Best 70's speakers
This post has 45 Replies | 2 Followers
Algor
Posts 3
Algor Posted: Sun, Nov 25 2012 11:33 AM
What are the better 70's B&O speaker?. From 1968 to 1975 and  little speaker. What do you think about Beovox 2200?
pepps
Kent, UK
Posts 116
pepps replied on Sat, Dec 8 2012 12:48 PM
Beovox 1702 are beautifully clear and neutral. Lots of detail.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Dec 8 2012 1:19 PM
Beovox 2200 is a very good speaker for its size and age but the Beovox 1100 is even better, same size but
with a dome tweeter rather than a cone.
Beovox 1700/1702 is also quite good. In my opinion better sounding than the later CX50 and CX100 but I'm
getting old and care more about what sounds pleasant to me than what looks best in the printed specs.
fergus
Posts 78
Silver Member
fergus replied on Thu, Feb 7 2013 7:52 PM
Anyone else have any suggestions?
Søren Mexico
Mexico City
Posts 6,411
I have a pair of early Bvox 1600, 2 way, later productions was 3 way, hanging on the wall wide apart they sound very good with good bass and detailed highs, of the wall, no bass and sound boring. they have rubber surrounds in the drivers, so no problems there.
fergus
Posts 78
Silver Member
fergus replied on Thu, Feb 7 2013 10:05 PM
I heard these in Eddie's last week and I thought they sounded great.
fergus
Posts 78
Silver Member
fergus replied on Sat, Feb 9 2013 12:42 AM
This might sound like a stupid question but do they only work on solid walls?
Søren Hammer
Denmark
Posts 953
The Beovox 5700 was IMO the best of the early big box uniphase designs Wink
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
fergus
Posts 78
Silver Member
fergus replied on Sun, Feb 10 2013 1:21 PM
So is the later, 3-way version better? Have you heard them?
Algor
Posts 3
Algor replied on Sun, Feb 10 2013 3:38 PM
An what do you think about S45 ore S45-2 speaker? Have they rubber too?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Feb 10 2013 4:43 PM
The S45-2 is the best bookshelf sized speaker made by B&O.  Remember that B&O did make system speakers - that is that speakers did seem to be designed with the performance of systems in mind. The Beovox 1200 is not a great speaker but suits the Beomaster 1200 brilliantly. The S45-2 works well with almost everything I have tried it with. It has a rubber surround to the woofer.
Peter
Søren Mexico
Mexico City
Posts 6,411
fergus:
Never heard the 3 way, as for the wall type, I dont think it will make much difference, I have concrete walls with 2 cm gypsum applied, its just a question of getting some reflection, a wood wall will do the same.
Søren Mexico
Mexico City
Posts 6,411
Algor:
S45 has foam surrounds, S45s are very placement critical.
Evan
USA
Posts 3,621
Evan replied on Sun, Feb 10 2013 5:43 PM
pepps:
These have been on my 'Need To Get' list for ages.
Beo4 'til I die!
Evan
USA
Posts 3,621
Evan replied on Sun, Feb 10 2013 5:45 PM
Ahem,
And as for my personal recommendation - The S45-2. Absolutely spectacular, well rounded, rich and clear as a bell. Can't praise them enough.
Beo4 'til I die!
Søren Hammer
Denmark
Posts 953
The original S45 does also have rubber surrounds as the driver units are identical to the S45-2. The later S45 with foam surrounds was a two-way low cost version of the S55.
Dillen
Posts 13,191
Dillen replied on Sun, Feb 10 2013 6:17 PM
Søren Mexico:
Algor:
Beovox S45 (6427) is a 2-way speaker and has foam surrounds.
Beovox S45 (6302) & Beovox S45-2 (6312) are both 3-way speakers and they have rubber surrounds (but lose magnets).
fergus
Posts 78
Silver Member
fergus replied on Sun, Feb 10 2013 6:17 PM
Re 5700s, I have a damaged pair of these sitting here not in use. It's mostly cosmetic damage but one of the bass cones isn't functioning perfectly.
Pity, because they're really great speakers.
Søren Mexico
Mexico City
Posts 6,411
fergus:
Thats a real pity, you should try to repair them, do you have the stands as well ?
fergus
Posts 78
Silver Member
fergus replied on Sun, Feb 10 2013 8:36 PM
Unfortunately not.
marc
s. wales uk
Posts 184
marc replied on Sat, Feb 23 2013 1:29 PM
Hi to all
I also have the beovox 5702 which both ABRs have rotten, would i be right in saying if I replace old ABRs with the kef b139 drivers and remove the magnets this to the job.
Marc
marc
s. wales uk
Posts 184
Take a look at this,
one speaker works fine and in the other one only the big driver in the centre is working, i've checked all the wiring to all drivers and all ok , also did not no that B&O used kef ABRs and celestion drive units in these speakers.
marc
Søren Mexico
Mexico City
Posts 6,411
marc:
marc
The caps in the crossover looks wrong, is that original??
marc
s. wales uk
Posts 184
marc replied on Sat, Feb 23 2013 6:43 PM
Not sure have not seen the inside of another pair, all i know is the speaker layout has changed  to 5700 and the ABRs in the 5702 are large ovell shape and are kef units. so what could need replaceing to get top to drivers to work.
marc
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Feb 23 2013 8:41 PM
The mid and tweet could both be blown. The caps could be completely dead/open circuit. Damage to circuit boards or wiring somewhere. For old speakers caps are often a problem. I just have been playing around with a set of very old Allied "triaxes" meaning a woofer, coax tweeter, and whizzer cone for a midrange. Caps were dead on both of them, I guess they were made in the 60's.
Jeff
Søren Mexico
Mexico City
Posts 6,411
Here is the scheme from the online manual, but the the scheme does not correspond with the part list, be careful if you change caps, it looks like someone tried to mach the original values with 2 or 3 caps in parallel. That may also be the reason that it does not work, maybe wrong connected or caps bad. Maybe someone with a 5700 could check it.
Søren Mexico
Mexico City
Posts 6,411
Sorry didn't work with copying, will post pics
Søren Mexico
Mexico City
Posts 6,411
Here goes
marc
s. wales uk
Posts 184
marc replied on Sat, Feb 23 2013 9:17 PM
Thanks for that, so there will be no difference between 5702 and 5700 inside if so does it mean the only changes between speakers were the ABRs and speaker layout.
Marc
Søren Mexico
Mexico City
Posts 6,411
marc:
Marc
Here is what Beocentral says:
The drive unit compliment consisted of a 10” Philips woofer, a 2.25” Celestion dome midrange and a 0.75” Celestion dome tweeter, the bass unit being supplemented by a 10” passive radiator of B&O’s own design. This model was later replaced by the lightly modified Beovox 5702.
marc
s. wales uk
Posts 184
marc replied on Sat, Feb 23 2013 9:47 PM
Ok so looks like the only difference is the kef ABR and mid range and tweeter now at the top of cabinet.
Marc
fergus
Posts 78
Silver Member
fergus replied on Fri, Mar 15 2013 7:18 PM
I wonder would it be a good idea to replace the speaker cable in the 1600 speakers with something heavier?
Dillen
Posts 13,191
Dillen replied on Sat, Mar 16 2013 6:53 AM
If my memory is still doing fine, the Beovox 5700 and 5702 only share the dome midrange.
The other drivers are different.
marc
s. wales uk
Posts 184
marc replied on Sat, Mar 16 2013 6:27 PM
just had one of the 5702 speakers checked and was told the two smaller speakers were blown, whats the chances of getting replaecment.
marc
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Mar 16 2013 8:35 PM
There are companies that will repair your drive units - I had a woofer of my M100s repaired. I was hoping to have pictures of this but the firm never sent them! They did however repair the drive unit well!
Peter
fergus
Posts 78
Silver Member
fergus replied on Sat, Mar 16 2013 11:57 PM
I have some 5700s I might be selling for parts if that would help.
fergus
Posts 78
Silver Member
fergus replied on Sat, Mar 16 2013 11:59 PM
That post was a reply for marc BTW
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Mar 17 2013 2:31 PM
Evan:
Ahem,
The slightly earlier S45 has similar performance although I suspect the S45-2 gets all the referencing because it's easier to keep it distinct from the later 1980's S45s.
The earlier S45's have moulded resin backs instead of the flat MDF back of the S45-2. The S45-2 also has a metal trim on the rear edge that the S45's don't have. It's as if B&O saved some money with a cheaper speaker back but then spent the savings on the extra edge trim! Did the moulded resin back give a better speaker performance????
Graham
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Mar 17 2013 2:35 PM
I think the flat back was made so the speaker looked better mounted on the floor stands. Don't think it made any difference to the sound - is it MDF or is it ply?
Peter
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Sun, Mar 17 2013 2:50 PM
Peter:
Also were not the resin back original S45 designed for the trumpet stand or they could also be wall mounted. I had a pair for awhile and it was slighly smaller than the S45-2 but had the same sound quality.
Page 1 of 2 (46 items) 1 2 Next > | RSS
