Regards
Kiran
Born in NL; I ride ML
Duels:You’vee taken the roof off!!
Kiran:Yup... whole things pivoting out to create a dormer...
Kiran: Guy: Thanks - certainly looks neater than an overhead hood - I'll be interested to see it up and running. 👍🏻👍🏻
Thanks - very impressive!
Nice work Kiran... the lab 4000s are such lovely warm sounding speakers, good choice! :)
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Kiran:Progress... I changed the build again... We are adding 10 Beolab 3500s in the house starting off with the kitchen / dining downstairs... This is how you wire up a 3500 in the modern day and age... More pics when its in 👍🏻💯 Regards Kiran Born in NL; I ride ML
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:Heard about speakers using WiFi?
Kiran:I ride ML... 👍🏻💯 Regards Kiran Born in NL; I ride ML
Hiort:In Sweden we are not allowed to pull a power cord inside a wall like that
I wonder why Hiort? No danger at all if it is properly installed, shielded and insulated. If the electrics are up to date then any problem would cut out within in hundredths of a millisecond, which is so quick that there's little to no chance of a fire or any other related problem. I have had a complete rewire done in my current property and its all between the plasterboard and original brickwork and 100% certified as safe and legal to UK/European standards. Simon.
BAND'OH!: Hiort:In Sweden we are not allowed to pull a power cord inside a wall like that I wonder why Hiort? No danger at all if it is properly installed, shielded and insulated. If the electrics are up to date then any problem would cut out within in hundredths of a millisecond, which is so quick that there's little to no chance of a fire or any other related problem. I have had a complete rewire done in my current property and its all between the plasterboard and original brickwork and 100% certified as safe and legal to UK/European standards. Simon.
Not in the US, either (https://gizmodo.com/5297352/your-wall-mounted-hdtv-probably-violates-electrical-codes). Then again, we build out homes out of very flammable sticks.
Stan
FWIW, it wouldn't be compliant in Ireland either. You should have rated cabling to a power socket behind the unit, and a short power cable to plug into it.
Stan:Then again, we build out homes out of very flammable sticks. Stan
Of course none of use would admit this, but I would be interested in knowing what percentage of us BeoWorlders occasionally run a power cable through walls for a clean-looking installation. I wonder how many of us hire an electrician to install power outlets behind each and every wall speaker, tv., etc. I would suspect that very few of us hire electricians to install power outlets behind every speaker and television. I'm not saying that it's not wrong. It's just the practical reality.
I would imagine most people do it properly Jeff for insurance purposes. I certainly have done, besides it all its checked by Building Control at various stages throughout the whole renovation and everything needs to be signed off and certified. I would never cut corners, not on my own properties. Simon.
My B&O installer has always put over cables in the wall.
Maybe my ignorance, wasn't aware of the potential restrictions etc.
But it looks mighty clean.
BAND'OH!: I would imagine most people do it properly Jeff for insurance purposes. I certainly have done, besides it all its checked by Building Control at various stages throughout the whole renovation and everything needs to be signed off and certified. I would never cut corners, not on my own properties. Simon.
I find that quite hard to believe. But then, the cynic in me expects to find most people claiming to be vegetarians to be having late-night hamburger binges at McDonalds wearing dark glasses and using the alias Anastasia Beaverhausen.
Reason being what has been mentioned in the thread already. Mainly firehazard and risk for people getting hurt. Mains has to be run in "tubes" and sufficiently dimensioned leads has to be used inside those. Reason for using "tubes" is that you can rerun or add power cabling if you need, once the walls are done.
The leads need to be terminated into a wall socket or a box. From there you can run the primary cable to the equipment.
In the UK the building regs state:"Where a cable is concealed in a wall or partition at a depth of less than 50mm from any surface it must be enclosed in earth metal conduit (trunking or cable) or installed either horizontally within 150mm of the top of the wall or patition or vertically within 150mm of the angle formed by two walls, or run horizontally or vertically to an accessory or consumer unit."
Normally you run cables vertically from the plug socket in the wall or horizontally between sockets, so you know where the cable is and you don't put a nail through them hanging a picture!
Love follow this thread.
In the Netherlands cabling must be run through a tube! More work, but great if you want to change something as you can pull another cable or set of wires through easliy.
Impressive job Kiran!
Hi Kiran,
Hope you had a structural engineer / building control check out the roof design before cutting those roof rafter A frames!
Graham
vikinger:Hope you had a structural engineer / building control check out the roof design before cutting those roof rafter A frames!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Those bolts should be enough, how big is the m2 of the roof? Just wandering for snowload. But eyeballing it it looks enough
I think that a civil or structural engineer might have a different viewpoint. Building Control would probably want to see calculations.
