Hi, is it possible to access the service menu on the Beomaster 5 with only mouse and keyboard? I have bought a used one and can't get it to react on the remote through my BV3 over masterlink.
Hi maybe by pressing R 9 on the keyboard. It works with Beomedia 1.
Muzies and Enjoy the Music
lano: Hi, is it possible to access the service menu on the Beomaster 5 with only mouse and keyboard? I have bought a used one and can't get it to react on the remote through my BV3 over masterlink.
I think you will need an external IR eye connected to your BM5. As far as I remember, it doesn`t work with older BVs, that doesn`t detect PC command.
And yes, R9 should work.
Stefan
After R 9, 0 0 enter
This will give you the servicemenu.
At the "roles" menu, you can change some options regarding responding.
Thanks alot, this worked fine! Now I can control the Beomaster 5 over masterlink. Also, with the latest software the BV3 has PC as a source.
