So am I doing something wrong?
I have connected my PS5 directly to the GX panel, for HDMI 2.1
And set audio as PCM.
But no sound, so I go into the sound settings on the LG and choose PCM, and then there is Sound.
All good,
But I turn on the tv agian and it is the same no sound?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hallo Mikipidia,
Thank you for the answer, that is exacly what I have done, but it did not remember it.
I will see if it starts to remember :)
Wait, So you would not recommend PCM,
That lossless right? If I use Bitstream it is only Dolby, not Dolby HD Right?
So I have to choose between HDMI 2.1 possibilities, or good sound?
That is a wierd limitation from LG.
LG rolls out PCM eARC fix for 2019 TVs (B9, C9, more) - FlatpanelsHD
doesn't work for me and I've tried every possible way with an aptv4k, am on sw 5.00.10
pcm is only lossless if the original file is lossless. In terms of a gaming console I would recommend attaching it to the panel for latency reasons. If you want the best pcm audio I would say to attach it to the soundcenter but you could possibly get a bit more latency in gameplay. connecting it to the soundcenter will work fine with 7.1 LPCM but so far I have had no luck doing that through the tv screen. I personally think the Dolby actually sounds better because in terms of the aptv it seems to keep way more of the dynamic range in the audio, but try it and see if you can tell the difference and make your own choice. To me the aptv through lpcm sounds super flat and unexciting. I wonder how big the soundtrack actually is on any game to make any difference, in terms of streaming I prefer the dolby route. but it's a personal choice, my choice would be the ease of use and not have to fiddle if the sound quality is more or less the same.
Alright, Thank you Miki,
I have also made a bit research my self, and a clear answer is missing.
But for gaming I need to choose Bitstream for Surround when going through TV, which is like that on all devices not only B&O.
And Bitstream should be as good, or at least 99% as good.
So far so good.
But when I will play a Blu-ray Disc (Which is rare) It only output in 2.0, even if I change the output for bitstream on the PS5(A menu only available when you play a Disc)
In the sound information on the Harmony it is saying that the PS5 output PCM even though I choose Bitstream so the problem is the PS5
I will try to dig further, but if anyone have found a solution that works let me hear :)
