Masterlink Gateway and Beolink Gateway integration Home Assistant
This post has 82 Replies | 2 Followers
Zeus_72
Posts 35
Zeus_72 replied on Mon, Apr 5 2021 11:51 AM
Hi Baaz
I figured out what's wrong,
You have set the NMusic source as CD.
I modified the plug to make it work in this configuration as well.
Download the new version from my github repository.
Let me know if it works.
Lele
Abakus2007
Posts 68
It works! Smile
Thank You all!
I really hope this helps for other installations as well.
Now I'll add the other products and add functions.
Take care
Baaz
Zeus_72
Posts 35
Zeus_72 replied on Sat, May 1 2021 4:59 PM
Hi...
I have updated my version of the plugin.
I would be happy if someone installed it and reported any bugs.
you can download the plugin from this link https://github.com/Lele-72/mlgw.
Thank you
Page 3 of 3 (83 items) < Previous 1 2 3 | RSS
