PLA and OLED77C9PLA).
HDMI 2.1
The newest HDMI 2.1 interface used in C9 provides many times more bandwidth than HDMI 2.0 (48 Gbit / s
versus 18 Gbit / s), which will allow displayingthe image in a higher resolution.  In particular, there was support
for 4K / 120 Hz mode.  In addition, HDMI 2.1 brought support for the Variable Refresh Ratefeature, which is
analogous to the AMD FreeSync and Nvidia G-Sync synchronization technologies, and Dynamic HDR will allow
for enhanced dynamic range (HDR) performance at a frame-by-frame level, which should further improve the image
quality on compatible monitors or tvs.  Also, the HDMI 2.1 standard includes Auto Low Latency Mode (ALLM)
technology, which automatically determines the optimal delay time for the smoothest frame rate. Inaddition, HDMI
2.1 provides a number of other useful features, including HDMI eARC, thereby providing lossless output and
transmission of audio through the HDMI eARC port. The LG C9 TV with support for the new High Definition
Multimedia Interface 2.1 is backward compatible with the peripherals of the previous version of the standard 2.0,
and also uses the familiar connectors.  However, to connect external devices with HDMI 2.1, you need to acquire
new cables marked Ultra High Speed ​​HDMI.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sun, Apr 28 2019 1:02 PM | Locked
Peter Pan:
Sure it will work like a charm behind a solid sheet of metal (The TV chassis),- not!
Then again who cares? If you cant cope with a simple wire for a speaker you truly deserve every single problem you will encounter!
Peter Pan
Posts 2,088
Peter Pan replied on Sun, Apr 28 2019 2:05 PM | Locked
@ BEOVOX141
   Let me google for you.
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen replied on Sun, Apr 28 2019 2:19 PM | Locked
@BEOVOX141
You know, Peter Pan has always been an advocate for very simple setups.
Peter Pan
Posts 2,088
Peter Pan replied on Sun, Apr 28 2019 2:34 PM | Locked
Magic Remote
An important advantage is the acquisition of the C9 model with the Magic Remote , which greatly improves
the ease of operation of the TV.  The main features of the LG Magic Remote are, of course, the cursor that
moves around the TV screen when you move the remote in space (a gyro is built into the remote).  In this
case, the remote does not necessarily have to be sent to the TV.
jvezina
Montreal, Canada
Posts 200
jvezina replied on Sun, Apr 28 2019 3:46 PM | Locked
Peter Pan:
Magic Remote
For people who are wondering, the Eclipse has this functionality implemented in the B&O app. Just go to the third screen and there is a virtual trackpad. The left part control the cursor. You move it over the TV screen and with a light tap you select the option. The rightmost part is used for scrolling.
Enjoy,
Jean
Peter Pan
Posts 2,088
Peter Pan replied on Mon, Apr 29 2019 8:43 AM | Locked
Interesting Jean.
What will then be easiest to use. B&O App or Magic Remote. Have an opinion about it.
jvezina
Montreal, Canada
Posts 200
jvezina replied on Tue, Apr 30 2019 4:54 AM | Locked
Peter Pan:
Interesting Jean.
Very simple: within the B&O environment, the B&O app. It can be used side by side with the Beoremote One. To my knowledge, the Magic Remote doesn't work with the Eclipse.
For a system based on a stock LG TV, obviously the Magic Remote!
For ease of use, that depends of your preferences. The virtual trackpad works like that of a computer. The magic remote works like a Wii controller. One of my relatives has a LG TV (not OLED) and use it.
Jean
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Tue, Apr 30 2019 6:34 AM | Locked
2019 LG C9 OLED 4K TV Full Review
www.youtube.com/watch?v=vkSOqbbuA28
Peter Pan
Posts 2,088
Peter Pan replied on Wed, May 1 2019 10:58 AM | Locked
A good YouTube video BEOVOX141.
The cheapest and most flexible solution with LG 55" C9 / AVR connection.
Here you choose your own speaker and Surround setup.
Guess where a center speaker is located. Note wooden slats on the doors.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, May 1 2019 8:06 PM | Locked
Robin
Nrw
Posts 107
Robin replied on Thu, May 2 2019 9:32 AM | Locked
Peter Pan:
Haven’t we’ve seen this picture quite som times? Moreover this is nothing new at all. We don’t need a LG c9 screen with WiSA dongle to attach it to an oldschool avr. I don’t see the point of putting it up all the times again.
I think we should rename this thread in PP’s personal blog...
Peter Pan
Posts 2,088
Peter Pan replied on Thu, May 2 2019 1:12 PM | Locked
@ Robin
Why do you feel sorry for seeing the possibilities available with a LG C9 OLED 4K TV. ?
SkiniPlay.   Possibly an upcoming opportunity.  Smile
Puncher
Durham
Posts 11,729
Puncher replied on Thu, May 2 2019 3:24 PM | Locked
Robin:
Peter Pan:
It seems nothing short of a direct hit from a tactical nuclear weapon will stop him! This must be very close to the top of list of worst ever threds on Beoworld!!Sleep
Ban boring signatures!
Peter Pan
Posts 2,088
Peter Pan replied on Thu, May 2 2019 3:50 PM | Locked
Puncher must like my thread since he returns.
Sandyb
Posts 2,186
Sandyb replied on Thu, May 2 2019 4:10 PM | Locked
Close to?
I can't believe there has been a worse thread?
It takes some kind of delusion to count the hundreds of complaints as a positive.
Peter Pan
Posts 2,088
Peter Pan replied on Thu, May 2 2019 4:22 PM | Locked
SandyB - Why just one thread, when we can have two.
Viewed 39,945 times. Thank you.
Sandyb
Posts 2,186
Sandyb replied on Thu, May 2 2019 4:26 PM | Locked
Strip out the complaints from that number
I guess some people care little for their credibility
OldJack
Split
Posts 371
OldJack replied on Thu, May 2 2019 4:28 PM | Locked
Still unclear to me.Is LG wisa dongle working or not?
P.S. Peter Pan,you are TZAR Unsure
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Puncher
Durham
Posts 11,729
Puncher replied on Thu, May 2 2019 4:54 PM | Locked
Peter Pan:
LaughingLaughingLaughing - 39,900 of them are just you!!
Peter Pan
Posts 2,088
Peter Pan replied on Fri, May 3 2019 5:52 AM | Locked
OldJack:
Hi OldJack
I hope to get the LG C9 / Dolby Atmos / WiSA dongle sound quality results from e.g recorders.dk /
flatpanelshd.com, as soon as they have had the opportunity to listen to this exciting opportunity.
Peter Pan
Posts 2,088
Peter Pan replied on Sat, May 4 2019 9:21 PM | Locked
Overview HDMI cable - hdmi.org.
Peter Pan
Posts 2,088
Peter Pan replied on Sun, May 5 2019 5:14 PM | Locked
ptrv:
Summit Wireless predicts 60 million units of WiSA Ready platforms will be on the market in 2019. Interesting.
We are still waiting for this. Indifferent
Peter Pan
Posts 2,088
Peter Pan replied on Sun, May 5 2019 6:12 PM | Locked
DIY -
Click here.
BeoLab 10, is a center speaker there each to recycle.
Peter Pan
Posts 2,088
Peter Pan replied on Tue, May 7 2019 6:55 AM | Locked
Download LG TV OLED55C9 - OLED65C9 Mamual - Click here.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, May 8 2019 8:39 AM | Locked
Click here.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Wed, May 8 2019 2:16 PM | Locked
Yikes, pure undiluted gadget-porn complete with a WISA logo. Ick!
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen replied on Wed, May 8 2019 4:33 PM | Locked
Odd setup....with upfiring speakers only at the back.
They probably ran out of WiSA channels 🤥
Peter Pan
Posts 2,088
Peter Pan replied on Thu, May 9 2019 7:12 AM | Locked
BEOVOX141:
gadget-porn
OK - I have to change that. Big Smile
Peter Pan
Posts 2,088
Peter Pan replied on Fri, May 10 2019 7:40 AM | Locked
LG C9 OLED TV. Reviewed on May 02, 2019. By Adam Babcock, Ian Cumming, Yannick Khong. -
Click here.
Note that at the end they write -
The C9 also supports WiSA wireless speaker technology, although we didn't test this, and
is expected to receive support for Apple HomeKit and AirPlay 2 in a future firmware update.
alexm86
Posts 2
alexm86 replied on Fri, May 10 2019 11:02 AM | Locked
The 2019 LG model all have the wisa capability but where can you actually buy the usb dongle?
I recently bought the C9 and plan was to connect Lab 18,19 and 3 via Wisa but so far still running it through the beolab transmitter.
Peter Pan
Posts 2,088
Peter Pan replied on Fri, May 10 2019 1:38 PM | Locked
Hi alexm86
It is a question we are many who will be happy to answer. This is the only thing I could find. Click here.
Peter Pan
Posts 2,088
Peter Pan replied on Fri, May 10 2019 3:02 PM | Locked
google - Where can i buy LG Innotek WiSA USB transmitter.
Maybe you find something I haven't found. Yes - thumbs up
During my search I found this.
TX Transmitter with USB Interface. (WiSA Transmitter).
This product is currently in development. To request more information, please contact us.
United Kingdom Tel: +44 (0)1702. - Click here.
NEW 2019 Profusion Short Form Catalogue. Download - https://www.profusionplc.com/brochures.php
Page 16 of 25 (966 items) « First ... < Previous 14 15 16 17 18 Next > ... Last » | RSS
DigiCert Secured Site Seal
