Playstation 5 Harmony 77 GX
This post has 8 Replies | 0 Followers
Emil Jensen
Denmark
Posts 766
Emil Jensen Posted: Thu, Dec 17 2020 1:59 PM
So am I doing something wrong?
I have connected my PS5 directly to the GX panel, for HDMI 2.1
And set audio as PCM.
But no sound, so I go into the sound settings on the LG and choose PCM, and then there is Sound.
All good,
But I turn on the tv agian and it is the same no sound?
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Dec 17 2020 4:56 PM
The lg auto sets to passthrough. Under the hmdi settings of the lg if the source is active you can set it to bitstream(default) or pcm. If you set it to pcm there is should work without fiddling everytime.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Emil Jensen
Denmark
Posts 766
Hallo Mikipidia,
Thank you for the answer, that is exacly what I have done, but it did not remember it.
I will see if it starts to remember :)
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Dec 18 2020 12:04 PM
I may not have written it clear enough so just double checking Stick out tongue
In the lg audio menu you have
-passthrough -auto -pcm
-earc -arc
Below that you have “additional hmdi setting”
Hdm1 / -bitstream -pcm
Etc for all hdmi connections.
Did you change it in there? That should fix you having to fiddle each time as it should then just “passthrough” pcm every time. (Ps i think lg is limited to passing through 2.0 pcm, so maybe also check the ps5 and set it to stereo?)
Emil Jensen
Denmark
Posts 766
Wait, So you would not recommend PCM,
That lossless right? If I use Bitstream it is only Dolby, not Dolby HD Right?
So I have to choose between HDMI 2.1 possibilities, or good sound?
That is a wierd limitation from LG.
Emil Jensen
Denmark
Posts 766
LG rolls out PCM eARC fix for 2019 TVs (B9, C9, more) - FlatpanelsHD
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Dec 18 2020 1:45 PM
doesn't work for me and I've tried every possible way with an aptv4k, am on sw 5.00.10 Confused
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Dec 18 2020 1:54 PM
pcm is only lossless if the original file is lossless. In terms of a gaming console I would recommend attaching it to the panel for latency reasons. If you want the best pcm audio I would say to attach it to the soundcenter but you could possibly get a bit more latency in gameplay. connecting it to the soundcenter will work fine with 7.1 LPCM but so far I have had no luck doing that through the tv screen. I personally think the Dolby actually sounds better because in terms of the aptv it seems to keep way more of the dynamic range in the audio, but try it and see if you can tell the difference and make your own choice. To me the aptv through lpcm sounds super flat and unexciting. I wonder how big the soundtrack actually is on any game to make any difference, in terms of streaming I prefer the dolby route. but it's a personal choice, my choice would be the ease of use and not have to fiddle if the sound quality is more or less the same.
Emil Jensen
Denmark
Posts 766
Alright, Thank you Miki,
I have also made a bit research my self, and a clear answer is missing.
But for gaming I need to choose Bitstream for Surround when going through TV, which is like that on all devices not only B&O.
And Bitstream should be as good, or at least 99% as good.
So far so good.
But when I will play a Blu-ray Disc (Which is rare) It only output in 2.0, even if I change the output for bitstream on the PS5(A menu only available when you play a Disc)
In the sound information on the Harmony it is saying that the PS5 output PCM even though I choose Bitstream so the problem is the PS5
I will try to dig further, but if anyone have found a solution that works let me hear :)
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
