Beomaster 5 service menu
lano
Posts 161
lano Posted: Tue, Feb 12 2013 9:00 PM
Hi, is it possible to access the service menu on the Beomaster 5 with only mouse and keyboard? I have bought a used one and can't get it to react on the remote through my BV3 over masterlink.
Griebel
Posts 416
Griebel replied on Tue, Feb 12 2013 11:03 PM
The answer is yes. It´s even easier than with the remote control. I guess your keyboard and mouse are connected to the BM5 via USB?
lano
Posts 161
lano replied on Wed, Feb 13 2013 5:35 AM
Yes, it's connected with USB to the BM5. Where can I found out how to do it?
Griebel
Posts 416
Griebel replied on Wed, Feb 13 2013 6:21 AM
When you see the BM5 menu (N.MUSIC, N.RADIO etc.) on the screen of your master TV, press MENU 9. Then you should be able to navigate through the service menu with the keyboard.
lano
Posts 161
lano replied on Wed, Feb 13 2013 6:41 AM
How do I press menu 9 when it doesn't react to the remote?
Hans Kroon
Uddel, the Netherlands
Posts 43
Hans Kroon replied on Wed, Feb 13 2013 11:08 AM
Hi maybe by pressing R 9 on the keyboard. It works with Beomedia 1.
Muzies and Enjoy the Music
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Feb 13 2013 11:15 AM
lano:
I think you will need an external IR eye connected to your BM5. As far as I remember, it doesn`t work with older BVs, that doesn`t detect PC command.
And yes, R9 should work.
Stefan
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Feb 13 2013 12:30 PM
After R 9, 0 0 enter
This will give you the servicemenu.
At the "roles" menu, you can change some options regarding responding.
lano
Posts 161
lano replied on Wed, Feb 13 2013 7:51 PM
Thanks alot, this worked fine! Now I can control the Beomaster 5 over masterlink.  Also, with the latest software the BV3 has PC as a source.
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
