I understand people saying WiSA is not really showing anything new at CES2019, but what I do think is different this year is that they’re now working with a big player like LG. Hopefully, this will help gain traction for the system and B&O WiSA speakers in particular.
LG and the WiSA feature is the subject of this thread.
I can’t tell, whether the WiSA Organisation is showing anything or not....because I don’t know.
I just notced that LG does not have much focus on it - or maybe the majority of the reporters aren’t interested.
The guy from Digital Trends seems to generally have more focus on sound - he has often mentioned/reviewed B&O gear in earlier reports.
Would be nice if people could share, when they find something WiSA related from CES 2019 - there is so much going on there.....hard to get an overview.
Torben Rasmussen:Then we got an answer to WISA on LG2019. There can be a maximum of 5.1 sound and the configuration you pair, the TV will always use, ie if you have 5.1 then everything will be converted to 5.1. Nobodyintelligent sound up and down. You cannot pair WiSA with more than 1 transmitter, ie, speakers are paired to a TV, so they cannot be paired with a Transmitter 1.A dongle inserted TV is required to access WiSA.
Thanks to Torben.
Pretty sure that some could live with this mediocre solution....I couldn’t.
It's also a way of saying this on Millemissen. Then your B&O became shares reduced by as much as 34 per cent. So you still can't afford new TV.
The LG rollable display is now a real 65-inch TV - Click here.
This will be a dream for the lady, so she can see flowers in the window when she is not watching TV.
A wireless audio protocol known simply as WiSA. - Click here.
It's so amazing that a screen can be rolled up
Aussie Michael - Read more here -
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1546885583
As 'old' beoworld and B&O fan, Click here. I wish the B&O would at least continue to be part of these new developments.
LG SIGNATURE OLED TV R. - Click here - https://vimeo.com/310173331
This year, LG has also added WiSA wireless audio as an option to their OLED TV, which means that this TV can connect to wireless speakers from brands with WiSA such as Klipsch, Bang & Olufsen, System Audio.
Directly from CES 2019 the Consumer Electronics Show in Las Vegas.
Torben Rasmussen:Dongle to WISA. We have also seen how, after all, manuallycan switch to 2.0 configuration in the menu without removing pairing.
Now we have a little more to relate to than we had on page 1.Shall we start thinking about a future with the new LG TV versions, and BeoLab WiSA. ?Shall we expect a future with one new B&O HDMI 2.1/ eARC SoundCenter simultaneously. ?
how much? and when is it too much? just curious
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
What about the future -Every day around the world, a BeoVision TV breaks down and cannot be repaired.Then, the owners are forced to choose another brand. Eclipse stops when B&O hasused their last LG C7. In collaboration with LG, which owns the WebOS platform.B&O made its own submenu system on Eclipse. If a similar solution does not existits way, as was the case with Eclipse. What if Bang & Olufsen does not deliver a new SoundCenter and your BeoVision TV is gone. What about the other B&O products you have purchased besides WiSA-compatible BeoLab speakers. Think about it.
Peter Pan:What about the future - Every day around the world, a BeoVision TV breaks down and cannot be repaired. Then, the owners are forced to choose another brand. Eclipse stops when B&O has used their last LG C7. In collaboration with LG, which owns the WebOS platform. B&O made its own submenu system on Eclipse. If a similar solution does not exist its way, as was the case with Eclipse. What if Bang & Olufsen does not deliver a new SoundCenter and your BeoVision TV is gone. What about the other B&O products you have purchased besides WiSA-compatible BeoLab speakers. Think about it.
chucky:So lets not panic.
Peter Pan:Stops the heart of my setup. But I am NOT infiltrated so much into B & O's ecosystem that everything is controlled from the TV panel.
chucky:I also have little faith in the future of the beovision as is, so I am looking in to other options. Like you say the heart stops. For me it has already stopped after they gently killed ML and moved on to NL. It is simply not not integradable. I have custom installers in the house and they even had trouble to instal the converter. It is not reliable, it sometimes simply does not respond. So no ML or NL for me I will use rs232 or IP control, no more dependent on any supplier or there way of moving forward. You move to Wisa, I ask Steve for cables . The result is the same no Beovisions any more and making sure we can use all our B&O gear for the years to come. From Beovision to doorbel...all B&O what rings.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Does anyone know why B&O Wisa Receiver doesn't have a SPDIF out so that I can connect my BL5?
DMacri: chucky: I also have little faith in the future of the beovision as is, so I am looking in to other options. Like you say the heart stops. For me it has already stopped after they gently killed ML and moved on to NL. It is simply not not integradable. I have custom installers in the house and they even had trouble to instal the converter. It is not reliable, it sometimes simply does not respond. So no ML or NL for me I will use rs232 or IP control, no more dependent on any supplier or there way of moving forward. You move to Wisa, I ask Steve for cables . The result is the same no Beovisions any more and making sure we can use all our B&O gear for the years to come. From Beovision to doorbel...all B&O what rings. Chucky- that’s why I bought two BeoSystem 3s and two Beomaster 7000s. They can drive just about any display up to 1080p, can handle my older datalink sources and interface with ML and MCL2 rooms. I just use MCL2 P to drive any passive speakers from any brand I want and can connect any of my Beolab speakers as well. All with reliable copper wire. No router swapping, no interference, no drop outs. B&O offers nothing like this any longer. If I want to add WiFi or Bluetooth, I just add the latest popular device - Apple or google based or both. I’m ok with buying stuff from the used market, it’s much more affordable, but it is sad that B&O left their legacy in the dust to try to attract new customers that have no reason to develop loyalty.
Mercedes and Porsche have done a nice job recognizing that many of their old but not so rare products are quite robust and have owners willing and able to keep them running. Perhaps a B&O Classic company in Europe could be successful recreating or securing parts for a portion of the line? I think the market will be very nice for BeoSystem 3, especially with HDMI output, plus ML and NL Gateways. Maybe hurt myself saying this as I lack the means to hoard any and the price for those will surely rise. 1080p is plenty for the Pipe and Harris Tweed crowd.
@ poodleboy
'B&O Classic'- company - is a good idea. I wish me a completely new B&O MMC 1 Pickup.
SandyB:The rollable OLED is very cool - though not sure it suits every use case / environment.
@ SandyB
LG Signature OLED R - Now we have to wait half a year. The concept is smart and fits our interior design. So I can dream.
I'm excited to see a test of this TV.
The LG Signature OLED TV R can be partially rolled up to display the time, the weather, photos, an ambient scene like a fireplace, stream music and access to the home dashboard.
Peter Pan:The LG Signature OLED TV R can be partially rolled up to display the time, the weather, photos, an ambient scene like a fireplace, stream music and access to the home dashboard.
He might not be once he sees the price!
Might be Scandinavian design; Ikea or Lego?
New from WiSAStandards for wireless, hi-definition, multi-channel audio for TV, movies, sports and games.- Click here.
Just put a picture of an Eclipse on that empty wall, then 😉
For dreamers with hope. - Expected price 17.900. GBP
Mikipidia:Lol, can you imagine. The screen rolls down gently to show you a painting of an eclipse
And leave your BROne on the coffetable - to make the illusion perfect.......untill you want to listen/watch from the R-OLED 😏
Millemissen
Present and Future.
It is probably a ½ year since it was announced that B&O will launch two Sound Center, in two price classes. But only a few pip from the UK that a B&O dealer has heard of one Upcoming Sound Center allows for individual LG TV connectivity, otherwise there has been deep silence. At the CES fair, the veil was not lifted for anything in that direction. It has also been written that after Eclipse there will be no more TVs from B&O. I am losing faith in B & O as an alternative supplier, after Eclipse departs from the B&O range. Has anyone an input that can bring my belief in B&O back. ?
NOW TIME: A BeoVision Eclipse from 2017, which will not follow the technological development in 2019 on the AV front. Future: LG's 2019 versions, and hopefully something new from B&O that can bind Bang & Olufsen's ecosystem with LG's 2019 TV versions.
I'm going to buck the trend and say I don't care much for the roll-up TV. No doubt it is novel and if it rolled up into a slimline box or tube then fine but if the option is a wallpaper TV or a 2 metre coffin in my living room then it will be wallpaper TV every time, the roll-up base is far more intrusive.
Ban boring signatures!
