Beoremote Halo, the future B&O remote control
This post has 626 Replies | 9 Followers
jowus
Posts 161
jowus replied on Sat, Sep 26 2020 2:01 PM
Hi Laserakex,
But why 9 Remotes? It’s too many of a Remotes for your Systems? That amount could’ve get you BeoLab 17 or something Better?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Sep 26 2020 6:31 PM
MrAndersen:
Happy testing, and as I said, keep it coming good or bad.
some thoughts:
1. when JOIN-ed a device, display the main-speaker's name of the Group (same as on the display of the BS35)
2. Extend with a Favorite page (per NL device) in addition to the dots. Every Favorite page can hold op to ten artists/albums/tracks from Deezer/DLNA. In the B&o app the favorites can be chosen (changed, deleted).
3. ML sources connected to a BLC and set as integrated, can be choosen and started. But if for example one wants to change from Phono to A.Tape, despite the change in showing the A.Tape as source, the Phono continue to play (Note: this isn't only a phenomenon in the Halo, the app does the same). To change one first has to Std.by the ML/NL device and start the NL/ML master again with the other source.
4. add Standby for linked products.
5. confusing: if one wants to push a software update, one expect to search Product Settings of the Halo in the app, but one has to go to Settings, Products, Halo to push the software update. (maybe also a point of inprovement in general for the app. Sometimes "settings" are shown twice)
6. One iDevice is used to setup the Halo (f.e. iPhone). The other iDevice (iPad) doesn't show the image of the Halo (it becomes visible after adding a new Halo, but canceling the setup thereafter).
mr_anders_son
sweden
Posts 1,710
I want to rename the favourite buttons myself...CD, Radio, Vinyl etc etc....
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
beojeff
USA
Posts 2,012
beojeff replied on Sat, Sep 26 2020 9:37 PM
mr_anders_son:
That's an excellent suggestion.
laseralex
Posts 240
laseralex replied on Sun, Sep 27 2020 5:48 AM
jowus:
The Essence Remotes are $300 USD; to buy 9 of them is $2,700 USD.  If you know where I can get a set of Beolab 17s for that price I'll buy them immediately!
I use all the remotes quite regularly.  In the master bedroom I have a table version right next to my bed and a wall-mount near the dresser.  In the master bath I have one just outside the shower to control the M5 by the sink.  One each for kitchen, dining room, office, and lab; living room has one on the table and one on the wall.  Thus, each playback device has one remote except for master bed and living room which have 2 each due to my usage patterns.  I have used every single one of those remotes in the last 48 hours.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
TWG
Posts 1,672
TWG replied on Sun, Sep 27 2020 7:21 AM
mr_anders_son:
That's a MUST.
Would improve usability if there's e.g. "Stair Lights" instead of 2 buttons and "Radiostation XX" instead of 3 buttons...
beojeff:
Good news: it CAN play linked sources.
How do you access linked sources? Does the HALO has access through a NL/ML convertes (despite listed incompatible on the compatibility chart)?
NVGAE
Posts 27
NVGAE replied on Sun, Sep 27 2020 8:39 AM
How complicated would it be to implement the Moodwheel - which I consider to be one of the most brilliant ideas of B&O in recent times - from BS Moment on the Halo? Would that also require some hardware or is it only software dependent?
If the Halo had the Moodwheel I think it would be the most perfect remote imaginable - plus the Moodwheel would fit nicely on the screen of the Halo and be a much better solution that other kind of music browsing.
Millemissen
Flensborg, Denmark
Posts 14,680
TWG:
beojeff:
I am pretty sure that is because the shown sources are sources linked to the BS1!
And - of cource - there must be a converter in the setup for that to be possible.
matador43
Posts 1,373
NVGAE:
It should be possible! Big Smile
StKong
Copenhagen
Posts 320
StKong replied on Sun, Sep 27 2020 9:47 AM
Millemissen:
Lively to see!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 27 2020 10:08 AM
Millemissen:
TWG:
beojeff:
MM, your assumption is correct
first pic: BS9000 BCL connected and linked to the BS Shape
second pic: Beosystem 7000 BLC connected and linked to a BS35
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 27 2020 10:16 AM
MrAndersen:
Another thought:
Give the possibility to rename the "LINE IN". For example now I have a BS5e line in connected to a BLC. It would be  easier to see "BS5e" in the display than "LINE IN". Especially  because it could also be the LINE IN of the linked product ("Line-in" is shown as the source of the BS35, "LINE IN" as the BLC source for example).
beojeff
USA
Posts 2,012
beojeff replied on Sun, Sep 27 2020 10:19 AM
Carolpa:
Millemissen:
TWG:
beojeff:
Carolpa-
Have you been able to see every source from NL/ML Converters connected as Primary Linked device and Secondary Linked device? I've found certain sources will depend on whether the converter is connected as Primary or Secondary. I believe the sources are CD and Phono.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Sep 27 2020 10:51 AM
NVGAE:
I agree that MW was the best concept since a while and which made me purchase a Moment.
The Halo is not a player, a MW feature in the Halo would require some kind of storage to build an index of the customer music favorites, Deezer and DLNA, which could be huge for some of us, store the track associated moods that would be fetched from either the track metadata or from an external provider such as Gracenote, get tracks that are related from Deezer to be used in the equivalent of the two external rings, process all these informations and expose them is some form of UI that could fit in such small display. This would be CPU intensive thus requiring the Halo to be plugged in the mains all the time.
The Halo does not have the required hardware to support this processing and we all know that the MW is now dead with no more hope that it will resurrect in its current form, if it resurrects, which means the end of the concept for me, unfortunately.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 27 2020 11:15 AM
beojeff:
Carolpa-
I do not use Secondary linked products, because I didn't get the hoped/expected outcome when sources were connected Secondary. (note: this was/is based on early experience of the BLC in NL. I didn't check for changes recently. Because of no software updates for the BLC, I do not expect changes though!)
And YES: all PRIMARY sources of ML products are visible (but not all are made visible).
They are: BS9000 (radio, cd, aux), BS3000 (radio, cd, aux). Beosystem 7000 (radio, cd, phono, a.tape, a.tape2)
EDIT: just did a test. I linked the BLC with the BS3000 as Secundary to the BS35. On the Halo the BS3000 sources were, as expected, NOT shown.
beojeff
USA
Posts 2,012
beojeff replied on Sun, Sep 27 2020 11:49 AM
Carolpa:
beojeff:
Carolpa-
For me, I can add CD to the local list, but it does not appear on the app, Halo, or BeoRemote One in bluetooth mode when CD is a source on the Secondary Linked device. For the Primary Linked device, I have the similar issue with either Phono or Aux -- I can't remember which. Therefore, I must always assign the BeoSound 9000 as the Primary Linked product (for cd)  and the BeoSystem 5500 as the Secondary Linked product (for turntables). Maybe it's because I have both primary and secondary linked products. I was hoping someone else might confirm that they encounter the same issues.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 27 2020 11:52 AM
beojeff:
see the addition to my previous post.
beojeff:
did you check the boxes "Enabled" of the "Experience mapped to NL" of your BLC?
beojeff
USA
Posts 2,012
beojeff replied on Sun, Sep 27 2020 1:00 PM
Carolpa:
beojeff:
beojeff:
Of course.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Sep 27 2020 4:18 PM
Carolpa:
I think this is a product feature to be implemented so that It should be possible to provide an alias to the various .IN ports of the B&O products within the product settings itself, and have the App / remotes to leverage it when alias exists.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 27 2020 4:33 PM
mbolo01:
I would say it is!
But the chance B&o would update sw of the BLC looks very small to impossible! So that's my reason to ask for having the option for LINE IN aliasses for the Halo.
talking about sw versions, this I notices when looking for some details for the Halo. But my devices all have other sw versions........
https://support.bang-olufsen.com/hc/en-us/articles/360049745891-Which-products-can-be-controlled-by-my-Beoremote-Halo-
Millemissen
Flensborg, Denmark
Posts 14,680
Carolpa:
My Essence MK2 has a version 1.22.38750   (and is set to automatic update).
To work with the Halo it needs 1.23.40317
VERY STRANGE!!!
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Sep 27 2020 5:27 PM
Carolpa:
Got you, I keep forgetting about oldest products with no more updates, sorry, an our Moment are surely in this category now.
Thanks for the sw versions link, looks like global update is coming! All my products are also at lower versions, being the latest.
Razlaw
Posts 4,345
Razlaw replied on Sun, Sep 27 2020 6:02 PM
Millemissen:
VERY STRANGE!!!
Same here. Also my Core does not have the newest needed update. My Halo has not yet arrived. Hopefully both the software update and the Halo itself will arrive soon.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 27 2020 6:07 PM
Razlaw:
no rush! the Halo works also with the actual sw versions
Millemissen
Flensborg, Denmark
Posts 14,680
How are we to understand the table, you’ve found, then?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 27 2020 6:20 PM
Millemissen:
I interpreted it as the up-coming sw updates.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Sep 27 2020 6:28 PM
Hopefully NL multiroom, as well as AP over NL multiroom, will survive the coming update.
My products are set for manual updates since a while now.
StKong
Copenhagen
Posts 320
StKong replied on Mon, Sep 28 2020 12:18 AM
mbolo01:
Yes.
Have there been any such indications?
mr_anders_son
sweden
Posts 1,710
My Halo does not take charge from B&O charger padErm..
My iphone works!
StKong
Copenhagen
Posts 320
StKong replied on Mon, Sep 28 2020 7:48 AM
mr_anders_son:
My iphone works
Probably too low a wattage. Try with a stronger adapter, eg. for an iPad.
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Sep 28 2020 10:09 AM
mine works fine with a generic QI charger attached to my pc
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Sep 28 2020 8:34 PM
My Halo arrived.
Decent. Fairly basic though, in my opinion. You can choose your connected speaker, adjust the volume, create a few presets and so on. You can't browse music, you can't see album tracks or anything in, say, a Spotify playlist.
But, it does what it says on the tin. If you want a quick volume controller this does the job and does it well.
Worth £700? No way. £400 max.
Steph
France
Posts 1,059
Steph replied on Mon, Sep 28 2020 8:58 PM
I really love the Halo.
I only have IR products, but i think it’s time to invest in some Multiroom speakers! 😀
A true B&O product. As Moxxey said, 750€ is very expensive, but B&O is expensive... 😔
Razlaw
Posts 4,345
Razlaw replied on Tue, Sep 29 2020 12:32 AM
I wish my Halo would arrive. Dealer is waiting for his stock to arrive. I am beginning g to wonder if US release is behind the rest of the world. The app still does not show the Halo and shows no update available. Anyone in the US have one?
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Sep 29 2020 6:24 AM
Razlaw:
I thought you said you cancelled it as it doesn't support many of your devices? Not convinced I'd get one if I was playing my BL50s and it couldn't control the volume.
The Halo just reminds me of a sphere BeoRemote One. Similar screen, idea and materials. Just 3x the price.
StKong
Copenhagen
Posts 320
StKong replied on Tue, Sep 29 2020 7:21 AM
moxxey:
My initial impressions are that this thing can do an awful lot, but for anyone else then he who has set up the system, all the dis-payed linked sources (with long names) makes it quite a cluttered affair to control intuitively.
I look forward to coming updates.
Having got the impression from the Balance and other indicators that network link was a dead protocol, I am thrilled with this new tool that makes NL very much alive.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Sep 29 2020 7:38 AM
StKong:
The remote function and the NL Multiroom are two different and independent things I'm afraid.
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Sep 29 2020 9:15 AM
StKong:
Really? No more than the BeoRemote One? I was playing with mine last night. Fairly limited. Or am I missing something.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Sep 29 2020 10:44 AM
Razlaw:
I'm in the US and received my first one (bronze table) last Thursday on the launch date. I just ordered my second one (bronze table) yesterday. It seems that the color choice could have something to do with the availability. If you look at the B&O website, it shows the natural and brass table models are sold out. However, the bronze table model and all colors of the wall model are available.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Sep 29 2020 10:55 AM
beojeff:
Razlaw:
Update: This morning, the B&O site shows the brass table model as being available again. It wasn't available last night.
Page 9 of 16 (627 items) « First ... < Previous 7 8 9 10 11 Next > ... Last » | RSS
