Hi Baaz
I figured out what's wrong,
You have set the NMusic source as CD.
I modified the plug to make it work in this configuration as well.
Download the new version from my github repository.
Let me know if it works.
Lele
It works!
Thank You all!
I really hope this helps for other installations as well.
Now I'll add the other products and add functions.
Take care
Baaz
Hi...
I have updated my version of the plugin.
I would be happy if someone installed it and reported any bugs.
you can download the plugin from this link https://github.com/Lele-72/mlgw.
Thank you
