UPDATE
The Beolink Gateway is wicked! And working alongside Lutron, it pretty much covers everything I need to do in the house.
I can also use IP cameras with H.264 stream now that the firmware has been updated. This is very good news ๐๐ป
I have added areas, zones and some NL equipment for now. I can't wait until it's all wired up.
Regards
Kiran
Born in NL; I ride ML
Progress...
I see some nudges on the roof tiles outside the bifold doors. This will need sorting out.
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230: Hay Kiran My experience is the opposite. The BeoLink2 app will only show the products if you had added them in the BLGW and assigned them to a zone.
Hay Kiran
I have assigned the TV and Converter in the same zone - living room in the blgw.
I am currently playing the CD from the 9000 on through the TV speakers and all working fine.
When I return back to the Beolink2 app, it asks to select a source and doesn't recognise I'm playing music. Also, the sources of the converter doesn't show up too or the BS9000 icon.
It works in the BeoMusic app.
Hi Kiran,
If I'm understanding, you're missing the BS9000 sources in the BeoLink App2, am I right?
If that is the case, please check on the BeoLink Gateway setup page that the BLC (the one that represents the BS9000) is defined under Resources and also that their sources are listed in the Interfaces tab.
BTW: Really nice project!
Best.-
fedenunez:Hi Kiran, If I'm understanding, you're missing the BS9000 sources in the BeoLink App2, am I right? If that is the case, please check on the BeoLink Gateway setup page that the BLC (the one that represents the BS9000) is defined under Resources and also that their sources are listed in the Interfaces tab. BTW: Really nice project! Best.-
Did you try with the BeoLink App 1?
Can you share your BLGW configuration?
fedenunez:Did you try with the BeoLink App 1?Can you share your BLGW configuration?
You are welcome!
Kiran:Progress... Pillars have come down. Steel beams in place. Regards Kiran Born in NL; I ride ML
Duels:That looks better without the pillars. Coming in nicely Kiran.
This is such a nice collection.
BeoHut:Hi Kiran, I am following your building of your own B&O-house, What a great project. So many cables, but I cannot see a label on it? How will you manage this? What kind of router/switch will you use? Looking forward to see more of your progress! Suc6!
I'm also following your building project with many interest.
Can you post some images from your Lutron install? I'm thinking about a Lutron install to control my B&O equipment. In germany with have the KNX equipment from Gira or Busch & Jaeger for example. But the Lutron Palladiom looks much better i think.
Just an example for KNX products....
http://www.basalte.be/en/products/switches
Stefan
bigdeniz:Hi Kiran,I'm also following your building project with many interest. Can you post some images from your Lutron install? I'm thinking about a Lutron install to control my B&O equipment. In germany with have the KNX equipment from Gira or Busch & Jaeger for example. But the Lutron Palladiom looks much better i think.
Why you can't install the Palladiom?
bigdeniz:Why you can't install the Palladiom?
ok, i understand. Here in germany the Lutron series are much more expensive than the KNX equipment. You can only buy the equipment at one Lutron partner. How is it in your case?
bigdeniz:ok, i understand. Here in germany the Lutron series are much more expensive than the KNX equipment. You can only buy the equipment at one Lutron partner. How is it in your case?
