With all the efford from the guys in the Acoustic Department and with the knowledge of how the BL90/50’s work, it would not be far away to wish for a Slave version of the Balance.....for a genuine stereo setup or as speakers for a BV.
Still wondering what the two (!) RJ45 port are for!
mbolo01:I’m maybe the only one to care, but DLNA has been dropped too .... BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Millemissen: With all the efford from the guys in the Acoustic Department and with the knowledge of how the BL90/50’s work, it would not be far away to wish for a Slave version of the Balance.....for a genuine stereo setup or as speakers for a BV. Still wondering what the two (!) RJ45 port are for! MM
BV14, BV10, BeoGram 3000, 4500, BS 9000, Moment, Core, Ouverture, Essence, Beo6, BROneBT, BeoTime, ML/NL, BLGW, BeoLab 2, 11, 18, CX100, BeoPlay A6, M3, E8/H3/H8
Reply for my question on Software Update enabling NL BeoLink Multiroom: "As the brand new BeoSound Balance does not have the respective older ASE (Audio Stream Engine), I am afraid that this is not technically possible through a pure software update."
Regarding speaker design I find it interesting that it uses the same principle for bass as the BeoLab 11 but I wonder why it's only one tweeter pointing forward without "acoustic lens" when it's supposed to be omni directional or for beam control why it haven't got multiple for tweeters in the different directions?
Millemissen: Still wondering what the two (!) RJ45 port are for!
C'mon, really?
If only Chromecast & Airplay 2 allowed me to play music to all my B&O speakers simultaneously, I would not worry about the disappearance of Beolink Multiroom... But it's not the case on my setup. The only way to play perfectly in sync is Beolink.
diisign.com
I aree. I think B&O is doing an excellent job in the audio dept with their new BeoSound and some Beoplay speakers like the A9. I wish they were all designed to enable of a pair of them to work in stereo mode. A9s in stereo mode would sound amazing. I know because I was able to do it by splitting an RCA input connection and setting both to line in as an experiment. The balance even has the form factor to be a mini Beolab system if it could work as stereo speakers.
B&O in my life 😊:
alex_112: Millemissen: With all the efford from the guys in the Acoustic Department and with the knowledge of how the BL90/50’s work, it would not be far away to wish for a Slave version of the Balance.....for a genuine stereo setup or as speakers for a BV. Still wondering what the two (!) RJ45 port are for! MM From what I've heard it's for "daisy chaining" ethernet to other devices (small two port switch?)
Who the heck would use that???
Is it because of wifi issues? AirPlay 2 plays in perfect sync in my experience. I have A9, Stage, Core and BS1
Millemissen: alex_112: Millemissen: With all the efford from the guys in the Acoustic Department and with the knowledge of how the BL90/50’s work, it would not be far away to wish for a Slave version of the Balance.....for a genuine stereo setup or as speakers for a BV. Still wondering what the two (!) RJ45 port are for! MM From what I've heard it's for "daisy chaining" ethernet to other devices (small two port switch?) Who the heck would use that??? MM
Less cables if you have products close by? Maybe it's multipurpose ports so you can connect a BeoLink IR-eye to it (like the BeoSound Core)?!
alex_112: Millemissen: alex_112: Millemissen: With all the efford from the guys in the Acoustic Department and with the knowledge of how the BL90/50’s work, it would not be far away to wish for a Slave version of the Balance.....for a genuine stereo setup or as speakers for a BV. Still wondering what the two (!) RJ45 port are for! MM From what I've heard it's for "daisy chaining" ethernet to other devices (small two port switch?) Who the heck would use that??? MM Less cables if you have products close by? Maybe it's multipurpose ports so you can connect a BeoLink IR-eye to it (like the BeoSound Core)?!
Unless you can connect a Core to it and make the Balance NetLink (please, please), you really have to wonder if it were not just another part from the bin, like the blanks on your auto dashboard.
If I buy a Beosound Balance and I want to connect it to my BLGW/BLI I will not have the possibility to control it with the Beoliving app? Not be able to make macros in my "smart house"?
Is this right??
Normann: If I buy a Beosound Balance and I want to connect it to my BLGW/BLI I will not have the possibility to control it with the Beoliving app? Not be able to make macros in my "smart house"?
Probably you’re right. I have asked Khimo in the Home Automation forum about their way forward, but no reply yet. Interim solution is adding a Core/Essence Mk2 i.e. treating the Balance as a BeoLab instead of a BeoSound. But then the control pad doesn’t have any use.
Millemissen:Who the heck would use that???
Who the heck would daisy chain Beolabs?
matador43: Millemissen:Who the heck would use that??? Who the heck would daisy chain Beolabs?
Those who have 2 x BL90 or 50.....they do it in order for them to work (as a stereo pair - and to get them to work together using the room adaptation/compentation.
Ok Millemissen, I drop the towel here
People daisy chain Ethernet devices. At least enough of them for brands to add a second port to their products.
You dont want to understand because you didn't have had the need yet but one day you'll see by yourself and that day will be a great day!
I read that too, the confuse is complete,
I talk to one of my dealer, he was well aware that beolink was missing, but had not heard if that counted all future products.
He also said that this product have been in development way longer than the Stage which make it even stranger.
On a positive note, if you make it play a radio channel, and code it for My buttons it works like before.
I also read a place that Spotify Connect would be added later.
The information on this new platform is mildly said very bad.
Millemissen: Still wondering what the two (!) RJ45 port are for! Who the heck would use that???
It's confirmed. To connect the Balance to ethernet and as a bridge to another product.
Interesting reading some of the comments under the news from various technology websites.
Your average non B&O customer is fairly negative about the brand. Apart from moaning about the cost, I saw someone comment "it's way too small for the price" (as if cost = bigger speaker) without even hearing it first!
moxxey:Interesting reading some of the comments under the news from various technology websites. Your average non B&O customer is fairly negative about the brand. Apart from moaning about the cost, I saw someone comment "it's way too small for the price" (as if cost = bigger speaker) without even hearing it first!
Beobuddy: Millemissen: Still wondering what the two (!) RJ45 port are for! Who the heck would use that??? It's confirmed. To connect the Balance to ethernet and as a bridge to another product.
In that case it’s either, what are the thinking, these guys?
Buy a BS Balance, hardwire it and connect and place your printer next to it (in days of wireless printers).....hmmmm!.
What would YOU use that ‘switch’ for?
Or they are just not telling us all about this,...yet?
P.S. Sorry - but in my view it is a ridiculous thought having a network switch in an otherweise for the most part/in most use cases wireless device.I just don’t get it ;-(
Millemissen:I just don’t get it ;-(
Because wireless isn't always reliable…
matador43: Millemissen:I just don’t get it ;-( Because wireless isn't always reliable…
Precisely. On Instagram you see many dealers selling a BV (!!) with a BeoSound placed next to it. Even though eg a Harmony has full audio capability people want a separate speaker next to it. Pointless from my point of view, but some neat extra cash for the dealer and B&O.
There's also talk in the Balance youtube videos of using 2 for stereo. In this case, you can daisy chain your speakers similar to BL4000s (and others). Not everyone is married to wireless everywhere, all the time.
Millemissen:In that case it’s either, what are the thinking, these guys? Buy a BS Balance, hardwire it and connect and place your printer next to it (in days of wireless printers).....hmmmm!. What would YOU use that ‘switch’ for? Or they are just not telling us all about this,...yet? P.S. Sorry - but in my view it is a ridiculous thought having a network switch in an otherweise for the most part/in most use cases wireless device. I just don’t get it ;-( MM There is a tv - and there is a BV.
Stan:There's also talk in the Balance youtube videos of using 2 for stereo. In this case, you can daisy chain your speakers similar to BL4000s (and others). Not everyone is married to wireless everywhere, all the time.
Chris Townsend: A pair of pre owned Beolab 17s would be far better value and do the same thing.
In my understanding a Balance combo is certainly superior to BL17s. But I’ll try to visit the store tomorrow and make a judgment.
steve1977: Millemissen: In that case it’s either, what are the thinking, these guys? Buy a BS Balance, hardwire it and connect and place your printer next to it (in days of wireless printers).....hmmmm!. What would YOU use that ‘switch’ for? Or they are just not telling us all about this,...yet? P.S. Sorry - but in my view it is a ridiculous thought having a network switch in an otherweise for the most part/in most use cases wireless device. I just don’t get it ;-( MM There is a tv - and there is a BV. Millemissem is always very well informed, so my bet goes to something new to come. I’m still quite hopeful as well that the “new audio engine” is not just a AP/CC point, but something of some form is still to come. And maybe the two ethernet ports are part of this.
In this case I am not that well informed.
I am just wondering, if what we know now, really can be all there is.
This (in this case: these) speaker(s) seem(s) predestined to make a good combination for a stereo setup.
Due to the downscaled features from the BL90/50 - directional sound, left/right/front/omni etc etc - two Harmony’s could do an excellent job if joined together like they do natively with the 90/50.
As someone already mentioned, there are in and out ports on a lot of the dedicated Beolabs.
Maybe this is just wishfull thinking - but still (as mentioned before) it would be somewhat a waste of the work in the Acoustic Department, if they just leave it to one single streaming speaker.
The decisions how to launch/sell products are not made in the Acoustic Department - these are complicated decisions made elsewhere in the company.
Just hoping ;-)
moxxey:I saw someone comment "it's way too small for the price" (as if cost = bigger speaker) without even hearing it first!
@MM: What I’ve read seems to point into the direction that the stereo pairing functions through IP and needs to be configured through Google Home. So that’s why there is double Ethernet connection. Still hope PL (or digital PL!!) is in the cards.
1990: @MM: What I’ve read seems to point into the direction that the stereo pairing functions through IP and needs to be configured through Google Home. So that’s why there is double Ethernet connection. Still hope PL (or digital PL!!) is in the cards.
You can pair any CC speaker to a stereo setup (using the Google Home app) wirelessly - no need for wired connections there.
However that does not mean, that both speakers would work together utilizing room compensation etc.
That could only be achieved through a DPL connection - master/slave setup.
Listening to BeoSound Balance at my dealer's store: Sound phantastic. Bass: All you need. Treble: Clear. Hide it behind a curtain, play some music and ask your neighbour: Which speaker ist hidden? He or she won't tell you that it is a small speaker for a bookshelf.
Peter the Biker: Listening to BeoSound Balance at my dealer's store: Sound phantastic. Bass: All you need. Treble: Clear. Hide it behind a curtain, play some music and ask your neighbour: Which speaker ist hidden? He or she won't tell you that it is a small speaker for a bookshelf.
...... and then pull back the curtains, point it out, and tell them it's only £1750 - that'll impress them!
Ban boring signatures!
1990:In my understanding a Balance combo is certainly superior to BL17s. But I’ll try to visit the store tomorrow and make a judgment.
I had the opportunity to see and listen a bit to a BS Balance in a store today.
I am not impressed - but I blame that on the not very good placement of the unit.....far from optimal (why?).
So watch out for how it is presented, before you give it your final vote.
Please be sure how the Sound Direction is set - Omni sound is different from the Front sound setting
Definitely waiting for a better demonstration.
I like it - but I don’t want it.....due to the lack of the NL fnctionallity.
It’s funny.... ...I found it smaller in real life than I thought from the pictures.
P.S
Here is a link to the video from Baron Vejrup - sound demo.
https://youtu.be/7dmGpspX9x8
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hi Miki,
I did - however sound tests in a YT video - even over headphones - are not the real thing.....
......and - sorry - I am not very fond of the music that you choose for demoing.
Also the volume seemed to be cranked up a bit too far - on the baron video it was better.
I am looking forward to listen to the Balance under better condition in other shops or with somebody at home....or in Struer.
