When I connect my macbook to a BV 7 usind dvI cable and a two RCA jacks to external red and white connections (TV upper rear back side), I can't get sound.
How should I connect properlly to get the sound?, oher connections, some modifications in the config?
Advice will be very welcome.
alvar:When I connect my macbook to a BV 7 usind dvI cable and a two RCA jacks to external red and white connections (TV upper rear back side), I can't get sound. How should I connect properlly to get the sound?, oher connections, some modifications in the config? Advice will be very welcome. Thanks
BeoNut since '75
Thanks.
We are using a Macbook, so runs on apple soft.
What do you mean about the set up? using the menu option.
alvar:Thanks. We are using a Macbook, so runs on apple soft. What do you mean about the set up? using the menu option.
Thanks folk
My Mac is a 2008 model and yes i'm using a mini dvi
Any Ideas to get this f*****g sound?
Thanks so much
You will have to use the RCA input in the same AV-block as the DVI is in.
I will try and let you know!!
