Hi
How can i copy all music/ albums/covers from BM5 to computer and that to new BM5 disc ?
I've copied my BS5 HDDs plenty of times using this:-
https://www.amazon.co.uk/gp/product/B006CS1VN4/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
Easy to copy to a 3.5in to a 2.5in to a caddied SDD.
Solving the SDD compatibility issue beat me until I gave up the BS5s but believe there is a Crucial SSD out there that will work.
After cloning, being a bit handy with disc partition sizing is quite useful thing to know to maximise your space. I think with Win 3SE, the system can handle 3TB max?
Maybe ask in wrong way.
I have lot's of music albums on BM5 disc..and i will sell in to my frind...just BM5
I wish to keep music on one my dics on my computer.
So..how can i download ( just )music from BM5 to my computer...and then when i buy yunger BM5 ...again copy to my new BM5 ?
is it possible ?
If you have BeoConnect software (https://www.bang-olufsen.com/en/product-support/accessories/beoconnect-for-windows), you can link from your computer to the BM5. You just connect to the BM5 as a computer over a network and file copy your music directories.
If you have Windows 10, please see this thread: https://archivedforum2.beoworld.org/forums/t/18245.aspx
If you have a Mac, you can get Beoconnect here: https://www.bang-olufsen.com/en/product-support/accessories/beoconnect-for-mac
Alternatively, you can connect a portable UBS drive and keyboard/mouse to the BM5 and boot into service mode. At this point, you have a Windows computer, and it should automatically mount the UBS drive, then you can copy the music file directories/files to the external UBS drive. I believe you will use your TV as the monitor for the BM5 computer. I'm guessing a bit because I have only done this with my BS5/BM5.
