HI pauliander, and thank you.
We can hopefully expect a larger range of WiSA compatible active speakers from Bang & Olufsen.But at present I have not heard of such an initiative. Personally, I have requested one WiSA center speaker designed to fit naturally under LG's C9 panels.
Yes, I think the WiSA usb dongle will be enough with LG's 2019 OLED TV, it's proven, see picture at the end of page 40. Now, LG's 2019 OLED TV is coming out. Then there will soon be someone testing the WiSA usb dongle connected to LG's 2019 OLED TV. We need some patience.
Update from tomsguide.com - Click here.
Note this section:
Smart home interaction is vastly improved, with support for all manner of smart home devices. LG has teamed up with the Open Connectivity Foundation (OCF), so you'll be able to control all of your smart stuff — lightbulbs, door locks, smart washers and dryers, and more. Anything that uses OCF's certification standard can be connected to the TV and controlled from the comfort of your couch. - Click here.
Here is the user interface for controlling eg. OCF-compatible devices on LG TV:
May 2009 I bought BeoVision 7-40 Full HD, mk III. which also works fine today. I'm happy with that, because this gives me good opportunity to follow the development of LG's TV, which will be my next TV. Here my setup today.
LG OLED C9 TV
Model C9 belongs to the lineup of OLED TVs LG 2019 and is the successor to last year's model C8 . The main differences between C9 and C8 are: the ports of the latest HDMI 2.1 standard, an upgraded video processor, an updated webOS 4.5 platform with artificial intelligence functions, support for wireless multichannel WiSA sound, and improved gaming performance due to VRR support (similar to Freesync). The design of the model largely repeats last year’s, albeit with some changes.
The C9 model is available in three screen diagonal versions: 55, 65 and 77 inches (model designations for the market are LG OLED55C9PLA, OLED65C9PLA and OLED77C9PLA).
HDMI 2.1The newest HDMI 2.1 interface used in C9 provides many times more bandwidth than HDMI 2.0 (48 Gbit / s versus 18 Gbit / s), which will allow displayingthe image in a higher resolution. In particular, there was support for 4K / 120 Hz mode. In addition, HDMI 2.1 brought support for the Variable Refresh Ratefeature, which is analogous to the AMD FreeSync and Nvidia G-Sync synchronization technologies, and Dynamic HDR will allow for enhanced dynamic range (HDR) performance at a frame-by-frame level, which should further improve the image quality on compatible monitors or tvs. Also, the HDMI 2.1 standard includes Auto Low Latency Mode (ALLM) technology, which automatically determines the optimal delay time for the smoothest frame rate. Inaddition, HDMI 2.1 provides a number of other useful features, including HDMI eARC, thereby providing lossless output and transmission of audio through the HDMI eARC port. The LG C9 TV with support for the new High Definition Multimedia Interface 2.1 is backward compatible with the peripherals of the previous version of the standard 2.0, and also uses the familiar connectors. However, to connect external devices with HDMI 2.1, you need to acquire new cables marked Ultra High Speed HDMI.
Peter Pan:Yes, I think the WiSA usb dongle will be enough with LG's 2019 OLED TV
Sure it will work like a charm behind a solid sheet of metal (The TV chassis),- not!
Then again who cares? If you cant cope with a simple wire for a speaker you truly deserve every single problem you will encounter!
@ BEOVOX141
Let me google for you.
@BEOVOX141
You know, Peter Pan has always been an advocate for very simple setups.
Magic Remote An important advantage is the acquisition of the C9 model with the Magic Remote , which greatly improves the ease of operation of the TV. The main features of the LG Magic Remote are, of course, the cursor that moves around the TV screen when you move the remote in space (a gyro is built into the remote). In this case, the remote does not necessarily have to be sent to the TV.
Peter Pan: Magic Remote An important advantage is the acquisition of the C9 model with the Magic Remote , which greatly improves the ease of operation of the TV. The main features of the LG Magic Remote are, of course, the cursor that moves around the TV screen when you move the remote in space (a gyro is built into the remote). In this case, the remote does not necessarily have to be sent to the TV.
For people who are wondering, the Eclipse has this functionality implemented in the B&O app. Just go to the third screen and there is a virtual trackpad. The left part control the cursor. You move it over the TV screen and with a light tap you select the option. The rightmost part is used for scrolling.
Enjoy,
Jean
Interesting Jean. What will then be easiest to use. B&O App or Magic Remote. Have an opinion about it.
Peter Pan: Interesting Jean. What will then be easiest to use. B&O App or Magic Remote. Have an opinion about it.
Very simple: within the B&O environment, the B&O app. It can be used side by side with the Beoremote One. To my knowledge, the Magic Remote doesn't work with the Eclipse.
For a system based on a stock LG TV, obviously the Magic Remote!
For ease of use, that depends of your preferences. The virtual trackpad works like that of a computer. The magic remote works like a Wii controller. One of my relatives has a LG TV (not OLED) and use it.
www.youtube.com/watch?v=vkSOqbbuA28
A good YouTube video BEOVOX141.
The cheapest and most flexible solution with LG 55" C9 / AVR connection.Here you choose your own speaker and Surround setup.
Guess where a center speaker is located. Note wooden slats on the doors.
Peter Pan:
@ Robin
Why do you feel sorry for seeing the possibilities available with a LG C9 OLED 4K TV. ?
SkiniPlay. Possibly an upcoming opportunity.
Robin: Peter Pan: Haven’t we’ve seen this picture quite som times? Moreover this is nothing new at all. We don’t need a LG c9 screen with WiSA dongle to attach it to an oldschool avr. I don’t see the point of putting it up all the times again. I think we should rename this thread in PP’s personal blog...
It seems nothing short of a direct hit from a tactical nuclear weapon will stop him! This must be very close to the top of list of worst ever threds on Beoworld!!
Ban boring signatures!
Puncher must like my thread since he returns.
SandyB - Why just one thread, when we can have two.Viewed 39,945 times. Thank you.
Still unclear to me.Is LG wisa dongle working or not?
P.S. Peter Pan,you are TZAR
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Peter Pan: SandyB - Why just one thread, when we can have two.Viewed 39,945 times. Thank you.
- 39,900 of them are just you!!
OldJack:Still unclear to me.Is LG wisa dongle working or not?
Overview HDMI cable - hdmi.org.
ptrv:Summit Wireless predicts 60 million units of WiSA Ready platforms will be on the market in 2019. Interesting.
We are still waiting for this.
DIY -
Click here.
BeoLab 10, is a center speaker there each to recycle.
Download LG TV OLED55C9 - OLED65C9 Mamual - Click here.
Yikes, pure undiluted gadget-porn complete with a WISA logo.
Odd setup....with upfiring speakers only at the back.
They probably ran out of WiSA channels 🤥
BEOVOX141:gadget-porn
OK - I have to change that.
LG C9 OLED TV. Reviewed on May 02, 2019. By Adam Babcock, Ian Cumming, Yannick Khong. -
Note that at the end they write -The C9 also supports WiSA wireless speaker technology, although we didn't test this, and is expected to receive support for Apple HomeKit and AirPlay 2 in a future firmware update.
The 2019 LG model all have the wisa capability but where can you actually buy the usb dongle?
I recently bought the C9 and plan was to connect Lab 18,19 and 3 via Wisa but so far still running it through the beolab transmitter.
Hi alexm86
It is a question we are many who will be happy to answer. This is the only thing I could find. Click here.
google - Where can i buy LG Innotek WiSA USB transmitter.
Maybe you find something I haven't found.
During my search I found this.
TX Transmitter with USB Interface. (WiSA Transmitter).
This product is currently in development. To request more information, please contact us.United Kingdom Tel: +44 (0)1702. - Click here.
NEW 2019 Profusion Short Form Catalogue. Download - https://www.profusionplc.com/brochures.php
