Peter Pans Hjemmebio, - interface - tips & tricks.
This post has 1,576 Replies | 16 Followers
Millemissen
Flensborg, Denmark
Posts 14,680
Held og lykke med det.
Det var bare ment som en advarsel for de, der tror at du har testet et sådant setup.
Millemissen
Flensborg, Denmark
Posts 14,680
bwel:
Hi there,
If I am also using the Beolink Passive 1657 in this way, will the IR Receiver have any function control on the Passiv eg Volume, Mute etc or will it be eliminated for any control of the BeoLink Passive Audio into the PowerLink Din ?
Many thanks
Bob
Do I understand you right?
You want to use the BL Passive as an amp for some passive speakers.
You have connected the PL input of the Passive to the PL output of a BeoVision (the Eclipse?).
In that case there is no need for, because no use for an ir eye there (this is needed only when the Passive is connected as a linkroom device).
The volume etc is controlled via the BV through PL.
Be sure to use a fully wired PL cable - otherweise the Passive amp) won’t turn on (and off).
If you however, mean something else, feel free to write again.
bwel
Milton Keynes, UK
Posts 20
bwel replied on Mon, Dec 3 2018 11:37 AM
Apologies, I tried to reply to an earlier post that had the similar setup.
Background.
I have Beolink Passives 1657 and Ceiling Speakers in a number of rooms with ML cabling across the house. I moved in to the house and do NOT have a BeoSound for Audio Master.
I would like to use Spotify in rooms and so have been looking to connect Echo Dot’s to either
  • 1) Distribute to all rooms together
  • 2) Or connect individually to each Beolink Passive in each room.
For 2). I have tried connecting to the  Beolink Passive - PowerLink DIN as a test in one of the Rooms. I used a cable with that links to 2.5mm audio of Echo Dot and also links to USB for 5v trigger on pin 1 (from memory).
This works for 1 room ok, but I wondered if I will be able to use the Volume and Mute of the IR connected to that room Beolink Passive ?
Currently the IR does not control the Passive in this way, other than setting it to off, but not on.
For 1)
I am also looking at trying a Beolink Converter 1611 to operate as an Audio Master vial the ML to all Beolink Passives.
  • In that way, will the IT Volume and Mute work ?
  • Will I also need a B&O remote to set this up at all ?  Currently I don’t have any remotes.
  • For the Beolink Converter 1611, Other than connecting ML, what would the connections / pins be to input the Audio and if necessary, any trigger ?
  • Will I need a B&O remote to set this configuration up ?
Any advice, diagrams or other would be most appreciated.
Many thanks
Bob
Peter Pan
Posts 2,088
Hallo bwel
This drawing is what I can help with.
bwel
Milton Keynes, UK
Posts 20
bwel replied on Mon, Dec 3 2018 8:08 PM
Hi Peter Pan,
Yes, this is the method I am using to connect directly to the Beolink Passive and this works ok, but now I’m wanting to connect in to the Beolink Converter 1611. Would I use the same method of Audio In and Trigger on Pin 1 of the PowerLink on a 1611 ?
Do you have any thoughts on the other questions ?
Thanks so much for all the help and advice.
bwel
Milton Keynes, UK
Posts 20
Hi Peter Pan,
Peter Pan
Posts 2,088
Hej.
Se svar - https://archivedforum2.beoworld.org/forums/t/35644.aspx
_______________________________________________________________________________________
B&O ML-MCL Converter MCL2P Type 1741. Her med flere X-tre speaker kit og MCL 2A Relæboks + transmitter.
Volumen styres med Beo4 i det rum du ønsker lyd fra et BeoCenter 2300, som ikke har MasterLink tilslutning.
Peter Pan
Posts 2,088
Disse nye mulighed er hver at vente på, hvis opgradering
med HDMI 2.1 & cARC, holder hvad der skrives.
Peter Pan
Posts 2,088
Her et eksempel på at HDMI 2.1 / eARC SKAL være integreret i de produkter man tilslutter.
Peter Pan
Posts 2,088
Den nye konfiguration vil kræve eARC- støtte fra både dit tv og dinlydenhed, hvilket betyder at dine enheder skal
understøtte HDMI 2.1. Ældre HDMI- versioner understøtter ikke eARC. Du skal også bruge en HDMI med under-
støttelse til Ethernet, som de nyere Ultra High- Speed ​​HDMI- kabler, som omfatter Ethernet- support.
Mere læsstof her - https://tinyurl.com/ybknfw2k
Her en funktions tegning.
Billede
Peter Pan
Posts 2,088
2 x 500 Watt ASP ICEpower moduler er tilsluttet 2 x PowerLink front out på mit BeoVision 40"
Mk III TV, og levere signalet til to Passive BeoVox Penta, som er front højttaler i mit 5,1 setup.
ASP ICEpower moduler har nu leveret super lyd hver dag siden April 2005, og har kun været
uden 230V når vi har været på ferie. Så det er et køb jeg aldrig har fortrut.
På vej til "TEKNIK BOKSEN".
Jeg syntes det er lykkedes meget godt at skjule alle de nødvendige kabler.
Her beskrives af hvad der ligger bag de små nr. du ser på billedet.
1) BeoLink 1611 Converter krontrolboks, benyttes, når audio og videoprodukter med Master Link
   (ML) og 7 polet datalink /MCL) ønskes forbundet. I mit setup har Beocenter 9300 MCL link og
   BeoVision 7 ML link.
2) Remote mains switch, er en fjernbetjent netafbryder som får et on/off trikkersignal fra pin 4 i
    PowerLink  tikket. I mit setup tilslutter den 230V til min subwoofer. Her udover tændes nr. 2 -
    nr. 4. - nr. 6 og nr. 5.
3) Er endnu en Remote mains switch som trigger 230V til de to aktive BeoLab 4000 bag -
    højttalerne i mit surround system.
4) Er en 20 db antenne forstærker  som tilsluttes 230V med triggersignal fra (2).
5) Er et højttalerrelæ som sikre at ICEpower modulerne ikke givet "blobs" i højttalerne.
6) Strømforsyning til højttalerrelæet, som tændes med triggersignal fra (2).
7) X-TRA speaker kit, består af en MCL 2A relæboks, og en transciver. I mit setup sendes lyd fra
    Beocenter 9300's 80 Watt forstærker til passive højttaler i vores alrum/køkken.
8) Er fra JJAZ, en IP 205 KV Stainless, 2 X 500 Watt APS ICEpower forstærker, tilsluttet direkte fra
    BeoVision 7-40 TV's PowerLink front bøsninger med 2 stk. MK III PowerLink kabler til ICEpower
    modulerne. Strømmen til ICEpower forstærkeren slukkes aldrig.
Peter Pan
Posts 2,088
Peter Pan
Posts 2,088
Peter Pan replied on Mon, Dec 10 2018 10:06 AM
Hvordan flyttede Bang & Olufsen fra proprietær teknologi til at åbne
økosystemer uden at miste sin sjæl. - Google dk her.
Bang & Olufsen solgt sjælen for længe siden.
Peter Pan
Posts 2,088
Peter Pan replied on Mon, Dec 10 2018 3:18 PM
I mange år havde Bang & Olufsen flotte kataloger, som gennem årene fristede mig til at købe grej, jeg måtte eje.
Katalogerne har jeg stadig, så jeg kan se billeder af de fine designikoner, der skabte B&O's brand.
Millemissen
Flensborg, Denmark
Posts 14,680
Museum!
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Dec 11 2018 8:25 PM
En ting, som B&O negligere, er helt klart hvor meget B&O's tidligere design succes med deres produkter
var direkte resultatet af de to hoveddesignere, først Jacob Jensen, og derefter David Lewis. Disse to
stærke designere har været drivkraft for virksomhedens succes. I de dage havde B&O et integreret
designsprog og en bedre integration, af de fleste produkter.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Dec 12 2018 7:38 AM
mr_anders_son:
BeoVision Eclipse .. Ny software ud i aften!” Tirsdag 11 Dec. 2018
Nu ved jeg ikke om omtalte opdatering er gennemført - ?
Beovision Eclipse - Software fejl i den seneste opdatering (2.3.xx),
når du skifter lydkilder fra Deezer til "music" DLNA
Læs mere her.
Millemissen
Flensborg, Denmark
Posts 14,680
Den er ude til beta-testere....som er tilfredse med løsningerne.
Bliver snart leveret til alle.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Dec 12 2018 10:49 AM
LG 2019 OLED får WiSA-baseret trådløs Dolby Atmos-lyd - Tryk her.
Indstilling af BeoLab 19 til trådløs WiSA audio overførsel. Foto af Aussie Michael
Snart behøver man ikke længere et B&O TV for at kunne forbinde WiSA-kompatible BeoLab-højttalere.
Det er jo fint når der ikke kommer flere TV fra B&O, udover måske et med LG klistermærke.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Dec 12 2018 7:13 PM
Det er vel det samme vi så først i 2018, men først færdig udviklet nu.
WiSA Wireless Audio Tx Dongle - Download PDF fil. - Tryk her.
Millemissen
Flensborg, Denmark
Posts 14,680
Peter Pan:
Det er nok ikke så meget donglen, der er ‘problemet’.
‘WiSA Ready’-certificeringen til tv’ene skulle første være færdig - og den dermed sammenhængende software.
Denne skal jo også integreres i LG’s (og andre potentielle kunders) tv-OS.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Dec 12 2018 9:22 PM
Peter skrev - Det er vel det samme vi så først i 2018, men først færdig udviklet nu.
Det er det så ikke Millemissen. Der er deres version i stereo.
Lars skriver.
I 2019 sender LG hele ni tv-serier på markedet med indbygget WiSA. Det bliver produkter som deres OLED TV
og flagskibsmodellerne indenfor LCD TV. De TV får også indbygget dekodning for Dolby ATMOS og DTS X.
Det jeg har prøvet at forklare på General Forum.
Millemissen
Flensborg, Denmark
Posts 14,680
Peter Pan:
Selvfølgelig var det det - altså 2-kanal/aka stereo.
Der var jo ikke udviklet nogen WiSA Ready standart den gang.
Og de tv havde ikke nogen multikanal-processor indbygget....som de, der kommer i 2019 vil have det.
Millemissen
Flensborg, Denmark
Posts 14,680
Peter Pan:
Lars skriver.
Uagtet hvad ‘Lars skriver’ - de kommende LG-tv har ikke WiSA indbygget.
De er WiSA Ready, hvilket betyder at de behøver en WiSA-dogle tilsluttet via USB for at kunne sende til kompatible højtalere.
B&O’s tv har WiSA indbygget og har haft det i flere år.
Her er et link til WiSA-organisationens egen bekendtgørelse af samarbejdet med LG
https://wisa.cdn.prismic.io/wisa%2F872a168c-424f-4c5b-8a60-069f379a7b40_summit+wireless+announces+global+collaboration+with+lg+electronics_12-11-18+.pdf
Her er overalt tale om WiSA Ready!
P.S. Lur mig om ikke LG samtidigt præcenterer en trådløs soundbar med tilhørende subwoofer i 5.1.2-formatet (det er lige nøjagtigt de 8 kanaler, der er til rådighed).
Så slipper LG-kunderne for kabler fra tv’et.
Peter Pan
Posts 2,088
Peter Pan replied on Thu, Dec 13 2018 10:41 PM
Andre end Lars skriver - med indbygget WiSA.
LG gives first look at upcoming 2019 flagship TVs with built-in WiSA Hi-Fi wireless audio support -
Click here.
Millemissen
Flensborg, Denmark
Posts 14,680
Fremfor at læse journalisters artikler, kunne du jo blot læse den artikel, du selv linker til.....skrevet af dem, der producerer disse ting.
’LG will leverage Summit technology and WiSA Certification to make their 2019 lines of OLED and flagship UHD LCD TVs WiSA Ready™ and compatible with WiSA USB Transmitters as well as a range of intelligent, WiSA Certified™ speakers that together deliver unprecedented wireless sound for the home entertainment experience.’
Der skelnes mellem ‘indbygget WiSA (som i et B&O-tv) og WiSA Ready plus USB-transmitter-dongle (som er måden LG-tv’ene virker på).
Hvis du ikke har forstået det indtil nu, kommer du nok aldrig til det.
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Dec 15 2018 7:00 AM
Meget spændende hvad det vil ende med.
2017 LG OLED TV's FIRST TO OFFER DOLBY TRUEHD LOSSLESS SOUND.
SEOUL, 19. oktober 2017 - Årets førende OLED-tv fra LG Electronics, den første til implementering af
Dolby Atmos-lyd, vil yderligere forbedre lydoplevelsen for seerne med den banebrydende Dolby TrueHD-
lossless lydteknologi. LG OLED TVs overlegne billedgengivelsesfunktioner tilbyder nu en ny lyddimension
til at skabe den ideelle filmoplevelse.
Den tabløse, ukomprimerede teknologi vil blive leveret til 2017 LG OLED TV-ejere denne måned via en
over-the-air firmware opgradering, der giver ejerne en fantastisk Dolby TrueHD lyd, der allerede er blevet
vedtaget af 4K UHD Blu-ray content udbydere i den seneste film titler. Alle LGs 2017 OLED-tv'er leveres
med Dolby AC-4-dekodning, hvilket betyder, at kompatible LG-tv'er kan håndtere objektbaseret næste
generations lyd til nedsænkende tredimensionel lyd. LGs 2017 premium-tv'er er allerede Dolby Vision™
 -kompatible, hvilket gør det muligt for ejere at nyde mere end 100 studie titler af streaming streaming-
jenester med Dolby Vision-support.
Den seneste opdatering omfatter også Codec MAT-understøttelse (Metadata-enhanced Audio
Transmission) for at aktivere Dolby TrueHD-lydbits streaming på kompatible 2017 LG OLED TV'er, når
du spiller konsolspil. Og for kunder, der ønsker den ultimative oplevelse, kan de maksimale fordele ved
Dolby TrueHD nydes ved at streame indholdet via en kompatibel lydlinje til tv'et.
"LGs OLED-tv er blevet de facto-lederen på premium-tv-markedet og er den optimale platform for dem,
der søger at opleve indhold, som deres oprindelige skabere forestillede sig," siger Brian Kwon, formand
for LG Electronics Home Entertainment Company. "Med Dolbys lyd- og visuelle teknologier fortsætter
LG med at levere en forbedret oplevelse, der skubber grænserne for tv-visning i hjemmet."
LG 2017 OLED TV-ejere kan også nyde den kombinerede Dolby Vision og Dolby Atmos oplevelse via
den dedikerede indbyggede Dolby Access App, der er tilgængelig på nøglemarkederne, med ti flere lande,
der tilføjes hver måned. Appen indeholder forskellige indhold for hele familien, såsom rejser, sport og kunst.
http://www.lgnewsroom.com/2017/10/2017-lg-oled-tvs-first-to-offer-dolby-truehd-lossless-sound/
Millemissen
Flensborg, Denmark
Posts 14,680
Peter Pan:
Og hvor er det så lige denne ‘True HD Sound’ kommer fra?
Mig bekendt er der kun én kilde til det - UHD/Bluray-skiver (samt et par bluray-skiver).
Og sjovt nok er dette medium kraftigt på retur - især hos de, de vil have et slankt setup uden ekstern receiver/surroundprocessor osv.
(Et sådant slankt setup kunne være et WiSA Ready tv fra LG, der selv kan sende op til 8 kanaler ud via USB-senderen)
Mig bekendt er der ingen online streamingtjeneste (som jo for det meste er indbygget i tv’ene nu om dage) der understøtter Dolby Atmos-lyd i mere end skrumpet DD+ format.
Fint nok at reklamere med tabsfri lyd - det er blot de allerfærreste, der har gavn af den mulighed fra LG.
Men det lyder fint i reklamematerialet fra LG 😏
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Dec 15 2018 9:18 AM
@ Millemissen
Når der ikke rigtigt skete noget i forlængelse af indlæget fra 2017, kan det jo være fordi LG fandt ud af der siden
er sket noget. Nemlig at HDMI 2.1 eARC-teknologien i 2019/2020 giver nye muligheder, som eARC-teknologien
sørger for det hele kan tale sammen via RX Sil9437 chip på afdender siden, og TX Sil9438 chip i TV'et. Findes de
ikke vil eARC ikke transmittere den fulde båndbredde for 8 kanaler med 24-bit i ukomprimeret 192 khz lyd, eller
styre lip sync, med mere. Men gå tilbage i almindeligt ARC transmision.
Altså at der nu endeligt er mulighed for at give en langt bedre lydoplevelse, til os med interesse i god lyd.
Så kan vi mene hvad vi vil om Dolby Atmos-lyd. For nogle år siden var det 3D der skulle sælge produkterne.
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Dec 15 2018 10:04 PM
(Delvis fra ) BANG & OLUFSEN A/S. 2 DECEMBER 2018.
"Snorre Kjesbu har stor erfaring med produktudvikling, innovation og teknologi i globale virksomheder",
siger Henrik Clausen, CEO for Bang & Olufsen." Han vil spille en central rolle i vores bestræbelser på
at fortsætte med at udvikle progressive og innovative produkter, og opnå vores ambition om bliver det
mest ønskede lydmærke i verden, og jeg glæder mig til at byde velkommen Snorre til Bang & Olufsen".
Henrik Clausen direktør.
Held & lykke til Snorre Kjesbu. Det får han bestemt brug for.
Peter Pan
Posts 2,088
Peter Pan replied on Mon, Dec 17 2018 11:57 AM
Pro Partner-programmet er lukket ned i USA = 'en B&O butik i en butiken, der også sælger andres produkter'.
Nå, se på det, på denne måde ... Hvis der ikke er nogen butikker at købe B&O fra, så forsvinder alle de
irriterende kundeklager, om at produkterne ikke fungerer lige så magisk! som det fremstår fra Bang & Olufsen.
Men så er det da godt der findes så mange andre der kan levere.
Tidligere link- https://www.abt.com/brand/Bang-And-Olufsen -  Link nu - https://www.abt.com/brands -
Mono-brand butikker ville åbne. Multi-brand butikker ville blive sorteret. (Mono-brand). Endeligt et rigtig godt
navn, til det meste af det sortiment B&O forhandler i dag. En rigtig god idé, B&O burde indføre i Danmark.
Peter Pan
Posts 2,088
Peter Pan replied on Mon, Dec 17 2018 8:12 PM
Et ikon er nu opdateret. Beoplay A9 - nu til 3rd generation.
Strøm trådløst via AirPlay, Cast, DLNA eller Bluetooth; adgang til indbyggede streaming-tjenester
og internetradio. - 1500W kraftig lyd, spredt over 7 forstærkere og individuelle drev.- Intuitive
touch kontroller. - Room tilpasnings teknologi optimerer lyd, og automatiske software opdateringer
fremtiden sikrer lyd systemet.  Af Less.
Rygte siger at USB indgang nu er fjernet på BeoPlay 9 Mk 3.
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Dec 18 2018 6:33 PM
Millan:
Hej
Min opsætning skal være - Beoplay S8 til Beolab 7-2 center, med RJ45 til DIN powerlink adapter.
Ville det fungere, og vil du anbefale denne opsætning ?. Med venlig hilsen Millan.
Hej Millan.
Det kan du godt. Her beskrivelse, og et par tegning.
Fra S8 Hub til Beolab 7-2 højttaleren:
Du har brug for et Powerlink kabel. Traditionel RJ45 til 8-pin DIN, den 'ny' version 2013 med RJ45 stik
passer til alle de seneste B&O Powerlink RJ45-stik dåser. Det skal være fuldt loddet Powerlink Mk.II.
Kablet bruges til alle Powerlink udstyret enheder for "Speaker On", "Data" og "Data Ground" /
"Spændings reference" Fuldt kompatibel med alle Beolab højttalere. Også for aktive højttalere der ikke
har LINE IN. Dette all-in-one kabel er fuldt termineret, hvilket gør det velegnet til alle PL-produkter:
Beolab højttalere, BeoVision TV, BeoSystemer, BeoPlay, Playmaker, S8 Hub, osv.
Den tegning, hvis du er til gør-det-selv.
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Dec 18 2018 10:25 PM
Brug af Sonos med B&O Beolab højttalere er nemt! - Click here.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Dec 19 2018 11:46 AM
BeoLab 7.1/2/6 har PowerLink IN, ikke Line IN. Altså skal de have et trigger signal for at relæerne går i ON/OFF.
De har et fint design, oger meget populær som center højttaler. Men skal trigges manuelt for at modtage lyd fra
f.eks Sonos. Det er en skam da mange derfor ikke benytter BeoLab 7.1/2/6.
Min kone hjembragte en LED lys-gren. Pris 20 Kr.
Ups det var billigt! Jeg kan da godt bruge den batteri kasse.
Den kan du ikke få, og hvad i alverden vil du bruge den til spørger konen.
Jeg vil da bruge den til at trigge relæet i aktive BeoLab højttaler.
De 3 stk. AA batterier giver de 4,5 Volt DC, det passer fint til formålet.
Sådan kan de der gider trigge manuelt tilslutte BeoLab 7-1/2/6 f.eks til Sonos.
Jule tips fra Peter Pan.
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Dec 19 2018 7:44 PM
WiSA Home Audio Entertainment
Uanset om det er et 2.1 starter system eller en komplet 7.1 surround oplevelse, WiSA-certificerede enheder
arbejder altid i perfekt harmoni. Byg, skala, mix og match. Med WiSA er mulighederne uendelige. - Læs her.
Peter Pan
Posts 2,088
Peter Pan replied on Fri, Dec 21 2018 5:47 AM
Så rigtigt som det er skrevet Martin.
Peter Pan
Posts 2,088
Peter Pan replied on Fri, Dec 21 2018 3:35 PM
B&O-aktiekurs i Danske kroner. - Interesserede kan læs her.
Millemissen
Flensborg, Denmark
Posts 14,680
Peter Pan:
Hvorfor ikke bare læse her i stedet
https://www.bang-olufsen.com/~/mediaV3/corporate/investors/other-notifications/bo-1831-announcement-dk.pdf
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Dec 22 2018 7:33 AM
Gammelt til 'nyt':
Torsten Valeur B&O, forsøger vist at lave en fjernbetjening til et kommende LG C9 WiSA fjernsynet.
LG C9 Design, håber jeg. Yes - thumbs up
Page 26 of 40 (1577 items) « First ... < Previous 24 25 26 27 28 Next > ... Last » | RSS
