Sound problems PC - Beovision 7
This post has 6 Replies | 0 Followers
Ignacio
Barcelona
Posts 39
Ignacio Posted: Fri, Nov 29 2013 8:58 PM
When I connect my macbook to a BV 7 usind dvI cable and a two RCA jacks to external red and white connections (TV upper rear back side), I can't get sound.
How should I connect properlly to get the sound?, oher connections, some modifications in the config?
Advice will be very welcome.
  • Filed under:
elephant
AU
Posts 8,219
elephant replied on Sat, Nov 30 2013 4:12 AM
alvar:
Is the PC running Windows?
And when you defined the source on the BV7 how did you set it up?
BeoNut since '75
Ignacio
Barcelona
Posts 39
Ignacio replied on Fri, Dec 27 2013 9:19 PM
Thanks.
We are using a Macbook, so runs on apple soft.
What do you mean about the set up? using the menu option.
elephant
AU
Posts 8,219
elephant replied on Sun, Dec 29 2013 2:59 AM
alvar:
Thanks.
I don't have a BV7 although I have manuals for the various models
It seems like you may have plugged the audio into the [CAMERA] position which expects video ?
What year is your MacBook from ? Are you using a MiniDisplayPort adapter ?
BeoNut since '75
Ignacio
Barcelona
Posts 39
Ignacio replied on Sun, Jan 12 2014 5:35 PM
Thanks folk
My Mac is a 2008 model and yes i'm using a mini dvi
Any Ideas to get this f*****g sound?
Thanks so much
Millemissen
Flensborg, Denmark
Posts 14,680
You will have to use the RCA input  in the same AV-block as the DVI is in.
Ignacio
Barcelona
Posts 39
Ignacio replied on Tue, Jan 14 2014 8:51 PM
I will try and let you know!!
Page 1 of 1 (7 items) | RSS
